By buying this product you get 94 loyalty points
Its ultra-modern DAC allows you to manage 32bit 384kHz sources directly via Amanero (Asynchronous) USB interface and 32bit 192kHz via S / PDIF inputs. P>
This version incorporates the same new features as the NFB-1DAC namely:
The 100% discrete and symmetrical design of this amplifier is backed by a high-power isolated power supply and a selection of high-end components (R-core transformers, DALE resistors, WIMA capacitors and 2 ultra low Jitter TCXO clocks.
Included Options:
Features:/ Strong>
USB Interface | Amanero |
DAC | ESS Saber ES9018 |
THD | <0.0005% (0DBV output level) |
Signal / noise ratio | > 120dB |
Output Level |
Output Power (Headphones). P> | 3300MW / 25 ohm |
Output Power (Headphones). Balanced mode |
P> |
Gain P> | 12DBat H gain |
Output Impedance | 2 ohms |
Input sensitivity | 0.7V to 5V RMS RMS (RCA) |
Frequency Response | |
USB compatibility | 44.1 to 192kHz |
Supported sampling rates | Model USB / I2S: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4, 192kHz, 352.8, 384kHz DSD 64/128 DXD coaxial model: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4, 192kHz |
Consumption | 25W |
Weight & Dimensions | 5KG 240 × 360 × 80mm |
Accessories | ACpower cord x1 USB cable x1 Mini remote controller x1 |
P>
P>
P>
[Img-10173-left-thickbox_default]
[Img-14090-left-thickbox_default]
[Img-13362-left-thickbox_default]
[Img-13363-left-thickbox_default]
