AUDALYTIC AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Black
The Audalytic AH90 is a DAC offering excellent decoding performance and precise sound reproduction, thanks to a careful and intelligent design. And it's reasonably priced for what it delivers. As well as using top-of-the-range components, such as an AKM AK4499EX DAC chip or an XMOS XU316 USB interface, the AH90 boasts comprehensive connectivity, even providing balanced and single-ended amplified headphone outputs. It's also a connected device that can be used as a streamer, thanks to its RJ45 Ethernet port.
4.5 / 5
By buying this product you get 59 loyalty points
Reference : 18305
599,00 €tax incl.
499,17 € tax excl.
Shipping date: 25-09-2026.
Audalytic AH90
Audalytic AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Noir
AK4499EX DAC
The Audalytic AH90 is based on an AK4499EX digital-to-analog conversion chip and an AK4191 digital modulation chip. This design drastically reduces interference between digital and analog circuits. As a result, the AH90 is able to deliver high-quality decoding, favoring high-precision, crystal-clear playback.
FPGA
With its integrated, specially programmed FPGA, the AH90 ensures high-quality clock signal processing. It is thus able to greatly reduce jitter levels for perfect signal synchronization and enhanced sound accuracy.
Streamer
The Audalytic AH90 features a streamer function via Ethernet, enabling you to stream your music remotely. In particular, it supports DLNA, AirPlay and Roon protocols, enabling you to access your music from devices connected to the local network, whether a computer, NAS or smartphone.
The AH90's USB-C input is combined with a 3rd-generation XMOS XU316 USB interface. This ensures efficient signal decoding via this input, and supports high-resolution audio streams up to PCM 32bit 768kHz, DSD512 and MQA.
CK-01 Clock
The on-board CK-01 clock oscillator enables the AH90 to supply its FPGA with a high-precision clock signal. This greatly reduces the device's jitter.
Headphone outputs
The Audalytic AH90 features a headphone amplifier with two outputs: a balanced Jack 4.4mm and a single-ended Jack 6.35mm. In addition, two gain levels are available to enable the device to adapt to the vast majority of headphones on the market.
MQA
The AH90 is capable of efficiently decoding MQA (Master Quality Authenticated) streams. These ensure sound reproduction as close as possible to the original studio recording, thanks to files validated directly by the artist, record company or copyright holders.
1Power button
2Screen
3Jack 6.35mm single-ended headphone output
4Jack 4.4mm balanced headphone output
5Multifunction knob
6Coaxial input
7100-240VAC power input
8Balanced XLR output
9Single-ended RCA output
10Coaxial input
11Optical input
12USB-C Audio input
13Ethernet RJ45 port
14Micro SD slot for firmware update
1512VDC power input
16Fuse
Product typeDAC
DAC chipAKM AK4499EX
Inputs1* Ethernet RJ45
1* USB-B
1* Optical Toslink
2* Coaxial
Outputs1* Balanced stereo XLR
1* Single-ended stereo RCA
Supported sample ratesUSB / LAN: PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256, MQA
Optical / Coaxial: PCM up to 24bit 192kHz, DSD DoP up to DSD64, MQA
Frequency response20Hz - 20kHz ±0.5dB
Output levelRCA : 2Vrms
XLR : 4Vrms
Supply voltage100-240VAC OR 9-15VDC 2.5A (Jack DC 5.5 / 2.1mm)
Dimensions220*170*50mm
Package1* Gustard AH90
1* Power cable
1* USB cable
1* Remote control
Audalytic AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Noir Audalytic AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Noir Audalytic AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Noir Audalytic AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Noir Audalytic AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Noir Audalytic AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Noir Audalytic AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Noir Audalytic AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Noir
InputRJ45
OutputJack 4.4mm
OutputJack 6.35mm
DAC / ADC ChipAK4499EX
Max sampling rateDSD512
Max sampling rateMQA
Max sampling rate768kHz
NetworkingYes
Remote ControlYes
2 reviews
Complet et sobre
Ce dac ne fait pas dans l'esbroufe, aucune option inutile, très sobre, l'écran est petit, pas très lumineux, limite triste.
Pas très grave pour moi, car je n'aime pas ces petits écrans quand j'écoute de la musique, d'ailleurs j'ai activé la fonction qui l'éteint après 30 secondes sans activité.
Il reste donc que le voyant en façade, qui est aussi le bouton tactile pour l'allumer/l'éteindre, mais ce dernier ne change pas d'apparence si allumé ou éteint, stupide.
Il m'arrive donc de l'éteindre en voulant l'allumer... ou l'inverse.
On n'achète pas ce dac pour son physique, mais pour ses caractéristiques, et là, il est bien placé.
Je ne rentre pas dans le délire des puces, chacun fait son choix.
Ce dac contient une partie amplification casque, avec 2 sorties, très pratique, des sorties asymétrique & symétriques, nombreuses entrées dont une prise RJ45 pour le streamer, ce qui, pour moi est l'élément déclencheur de l'achat.
Compatible ROON, reconnu immédiatement, c'est parfait.
Toutefois, bien penser à mettre à jour le firmware (assez simple comme opération) sans quoi, le DAC génère une nouvelle adresse mac à chaque allumage, engendrant parfois des conflits d'adresse IP sur votre réseau.
Là encore, étrange, on peut trouver le firmware sur un forum "Head-fi", mais pas sur le site officiel de la marque.
Ce dac est donc à destination des utilisateurs qui recherchent un produit performant sans options inutiles et vu-mètre multi-couleurs, au rapport qualité prix excellent.
This review has been posted for AUDALYTIC AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Black
Excellent dac streamer de Gustard
Dac et streaming en un seul appareil.
Qualité de son au rendez-vous.
Nombreuses connexions.
Possibilité d'alimentation externe, un vrai plus.
Télécommande.
Un maillon de la chaine de reproduction audio réussi.
À ce prix il n'ya pas mieux je pense.
Grande communauté des appareils Gustard.
Une valeure sûre dans le monde de l'audio
The Audalytic AH90 is a DAC offering excellent decoding performance and precise sound reproduction, thanks to a careful and intelligent design. And...
