ESS ES9038PRO DAC Module I2S XLR 32bit 384khz DSD with Screen
This excellent DAC module is based on a high-end ESS ES9038Pro conversion chip. This ensures exceptional audio performance. The whole is supported by a set of components of high quality, for a rich and detailed restitution.
Reference : 12705
249,00 €tax incl.
207,50 € tax excl.
DAC ESS9038PRO
I2S XLR RCA Optical Coaxial 32bit 384kHz DSD
Module DAC ESS ES9038PRO
DAC ESS ES9038PRO
This DAC module is based on a high-end ESS ES9038PRO conversion chip. This document contains details about the transmitted signal, which results in infrequent timbre and harmonic quality.
A module particularly supplied with quality components
The ES9038PRO is supported by many high quality components, contributing to the quality of its sound reproduction. So we find on the 4 low noise NJM 5532DD / 5534DD PCB mounted on DIP8 (and therefore modifiable), LM317T / LM337T / 7805-CT voltage regulators and strong> 2 LDO low noise LT1963 . All this contributes to providing a stable current and a clean signal for a careful reproduction. In addition, a 100Mhz clock drastically lowers the jitter, always with a view of sound fidelity.
Complete connectivity
The module benefits from a complete connectivity that will satisfy most needs. There is therefore an input I2S to adapt according to his needs, as well as a coaxial plug, an optical plug and the possibility of adding a Bluetooth module to take advantage of remote transmission. In output the module offers a RCA Stereo, but also a balanced XLR output, much rarer on this type of module.
Modular thanks to the I2S
This module has mainly been thought to be associated with an excellent Amanero I2S / USB interface or an I2S / USB XMOS interface  to deliver an exceptional sound reproduction. Of course, it is also possible to take advantage of the I2S to use a different interface according to your needs. The module also allows you to add a Bluetooth receiver with a dedicated connector.
A complete DAC
To function effectively and enjoy all its features, the DAC is accompanied by several accessories. There is therefore an LCD screen capable of displaying, for example, the active source, the sampling rate, the signal format (DSD or PCM), the type of filter or the volume. To make these settings a panel with 3 buttons allows you to act on each parameter.
DACESS ES9038PRO
Regulators / LDO1x LM317T
1x LM337T
3x LT1963
1x 7805CT
OPA (DIP8)2x NJM 5532DD
2x NJM 5534DD
Clock100Mhz
DNR140dB
THD+N122dB
Sampling ratePCM : Up to 32bit 384kHz
DSD
Connectors
InputI2S (sold separately)
Optical
Coaxial
Bluetooth (receiver sold separately)
OutputsStereo RCA
XLR
Power supply2x 6V AC
15-0-15V
DAC Dimensions187 x 152 x 42mm
Screen PCB dimensions113 x 38mm
Screen PCB mounting holes spacing93 x 30mm
Display dimensions64 x 16mm
Control panel PCB dimensions88 x 17mm
Control panel PCB mounting holes spacing80mm
Poids300g
Package1x DAC ES9038Pro
1x LCD Screen
1x Control board
Schéma
DAC ES9038PRO
17805CT Regulator
2100Mhz Clock
3ESS ES9038Pro DAC
43x LT1963 Regulators
5LM317T / 337T Regulators
62x 5532DD OPA
72x 5534DD OPA
8Stereo RCA Output
9XLR Output
10I2S Input (for USB Interface, sold separately)
11Optical input
12Coaxial input
13Connector for Bluetooth receiver (sold separately)
14Screen connector
15Power connector AC 2x6V 15-0-15V
InputI2S
OutputCoaxial SPDIF
OutputOptical Toslink
DAC / ADC ChipES9038PRO
Max sampling rate384kHz
Montage ultra simple, très belles performances surtout en symétrique
Tellement simple à monter que s'en est un peu frustrant. Utilisé via un
AMANERO Combo 384, aucun problème de connexion sous linux, utilisé en connexion directe Alsa via Audacious, ou sans conversion avec la dernière version de pulseaudio (11) via le webplayer de Qobuz, j'obtiens un rendu bit perfect sans soucis jusqu'à 192kHz.
Le son est très bon via la sortie asymétrique que j'ai utilisée via l'ampli AUDIOPHONICS K214 V2 sur un casque HD800. Ampleur, douceur, précision.
J'ai testé la sortie symétrique en direct, sur le même HD800. La puissance est suffisante pour répondre à mes besoins, mais pourrait être un peu limitée pour certains utilisateurs, il faudra alors prévoir un ampli adapté. L'image stéréophonique s'ouvre et prend beaucoup d'ampleur, la légère tendance à la sibillance dans les hautes fréquences disparait.
Il me reste à jouer avec d'autres interfaces usb ou d'autres AOP, pour faire le tour de la bête.
This review has been posted for ESS ES9038PRO DAC Module I2S XLR 32bit 384khz DSD with Screen
This excellent DAC module is based on a high-end ESS ES9038Pro conversion chip. This ensures exceptional audio performance. The whole is supported...
