AIM Ultimate USB Audio Interface USB / DAC / Preamplifier 24bit / 192khz
4.8 / 5
Reference : 6974
62,90 €tax incl.
52,42 € tax excl.
A true Swiss Army knife from the multimedia audiophile, this sleek and stylish case combines all the functions you need: USB interface, DAC, and Preamplifier.
This USB interface will allow you to get a HIFI source from a conventional computer and will also allow you to scan high-sampling sources.
Its extensive features and its very good value for money make it a "Must Have" for anyone wishing to move to dematerialized in good conditions.
Equipped with a stereo RCA output, optical digital inputs and outputs and a 3.5 mm headphone jack, it will prove useful in all applications.
Features:
  • Volume control by endless potentiometer (+ Mute function)
  • DAC (analog digital converter): 24-bit 192kHz / 96kHz / 48KHz / 44.1kHz, THD (-90dB)
  • DAC / ADC: C-Media audio chipset CM6620A + CODEC: CM9882A
  • Power: auto powered via USB port
  • SNR: 108 dB
  • Software included: XEAR 3D Audio Center (included in drivers for Windows)
  • Support: Asio and Wasapi drivers
  • Size: 80 x 80 x 28.6 mm
  • Weight: 100 G
  • Interface: Mini USB
  • Compatibility: Windows XP, Windows 7, XP, Mac and Linux
  • 3.5 mm jack to RCA
  • Comes with USB cable and drivers
Connectors:
  • Inputs: USB, optical, analog stereo format 3.5 mm jack (scanning in 24bit / 192khz), and microphone
  • Outputs: (7.1: 3 jack 3.5 (front left / right, rear left / right, center / subwoofer)), stereo RCA,
Requirements:
  • This product is not "Stand Alone" and requires connection to a Computer
  • Available USB port
  • 1 GB of RAM
  • 20MB free hard disk space
  • Windows 7 / Vista / XP / Mac and Linux
  • CD-ROM / DVD-ROM drive for installation
https://www.audiophonics.fr/images2/6974/6974_AIMPROULTIMATEUSBAUDIO_7.jpg
Inputs / Outputs
Color
  • Black
  • Silver
Input
  • Jack 3.5mm
  • Optical
  • USB
Output
  • Jack 3.5mm
  • Optical Toslink
  • RCA
Max sampling rate
  • 192kHz
5 reviews
Le couteau suisse de l'audio
Super pratique, plein d'entrées sorties et caractéristiques audio High End (108dB, etc..).
Très bonne sortie SPDIF, qui nécessite quelques paramètres sous Linux.
Contient 2 DAC asynchrones, un ADC, un AAC, et connectique ultra-complète : peut donc servir de DAC, d'ampli casque, de convertisseur USB vers SPDIF, SPDIF vers analogique, etc....
Sous Linux il faut ajouter une regle UDEV et un fichier de profil pulseaudio pour faire fonctionner le SPDIF. Aucune idée si ce SPDIF est supporté par Windows.
This review has been posted for AIM Ultimate USB Audio Interface USB / DAC / Preamplifier 24bit / 192khz
Very Happy!
Bien reçu...à vitesse grand V...là déjà bravo à vous!...Ensuite le produit est juste génial...pour un prix mini en plus!
Totalement content de cet achat...
A suivre pour d'autres commandes éventuelles.
Cordialement
Gilles
Très bon et pratique petit boitier. Mais attention au système d'
Résumé :
Du tous bon pour le prix, qualité sonore très bonne, flexibilité d'usage au top.
Les points noir viennent de mon système d' exploitation et non pas de l'appareil.
Petit nouveau dans l'univers des DAC je n'ai pas de point de comparaison. Mais depuis quelque temps maintenant, je cherchais à tirer un maximum de qualité de mon matériel, avec divers réglage configuration (bidouille aussi ^^ ), d'un netbook Emachine d'une valeur de 199€ avec un atome 2go de ram et un ssd. Autant dire que je ne partais pas gagnant.Je suis par ailleurs passé sous Lubuntu 14.10 (15.4 au moment où j'écris) pour avoir plus de ressource disponible, et, ai installé DeaBeef. Le tout pour avoir un son plus que convenable. Mais voila le convenable ne me suffisant plus, je me suis mis à me renseigner sur la HQ pour découvrir par la suite l’existence des DAC.
J'ai longtemps hésité, et fini par me décider à en acheter un petit pas trop chère, pour voir. Je suis tombé sur le modèle Ultimate de AIM, ses spécificité sont plus qu'intéressante 24 Bits/192Khz, Optique In/Out, prise casque etc. Après confirmation que le flux USB sort bien aussi en optique, et que la qualité sera bien au rendez vous malgré le faible prix, je passe commande.
Livraison rapide, deux jours, le colis est bien emballé, rien à redire. Le packaging du Ultimate inspire la qualité, une boite blanche contenant le produit dans une autre qui sert de couverture. Le Ultimate en lui même est bien fini, bouton alu, plastique noir mat pour la base, plastique noir brillant au sommet, le genre qui aime se souvenir et vous rappeler que vous y avez posé les doigts.
Il est reconnu natif sous Lubuntu 14.10, ce n'est pas se qui il y a de plus ergonomique, mais rien de rédhibitoire. Il faut dans les lecteurs sélectionner, la bonne sortie du pilote ALSA, pour la sortie casque:USB2.0 High-Speed True HD Audio, USB Audio Direct hardware device without any conversions, ouf ! Cela trouvé et coché, je passe à l'écoute, et là, ça n'a plus rien avoir, après différentes écoutes, du classique au Mathmetal en passant par les B.O. d'anime, j'affirme que le son est plus précis, plus ouvert, plus langoureux, adieu ce filtre radiophonique qui entachait mes musiques.
Je me sert aussi de mon netbook comme pc multimédia relié à ma barre de son Sony HT-XT1 via un câble jack/jack 3,2 mm. Le Ultimate ma donc permis de passer par de l'optique, mais j'ai eu du mal à le faire fonctionner.
Je m'explique, le souci venait de la sortie audio à définir. Il ne faut pas la définir sur S/Pdif mais sur : High-Speed True HD Audio #1, USB Audio Direct hardware device without any conversions. Ce qui vous en conviendrez n'a aucune logique, bref une fois ce petit désagrément passé, la joie arrive, une très bonne qualité de son, le film Godzilla et impressionnant par rapport à avant !
Autre point important, le bouton de volume ne fonctionne qu'avec le volume des lecteurs, grâce aux raccourcis, par exemple Ctrl+ tourner le bouton (en ayant préalablement bien configurer le tout). De plus à l'heure où j'écris, je n'ai pas réussi à faire transiter par le Ultimate les sons de mon navigateur web, donc pour pouvoir visionner une vidéo youtube avec du son je suis dans l'obligation rebrancher mon casque sur la sortie de mon Netbook.
J’attends l'arrivé prochaine d'un vinyle de Klone pour m'essayer à l'acquisition, voir le rendu du Ultimate.
Malgré des point noir ; qui ne sont de toute façon pas à imputer au Ultimate ; c'est un achat que je ne regrette absolument pas, et que je referai sans aucun doute. Ou peu être un petit U-Sabre TXO, une fois que je me serai lassé ^^ .
Excellent, à la fois en lecture et en numérisation de source analogique. Je m'en sers pour numériser mes K7 audio avec audacity. Une fois numérisés, j'écoute mes fichiers audio à partir de mon ordinateur via le DAC sur ma chaine HIFI avec plaisir.
Je regrette juste qu'on ne puisse pas l'utiliser comme DAC pour écouter un smartphone sur une chaine HIFI.
Commandé alors qu'il n'était pas en stock et je l'ai reçu 2 jours après! Cool et règlement très sécurisé.
Sous Linux openSuSE 12,2, reconnu sans trop de problème en USB sur un portable déjà ancien.
Pour moi le résultat en lecture de CD est excellent, bien au dessus de ma carte son Terratec EWX 24/96 pourtant bien notée (voir Audiofanzine). Idem pour le flac en 24/96, je ne suis pas allé plus loin. Donc 4,5/5 pour le DAC.
Comme je n'ai pas de source analogique digne de ce convertisseur pour l'instant, je n'ai pas encore testé le ADC.
