I received this kit with complete parts and maiboard.
Unfortunatly some part are very gently (capacitors) and i broke one put it from paper package. Now I'm waiting for new capacitor. Attention for this
This DAC in KITchip-based soldering AKM AK4490EQallows you to replace or create your own analog digital converter to obtain a decoding in High Definition 32bit 384KHz.
This version with chipDAC AK4490allows a decoding of the DSD of better quality than the models AK4399andAK4495S.
Withan input in I2S format , this KIT is perfect for use with a USB / I2S interface as our models XMOS AudiophonicsandAmanero.
The already welded CMS components (AK4490EQ and voltage regulators) make it easy to assemble the analog part to be mounted on its own. It is thus possible to easily optimize by replacing components of better quality to obtain a high resolution DAC at an affordable price.
6OP amps JRC5534Dare provided withDIP supports8allowing the change to enhance the sound of this DAC at its convenience. (OPA604, OPA134, AD844 for example).
Warning: The analog part of this DACAK4490EQinKIT is welding .
This kit requires a 2x15V DCdouble for the analog part and a power supply9V ACfor the digital part.
Download the PDF of the AK4490, the S8050 transistor and the 5V 2A relay.
Features:/ Strong>
Components to be welded:
Dimenand Weight:
Average votes 4.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Dariusz N.
