BURSON AUDIO CONDUCTOR 3 REFERENCE DAC Class A Headphone Amplifier Preamplifier 2x ES9038Q2M Bluetooth 32bit 768kHz DSD512
Burson Audio offers with its Conductor 3 Reference a DAC, Class A headphone amplifier and preamplifier combo of great quality. Its digital/analog conversion stage is indeed equipped with a pair of ESS ES9038Q2M DAC chips, associated with a USB XMOS receiver chip using a custom Thesycon driver.
By buying this product you get 199 loyalty points
Reference : 15326
1 990,00 €tax incl.
1 658,33 € tax excl.
Burson Audio Conductor 3 Reference
Burson Audio Conductor 3 Reference DAC Amplificateur Casque Class A Préamplificateur 2x ES9038Q2M Bluetooth 32bit 768kHz
Burson Audio offers with its Conductor 3 Reference a DAC, Class A headphone amplifier and preamplifier combo of great quality. Its digital/analog conversion stage is indeed equipped with a pair of ESS ES9038Q2M DAC chips, associated with a USB XMOS receiver chip using a custom Thesycon driver. This combination allows to deliver a rich and precise sound, while supporting high sampling rates, up to PCM 32bit 768kHz and DSD512.
Conveniently, the Conductor 3 Reference also features a Qualcomm CSR8675 Bluetooth 5.0 receiver, supporting the aptX HD audio codec, allowing you to remotely stream your music, from a smartphone for example, with improved quality, comparable to CD.
The unit also incorporates Burson Audio's patented MCPS (Max Current Power Supply), increasing the voltage frequency from 50Hz to 170kHz, pushing noise beyond the threshold of human hearing. Moreover, it takes advantage of a low impedance to offer an important energy reserve to the output transistors. It is worth noting that the Conductor 3 Reference has no less than 5 sets of MCPS. Each element, namely the display, the controls, the DAC and the left and right analog channels are all independently powered.
In terms of design, the device's components are hidden in a robust high-density aluminum case. This chassis also acts as a heat sink to keep the components at an acceptable temperature. On its front panel, the Conductor 3 Reference is equipped with an OLED display for intuitive and fluid use.
Product typeDAC
Headphone amplifier
Preamplifier
DAC Chips2x ES9038Q2M
Amplifier typeClass A
Bluetooth ChipQualcomm CSR8675
InputsBluetooth 5.0
2x Line level stereo RCA
1x USB
1x Optical Toslink
Outputs1x Pre-Out stereo RCA
1x DAC Out stereo RCA
2x Jack 6.35mm headphone outputs
Input impedance40kΩ
Frequency response0Hz - 58kHz ±1dB
THD< 0.0015%
Output impedanceHeadphone amplifier : 0.5Ω
Pre Out : 1Ω
DAC Out : 25Ω
Headphone amplifier power output7.5W @ 16Ω
5W @ 32Ω
1.75W @ 100Ω
1.16W @ 150Ω
0.58W @ 300Ω
Channel separation (DAC)142dB @ 1kHz
135dB @ 20kHz
THD+N (DAC)0.0005% @ 1kHz, 0dBFS
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DoP512
SPDIF : PCM up to 24bit 192kHz
Dimensions255 x 270 x 70mm
ColorSilver
Weight5kg
Package1x Burson Audio Conductor 3 Reference
1x USB Cable
1x RCA Cable
1x Power supply
OutputJack 6.35mm
DAC / ADC ChipES9038Q2M
Max sampling rate768kHz
Max sampling rateDSD512
ColorSilver
ClassClass A / AB
Remote ControlYes
Burson Audio offers with its Conductor 3 Reference a DAC, Class A headphone amplifier and preamplifier combo of great quality. Its digital/analog...
