AUNE X8 DAC FPGA Altera Max II 32bit 768kHz DSD512 XMOS Silver
The Aune X8 is a high-performance DAC, compatible with high-resolution files up to 32bit PCM 768kHz and DSD512. The conversion is done using an Altera Max II FPGA chip, specifically programmed by Aune to achieve high conversion quality.
By buying this product you get 23 loyalty points
Reference : 15044
239,00 €tax incl.
199,17 € tax excl.
This product has been replaced by the new version, the AUNE X8 XVIII BT MAGIC DAC FPGA Bluetooth aptX HD LDAC.
Aune X8
Aune X8 DAC FPGA Altera Max II 32bit 768kHz DSD512
The Aune X8 is a high-performance DAC, compatible with high-resolution files up to 32bit PCM 768kHz and DSD512. The conversion is done using an Altera Max II FPGA chip, specifically programmed by Aune to achieve high conversion quality. The device benefits from a complete range of connectors, with USB-B, Coaxial and Optical inputs. The audio stream can then be output to an RCA Pre-Out or RCA Line output.
Adapt the X8 to your preference!
A special feature of the Aune X8 is that the OPA sound can be easily interchanged with another model to adapt the sound reproduction to your listening experience. The underside of the device shows the OPA in place, mounted on a DIP8 bracket, and is delivered with an extraction clip and a storage box for your OPA.
The device also offers a series of 7 filters to adjust its sound signature more and more precisely.
Aune X8 DAC FPGA Altera Max II 32bit 768kHz DSD512 Aune X8 DAC FPGA Altera Max II 32bit 768kHz DSD512
FPGA
The Altera Max II FPGA is the true heart of this Aune X8. Its program, developed and optimized by Aune, allows a particularly efficient conversion of digital streams.
Product typeDAC
Conversion chipFPGA Altera Max II
USB InterfaceXMOS U308
Inputs1x USB-B
1x Optical Toslink
1x Coaxial
Outputs1x RCA Pre-Out
1x RCA Line out
Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD up to DSD512
Coaxial : PCM up to 24bit 384kHz, DSD DoP up to DoP128
Optique : PCM up to 24bit 192kHz, DSD DoP up to DoP64
Output level (line out)2Vrms
Frequency response (line out)20Hz - 20kHz ±0.2dB
SNR (line out)117dB
THD+N (line out)0.0006%
Housing materialAluminum
Dimensions145 x 171 x 45mm
ColorSilver
Package1x Aune X8
1x USB Cable
1x Power supply
DAC / ADC ChipAltera MAX II
Max sampling rateDSD512
Max sampling rate768kHz
ColorSilver
Venceslav
I solved the problem with the installation with the usb plug, it was tested on you tube, and at the moment via spotify, great sound, I am pleasantly surprised, great device :)
This review has been posted for AUNE X8 DAC FPGA Altera Max II 32bit 768kHz DSD512 XMOS Silver
The Aune X8 is a high-performance DAC, compatible with high-resolution files up to 32bit PCM 768kHz and DSD512. The conversion is done using an...
