By buying this product you get 26 loyalty points
Tube OP+BUF DAC Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512
The Aune Flamingo is a tube DAC with a built-in headphone amplifier. The device is actually a hybrid structure, allowing you to use the tube circuit to enjoy a warm and round sound, or to select the operational amplifier section for a precise and clear reproduction. The Flamingo is a high-performance device that will also allow you to enjoy your high-resolution files, up to PCM 32bit 768kHz and DSD512.
In addition to its USB-B and coaxial inputs, the Aune Flamingo integrates a Bluetooth 5.0 receiver, allowing you to stream your music simply and remotely, from a smartphone or a tablet for example. The chip used supports the high-definition transmission codecs aptX HD and LDAC, for a sound reproduction of high quality even in wireless.
With its seven selectable digital filters, the Flamingo offers you the possibility to adapt its sound reproduction to your taste and your audio system. The following filters are available :
The OP+BUF section combined with the Flamingo's high current power supply gives it a great power reserve for its headphone amplifier circuit. It will thus be able to accompany most of the headphones on the market without difficulty.
Special attention has been paid to the power supply of this Flamingo. This one allows to provide to all the audio circuits a clean and stable electrical signal, in an independent way.
The manufacturing of the Flamingo shows the will of the brand to provide a high quality equipment. Aune has thus selected high-end components with high performances to equip its DAC.
Product type | DAC |
Inputs | Bluetooth 5.0 1x USB-B 1x Coaxial |
Outputs | 1x Stereo RCA 1x Jack 6.35mm headphone output |
Supported sampling rates | USB : PCM up to 32bit 768kHz, native DSD up to DSD512 Coaxial : PCM up to 24bit 384kHz, DSD DoP up to DoP128 |
Line output level @ 0dB | OPA : 2Vrms Max Tube : 1.9Vrms Max @ 0dBFS |
Line output frequency response | OPA : 20Hz-20kHz ±0.02dB Tube : 20Hz-20kHz ±0.6dB |
Line output THD+N@ 1kHz | OPA : 0.0003% @ 0dBFS Tube : 0.02% @ -17dBFS |
Line output noise floor | OPA : 4µV Tube : 20µV @ AES17 (20kHz) |
Headphone output power | 45mW @ 300Ω, 0.05% |
Headphone output THD+N @ 1kHz | OPA : 0.0005% Tube : 0.035% |
Supply voltage | 12VDC |
Housing material | Aluminum |
Dimensions | 135 x 101.1 x 27.1mm |
Color | Black |
Package | 1x Aune Flamingo BT 1x Remote control 1x Male USB-A to male USB-B cable 1x Male USB-B to female USB-C adapter 1x Male Jack 6.35mm to female Jack 3.5mm adapter 1x Power supply 12V |
Input | USB |
Input | Bluetooth |
Input | SPDIF |
Output | Jack 6.35mm |
Output | RCA |
DAC / ADC Chip | NC |
Max sampling rate | DSD512 |
Max sampling rate | 768kHz |
Color | Black |
Networking | No |
Remote Control | Yes |
