AUDIOPHONICS DAC1796 DAC PC1796 24Bit / 192KHz
Reference : 6341
189,00 €tax incl.
157,50 € tax excl.
We relied on a reliable value, a chip CS8416-CZ from Cirrus logicfor receiving SPDIF, coupled with a reference in the matter, the converter PCM1796 by Burr-Brown.
This DAC card converts a digital signal of a sampling frequency from 32 to 192KHz and this in 16 or 24 bit.
Version 1.1 of this card now includes 2 SPDIF inputs , a TOSLINK optics and a Coaxial
The analog output is always present on the small white connector.
Great care has been given to the analog output, it includes 3 high-end AOP socket-mounted, referenceOP275.
The capacitors around the signal are all MKP and Vishay DALE resistor.
The power capacitors are of superior quality, 9x Panasonic FC 1500μF and Panasonic OSCON
In all 5 regulators is concerned to provide a stable and pure power supply, including 2 low noise closest to digital chips.
Features:/ Strong>
  • Optical and Coaxial Input
  • SPDIF Reception by Cirrus Logic CS8416
  • Decoding up to 24Bit 192KHz by Burr-Brown PCM1796
  • AOP output Burr Brown OP275 mounted on stand
  • Analogue output via connector or directly on PCB
  • Power Capacitors Panasonic FC 1500μF and Panasonic OSCON
  • MKP Signal Capacitor and Vishay Resistors
  • Power supply via a single transformer 30VA 2x15V AC + 1x9V AC
  • Dimensions of the card: 160x70x29mm
  • Mounting hole distance: 145x55
[Img-17261-left-thickbox_default]
[Img-17263-left-thickbox_default]
[Img-17264-left-thickbox_default]
