This product is designed to make your favorite Raspberry Pi a real all-in-one multimedia, Hifi conversion based on a PCM5122 DAC is backed up by a class D amplifier 2x20W and a headphone amplifier. All in all a 3-in-1 performance and affordability.
chany of these functions can be disengaged at will according to the desired options.
Doall audio options imaginable this product will prove an absolute must have for all audio applications on Pi.
Features:/ Strong>
- 100% Volumio compatible (Driver: IQaudio Dac plus)
- GPIO for direct connection to Raspberry Pi B + and 2.0
- GPIO report for other module connectors
- 5-Port XHP Connector with 5V Aux
- DAC Burr Brown PCM5122 (32 / 384Khz)
- Signal to Noise Ratio (SNR): 112dB
- THD: 0.0019%
- Amplifier Class D TI TPA3118D2 (2x 20W at 4 Ohms)
- Amplifier DirectPath ™ TI TPA6133A (138mW / ch under 16 ohms), Gain + 4dB
- Input voltage: 6V to 24V DC converts to 5V 3A via step-down DC / DC regulator to power the Raspberry Pi
- Recommended Power Supply: 12V 2A (not supplied), DC Jack 5.5 / 2.1mm (+ center)
- Volume control via Alps potentiometer and / or via the software interface used (wired volume control in the PCM5122)
- Outputs: RCA stereo, 3.5mm jack amplified (Headphones), Speakers via screw terminals
- IR Receiver (38kHz)NEC code for remote control (connected to the GPIO 17)
- Dimensions: 85x56mm (same dimensions as PI)
- Potentiometer: 10mm (without thread), Ø 6mm notched
- 2 jumpers, 4 spacers (M3x20mm), 8 nylon screws (M3x6mm) and button provided
Illustration PI delivered separately
