AUDIOPHONICS DACWM8741 DAC 24bit 192kHz WM8741 DIY Kit
4.0 / 5
Reference : 8631
199,00 €tax incl.
165,83 € tax excl.
We offer here a complete kit to realize a converter / volume controller / source selector 100% functional controllable to the remote control.
We relied on a reliable value, a WM8805 chip for SPDIF reception, coupled with the same manufacturer's WM8741 converter.
This DAC module allows you to convert a digital signal with a sampling frequency from 32 to 192kHz, in 16 or 24 bit.
This new kit now includes a display, a remote control, a volume controller and a source selector to select one of 4 available digital inputs.
Great care has been taken in the analog output, which now offers symmetrical and asymmetrical analog outputs.
ThePower densifiers are of superior quality (Panasonic FC) and 4 regulators handles to provide a stable and pure power supply.
Symmetrical outputs (XLR) and asymmetric (RCA) available simultaneously at the output of the DAC
Preamp function : Variation of the volume and selection of the input by remote control
Features:/ Strong>
  • Blue Display
  • Inputs: 2 x Optical and 2x Coaxial
  • Receiving SPDIF by WM8805
  • Decoding up to 24bit / 192kHz by WM8741
  • Capacitors Panasonic FC,Nichicon Gold tune, etc ...
  • MKP Signal Capacitor
  • Aluminum front panel
  • Dimensions: 80x120x25mm
Configuration options:
Dip Switch:
  • SW1: Anti clipping (from 0 to - 2db) as input
  • SW2: Brightness of the display (min / max)
  • SW3: Upsampling 128x / 256x
  • SW4: not used
https://www.audiophonics.fr/images2/8631/8631_DACWM8741_DIYKIT_1.jpg
https://www.audiophonics.fr/images2/8631/8631_DACWM8741_DIYKIT_2.jpg
https://www.audiophonics.fr/images2/8631/8631_DACWM8741_DIYKIT_3.jpg
https://www.audiophonics.fr/images2/8631/8631_DACWM8741_DIYKIT_4.jpg
https://www.audiophonics.fr/images2/7573/7573_DAC_WM8741_AUDIOPHONICS_3.jpg
https://www.audiophonics.fr/images2/5805/5805_PGAVOL_4.jpg
apres quelques heures de test sur 2 systemes tres differents je peux degager une opinion assez claire:
la bande passante est large avec un haut du spectre tres defini mais denue d agressivite,un medium limpide sans effet de projection,et un grave plutot chaleureux mais ferme et bien controle
sur un systeme dote d un medium-aigu un peu en avant,la liaison par fibre optique donnera une legere rondeur bien venue.
sur un systeme plus neutre(dans mon cas un lecteur audio analogue et un ampli hybride tube-mos fet)la liaison coaxiale ira vers un peu plus de definition(luminosite?)
dans tous les cas c est excellent et tres equilibre,digne d appareils de grandes marques 3 à 4 fois plus chers que j ai ecoute par ailleurs.....
un defaut?....la telecommande liliputienne difficile à utiliser , à la puissance limitee et à la directivite agaçante....
le kit est tres facile à assembler et le resultat ne deçoit pas.
 (3)
This review has been posted for AUDIOPHONICS DACWM8741 DAC 24bit 192kHz WM8741 DIY Kit
