BURSON AUDIO CONDUCTOR 3X GT DAC 2x ES9038 Class A Headphone Amplifier 10W Bluetooth 5.0 32bit 768kHz DSD512
The Burson Audio Conductor 3X GT, a DAC and headphone amplifier combo, takes Burson's unique sound quality a step further with a new output stage for its two ES9038 digital converters. A new feedback-based gain control allows this GT to reach a maximum power of 10W on its XLR headphone output, while accommodating many headphones. With so many features and refinements, the Conductor 3X GT is the perfect ally for immersive listening.
By buying this product you get 309 loyalty points
Reference : 16446
3 090,00 €tax incl.
2 575,00 € tax excl.
Burson Audio Conductor 3X GT DAC 2x ES9038 Amplificateur Casque Class A 10W Bluetooth 5.0 32bit 768kHz DSD512
A single output circuit
The Conductor 3X GT uses a custom designed output stage, specifically for this device and therefore different from the generic circuits on most DACs on the market. This allows the Burson DAC to use the wide bandwidth of the Vivid PDUs. Combined with the brand's Max Current power supply supplied with the device, the 3X GT offers a unique sound signature, with an extremely high level of detail.
An advanced digital stage
The Conductor 3X GT's digital interface features a perfectly optimized design, from its XMOS USB receiver to its Qualcomm Bluetooth module. Featuring a custom Thesycon driver, the USB receiver has unparalleled processing power and accuracy, streaming DSD512 and 32bit 768kHz PCM audio signals with ease. The Qualcomm CSR8675 Bluetooth receiver supports the high-resolution aptX HD and LDAC transmission codecs. It pushes Bluetooth playback beyond CD quality and ease of use to its highest level.
Pn addition, the all-new OLED display and neat interface provide an intuitive user experience. Its solid red aluminum knob provides delicate and precise volume control.
An oversized power supply
The beating heart of the Conductor 3X GT is 5 sets of Burson Max Current power supplies. These MCPS are pushed to the limits of their potential to provide powerful and responsive amplification. The heat emitted by the components is efficiently dissipated by the optimized enclosure and the on-board active cooling using an extremely quiet fan from Noctua.
Differential audio circuits
Vivid V6 discrete PDUs have an excellent reputation for outstanding performance. The Conductor 3X GT uses six Vivid PDOs in its fully differential output stage, allowing it to achieve incredible transparency.
Product typeDAC
Headphone amplifier
Inputs2x Balanced XLR line input
2x Single-ended RCA line input
1x USB-C
1x Optical Toslink
1x Coaxial
Bluetooth 5.0
Outputs1x Balanced stereo XLR line output
1x Single-ended stereo RCA line output
1x Subwoofer output (RCA)
1x Single-ended Jack 6.35mm headphone output
1x Balanced XLR headphone output
Bluetooth version5.0
Bluetooth chipCSR8675
Bluetooth codecaptX HD
Input impedance40kΩ
Frequency response0-58kHz ±1dB
THD< 0.0015%
Output impedanceHeadphone amplifier: 0.5Ω
Pre-Out / DAC : 1Ω / 25Ω
Channels separation142dB @ 1kHz
135dB @ 20kHz
THD+N0.0005% @ 1kHz, 0dBFS
Supported sampling ratesCoaxial / Optical : PCM up to 24bit 192kHz
USB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DoP512
XLR headphone output power10W @ 16Ω
8W @ 32Ω
3.8W @ 100Ω
1.3W @ 150Ω
640mW @ 300Ω
RCA headphone output power5W @ 16Ω
4W @ 32Ω
1.9W @ 100Ω
650mW @ 150Ω
320mW @ 300Ω
Dimensions255 x 270 x 70mm
Weight≈ 5kg
ColorGray
Package1x Burson Audio Conductor 3X GT
1x Remote control
1x Power cable
1x USB cable
1x Power supply 24V 5A
Input
  • Bluetooth
  • Optical
  • RCA
  • SPDIF
  • USB
  • XLR
Output
  • Jack 6.35mm
  • RCA
  • Subwoofer
  • XLR
DAC / ADC Chip
  • ES9038Q2M
Max sampling rate
  • 768kHz
  • DSD512
Color
  • Gray
Class
  • Class A / AB
Networking
  • No
Remote Control
  • No
excellent DAC - pré ampli et ampli casque
Que du bonheur dans l'écoute à partir de toutes les fonctions de cet appareil. Très bon ampli casque avec mon casque Audeze LC2.
DAC très précis dans la restitution de la scène sonore, de l'étendue du spectre sonore, de la dynamique et de la justesse des timbres. Il est relié en XLR à un ampli V70E Octave pour une lecture HI RES sur Qobuz via Bluesound.
This review has been posted for BURSON AUDIO CONDUCTOR 3X GT DAC 2x ES9038 Class A Headphone Amplifier 10W Bluetooth 5.0 32bit 768kHz DSD512
The Burson Audio Conductor 3X GT, a DAC and headphone amplifier combo, takes Burson's unique sound quality a step further with a new output...
