DAC01 Module DAC AKM AK4490EQ 32Bit / 384 khz DSD256 & Module power supply
DAC01 Module DAC AKM AK4490EQ 24b 192 khz DSD 256 / Power supply
A DAC module that works with the AK4490EQ chip for high-definition decoding. Supplied power.
Reference : 12661
69,90 €tax incl.
58,25 € tax excl.
DAC01 AKM AK4490EQ
the DAC1, chip AK4490EQ
This DAC module is built around the chip DAC AK4490EQ capable of supporting a decoding HD 32bit 384kHz.
AKM AK4490EQ chip may receive audio streams through a coaxial or USB input. The selection of the source is done simply through a jumper. The coaxial input PCM supports up to 192kHz. The USB input for use with an interface will support the DSD 11.29964MHz, PCM 384kHz and 352KHz DXD. This DAC board is thus a very practical solution to integrate support high-quality audio files to your building projects.
This chip works with technology Velvet Sound in architecture in both channels. This technology can enhance the details of the sound while maintaining a very low distortion. To further increase the accuracy, two 32-bit filters are integrated into the architecture.
The card works with operational amplifiers LME49710NA. They are designed for high fidelity audio use and contribute to excellent sound quality.
Dedicated power supply provided
dedicated power supply DAC 1
The dedicated power supply of the DAC1 is provided. It has an AC input 15Vx2 & 9V to power all the functions of the card.
This power is supplied on a separate card that will facilitate the installation issues.
analog and coaxial output
1 DAC has an analog output and coaxial
A - AC Input 9V
B - AC input 15V x2
C - Slot for USB chip
D - Selector USB / COAX
E - Output Coaxial
F - Analog Output
chip DACAK4490EQ
S / N ratio120dB
THD + N-112dB
power Measurements45 x 100 x 28 mm
DAC card Weight42 g
weight power68 g
op ampLME49710na
micro controllerATMEGA88PA
S/PDIF ChipAK4118
Regulator/td>3296W
Voltage digital circuit3.3 V
Voltage analog decoding circuitryA5V, A3.3V
coaxial sampling ratePCM 44.1 / 48 / 88.2 / 96 / 176.4 / 192kHz
USB sampling ratePCM: 44.1 / 48 / 88.2 / 96 / 176.4 / 192/352/384 kHz
DSD 2.8224MHz / 5.6448MHz / 11.29964MHz
DXD: 352KHz
OutputCoaxial SPDIF
humm
fonctionne correctement ;
pas d'acces aux filtres et bruit de fond tres important : inutilisable avec des speakers a haut rendement . dommage .
This review has been posted for DAC01 Module DAC AKM AK4490EQ 32Bit / 384 khz DSD256 & Module power supply
