ARYLIC DAC BOARD ES9023 DAC Module I2S RCA 24bit 192kHz for Up2Stream V3
This tiny Arylic DAC Board digital-to-analog conversion module takes an I2S signal input and outputs it to stereo RCA. It is based on an ESS ES9023 chip, supporting PCM streams up to 24bit 192kHz. The module has been designed to accompany the Up2Stream Mini V3 and Up2Stream Pro V3 and offer them a conversion stage more powerful than the basic one.
Reference : 14823
27,90 €tax incl.
23,25 € tax excl.
Shipping date: 16-04-2025.
Arylic DAC Board
Arylic DAC Board Module DAC I2S RCA 24bit 192kHz
Arylic support chart
Compatibilité des modules Arylic
Product typeDAC module
DAC ChipESS ES9023
Input1x I2S
OutputRCA Stéréo
Supported sampling ratesPCM up to 24bit 192kHz
Dynamic range112dB
Interchannel isolation100dB
THD+N0dB FS 0.002%
Power supply5V 31mA
Dimensions40 x 38mm
Cables includedYes
InputI2S
DAC / ADC ChipES9023
Max sampling rate192kHz
joli son
This review has been posted for ARYLIC DAC BOARD ES9023 DAC Module I2S RCA 24bit 192kHz for Up2Stream V3
This tiny Arylic DAC Board digital-to-analog conversion module takes an I2S signal input and outputs it to stereo RCA. It is based on an ESS ES9023...
