AUDIO-GD NFB-10.33 DAC / Headphone Amplifier / Preamp 24bit / 192KHz WM8741 TCXO
Reference : 8191
699,00 €tax incl.
582,50 € tax excl.
Including 1,00 € for green tax
This versatile device (DAC, Headphone Amplifier and Preamplifier), has many inputs to be comfortable in all configurations.
Its Ultra Modern DAC allows you to manage 24-bit 192Khz sources directly via USB and SPDIF inputs.
The 100% discreet design of this amplifier is backed by a high power power supply and a relay volume controller.
The 24k Gold Plated RCAs and the Nover (UK) capacitors have been specially manufactured on Audio-Gd specifications.
Features:/ Strong>
  • 3 digital input channels: coaxial (BNC and RCA) / optical / USB
  • Output of the DAC: XLR * 2 / RCA * 2 / CESA
  • Headphone output: 4-pin XLR / Jack 6.35 mm
  • TCXO option included
  • Supplied with Aluminum remote control
USB Interface
USB 32 (Via VT1731)
DAC
THD
<0.001%
0DBV output level
44.1K sampling input, 1VP-P
Max volume
Signal / noise ratio
> 120dB
Output Level
Headphone output: 19V RMS (balanced, max)
Preamp Variable output (balanced): 10V RMS (max)
Preamp Variable output (RCA): 5V RMS (max)
Fixed output (balanced): 5V RMS
Fixed output (RCA): 2.5V RMS
ACSS: 2MA + 2MA
Output Power (Headphones). <Single-ended
3300MW / 25 ohm
1650MW / 50 ohm
850 MW / 100 ohm
300 MW / 300 ohm
150MW / 600 ohm
Balanced mode
9950MW / 25 ohm
5950MW / 50 ohm
3300MW / 100 ohm
1150MW / 300 ohm
590MW / 600 ohm
Gain
12DB at H gain
0 DB at L gain
Output impedance
2 ohms
himselfInput Capability
0.5 Vp-p (75 Ohms, Coaxial)
19 dBm (Optical)
USB1.1, USB2.0, USB3.0 (Full Speed, Class2)
Frequency Response
20Hz - 20KHz (<-0.4DB)
0DBV output level
96K sampling input
USB compatibility
44.1 to 192 kHz
Supported sampling ratesUSB model: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz
Coaxial model: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz
Optical model: 44.1kHz, 48kHz, 88.2kHz,
96kHz (176.4KHz and 192KHz available if the source support)
Consumption
18W
Weight & Dimensions
5KG
240 × 360 × 80mm
Accessories
AC power cord X1
USB cable X1
Mini remote controller X1
https://www.audiophonics.fr/images2/8191/8191_audiogd_NFB-10.33_dac_2.jpg
">https://www.audiophonics.fr/images2/8191/8191_audiogd_NFB-10.33_dac_1.jpg
https://www.audiophonics.fr/images2/8191/8191_audiogd_NFB-10.33_dac_4.jpg
