BURSON AUDIO CONDUCTOR GT4 STANDARD VERSION DAC Headphone Amplifier
Burson Audio's Conductor GT4 is a DAC and amplifier for headphones. The direct successor to the Conductor GT3, this new model benefits from the technological base that made its predecessor such a success, while offering a new architecture using 6 Max Current power supply modules and 7 SP noise filtering modules. This architecture enables the integration of one DAC chip per channel, making the Conductor GT4 a symmetrical DAC capable of converting signals up to PCM 32 bit 768kHz and DSD 512. The standard version is equipped with the brand's SP1 power supply modules and Vivid V6 OPA.
By buying this product you get 289 loyalty points
Reference : 19818
2 899,00 €tax incl.
2 415,83 € tax excl.
Burson Audio Conductor GT4 Version Standard DAC 2x ES9038 Class A Headphone Amplifier 10W Bluetooth 5.0 32bit 768kHz DSD512
Burson Audio Conductor GT4 : 3/4 view
Burson Audio's Conductor GT4 is a DAC and headphone amplifier. The direct successor to the Conductor GT3, this new model benefits from the technological base that made its predecessor such a success, while offering a new architecture using 6 Max Current power supply modules and 7 SP noise filtering modules. This architecture enables the integration of one DAC chip per channel, making the Conductor GT4 a balanced DAC capable of converting signals up to PCM 32bit 768kHz and DSD512. The standard version is equipped with the brand's SP1 power supply modules and Vivid V6 OPA.
Burson Audio Conductor GT4 : Key features
Burson Audio Conductor GT4  10W Class A output power
Thanks to the modularity offered by the Max Current modules used, a significant amount of space has been saved in the design of the Conductor GT4, making it possible to integrate the Soloist Voyager's independently powered output stage. As a result, the Conductor GT4 boasts a pure Class A output power of 10 W, delivering a sound as powerful as it is accurate.
Conductor GT4 : à la verticale
Conductor GT4 : puce DAC ESS9038
Burson Audio Conductor GT4: ESS9038 Dual DAC
The digital/analogue conversion stage of the Conductor GT4 is entrusted to two ESS9038 DAC chips. Each of these chips is assigned to a channel and powered independently, eliminating crosstalk and achieving finer detail. Thanks to these high-end DAC chips, the Conductor GT4 is capable of converting signals up to PCM 32bit 768kHz and DSD512.
Burson Audio Conductor GT4: Outstanding connectivity
When designing the Conductor GT4, the emphasis was on its connectivity. In order to receive a good quality signal in the most versatile way possible, a number of choices have been made. Firstly, the inclusion of a USB XMOS interface means that PCM 768kHz and DSD 512 are supported via USB-C. You can also enjoy a Bluetooth 5.0 connection that supports aptX Low Latency and aptX HD codecs thanks to the implementation of a Qualcomm CSR8675 chip.
Burson Audio Conductor GT4: Silent power supply
To power its various modules as quietly as possible, the Conductor GT4 relies on its SP1 modules. These modules, developed in-house by the brand, have an incomparable noise filtering capacity, with a noise level of just 40uV. Using these modules ensures crystal-clear sound without any distortion or sound artefacts linked to the power supply.
Conductor GT4 : Module d'alimentation SP
Conductor GT4 : Sortie Subwoofer
Burson Audio Conductor GT4: Headphone output + Subwoofer
In addition to the classic 3.5mm jack, 6.35mm and 4-pin XLR headphone outputs, the Conductor GT4 also features a subwoofer output, allowing you to enjoy your tracks through headphones while benefiting from the experience that a subwoofer can offer.
Product typeDAC
Headphone amplifier
Inputs2x Balanced XLR line inputs
2x Single-ended RCA line input
1x USB-C
1x Optical Toslink
1x Microphone input
Bluetooth 5.0
Outputs1x Balanced stereo XLR line output
1x Single-ended stereo RCA line output
1x Subwoofer output (RCA)
1x Single-ended 3.5 mm headphone output
1x Single-ended 6.35 mm headphone output
1x Balanced XLR headphone output
Bluetooth version5.0
Bluetooth chipCSR8675
Bluetooth codecaptX
aptX Low Latency
aptX HD
AAC
SBC
Input impedance40kΩ
Frequency response0-58kHz ±1dB
Total harmonic distortion (THD)< 0.0015%
Output impedanceAmplificateur casque : 0.5Ω
Pre-Out / DAC : 1Ω / 25Ω
Channels separation143dB @ 1KHz
136 dB @ 20KHz
Total harmonic distortion more noise (THD+N)0.0005% @ 1KHz, 0dBFS
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
XLR headphone output power10W @ 16Ω
5W @ 32Ω
3W @ 100Ω
2W @ 150Ω
1W @ 300Ω
Jack headphone output power5W @ 16Ω
2.5W @ 32Ω
1.5W @ 100Ω
1W @ 150Ω
500mW @ 300Ω
Signal to Noise Ratio (SNR)96dB @ 16Ω
98dB @ 32Ω
95dB @ 100Ω
96dB @ 150Ω
96dB @ 300Ω
Dimensions255 x 270 x 70mm
Poids5kg
ColorSilver
Package1x Conductor GT4 Standard Version
1x Standard Power Supply Unit
InputXLR
OutputSubwoofer
OutputJack 3.5mm
OutputJack 6.35mm
DAC / ADC ChipES9038PRO
Max sampling rate768kHz
Max sampling rateDSD512
ColorSilver
ClassClass A / AB
Remote ControlYes
BURSON AUDIO CONDUCTOR GT4 STANDARD VERSION DAC 2x ES9038 Class A Headphone Amplifier 10W Bluetooth 5.0 32bit 768kHz DSD512
Burson Audio's Conductor GT4 is a DAC and amplifier for headphones. The direct successor to the Conductor GT3, this new model benefits from...
