By buying this product you get 199 loyalty points
The 9I-92SA III from CEN.GRAND, known as the "Golden Trush", is a versatile device that performs the functions of DAC, headphone amplifier and pre-amplifier. As a high-end product, it incorporates many high-quality features, such as two ESS ES9038PRO DAC chips that can operate in parallel on 8 channels, and an XU208 + FPGA USB interface using an isolation system to suppress noise from any source.
The CEN.GRAND 9I-92SA III is an excellent, high-performance and functional headphone amplifier, with four output modes to suit all types of headphones. The Golden Trush delivers clear, rich and detailed sound reproduction.
Key points :
Four output modes let you select the one that best suits your listening preferences or the characteristics of your headphones. Normal mode is for low-impedance headphones and earphones, and BTL mode for high-impedance headphones. Parallel mode is effective for medium-impedance headphones, increasing driving force but not gain. Finally, Active Ground mode, which brings a stronger sense of harmonics, is particularly suited to listening to vocals or stringed instruments, thanks to the simulation of a "virtual GND". This last mode offers a softer, warmer listening experience.
The technology used in the headphone amplification circuit is fairly simple, but the extremely fine-tuned settings resulting from CEN.GRAND's know-how and experience deliver a clear, delicate sound balance. CEN.GRAND's aim here is to provide a headphone listening experience worthy of a Hifi system.
CEN.GRAND's Golden Trush features two ES9038Pro DAC chips operating in parallel on 8 channels. These not only support high-resolution files, but also deliver superb sound quality.
Within your source device, such as a computer, there may be numerous decoupled power supplies generating noise that is harmful to analog circuits. That's why CEN.GRAND has equipped the 9I-92SA III with USB interface isolation technology to block any noise coming from your source device. Isolating this noise significantly improves the purity of the sound signal. On the FGPA side, the code manages data isolation, clock distribution and DoP format decoding.
Equipped with an LPF (low-pass filter) and a high-performance AOP2604, the OPA amplifier circuit delivers a clean audio signal. The volume control chip, a PGA2311, is MCU-controlled. The volume range is -70db to 0db.
1 | XLR stereo input |
2 | RCA stereo input |
3 | XLR Stereo output |
4 | RCA stereo output |
5 | Toslink optical input |
6 | Coaxial input |
7 | AES/EBU input |
8 | USB-B input |
9 | Power switch / Power supply socket |
Product type | DAC Headphone amplifier Preamplifier |
Inputs | 1* Balanced stereo XLR 1* Single-ended stereo RCA 1* AES/EBU 1* Optical Toslink 1* Coaxial 1* USB-B |
Outputs | 1* Single-ended stereo RCA 1* Balanced stereo XLR 1* Balanced XLR 4-pin headphone output 1* Single-ended Jack 6.35mm headphone output |
Supported sampling rates | SPDIF (coaxial, optical, AES/EBU): PCM up to 24bit 192kHz, DSD64 (DoP) USB-B: PCM up to 32bit 384kHz, native DSD up to DSD512 |
Dynamic range | 115dB |
SNR | 115dB (A-weighted) |
Frequency response | ±0.4 dB (20-20KHz A-weighted) |
THD+N | -102dB (fs=96KHz /10KHz A-weighted) |
Pre-level gain | 4db (volume = 0db) |
Output power | 2.1W (0.9% distorsion 33Ω) 0.5W (0.027% distorsion 600Ω) |
Screen |
Power supply | AC 220V-230V 50-60HZ (6.3A fuse) |
Color | Black |
Dimensions (W*H*D) | 320*100*310mm |
Gross weight | 7.3kg |
Net weight | 6.2kg |
Package | 1x CEN.GRAND 9I-92SA III Golden Trush 1x IR Remote control |
Input | USB |
Input | XLR |
Input | Optical |
Input | RCA |
Input | SPDIF |
Input | AES/EBU |
Output | RCA |
Output | Jack 6.35mm |
Output | XLR |
DAC / ADC Chip | ES9038PRO |
Max sampling rate | DSD512 |
Max sampling rate | 384kHz |
Color | Black |
Class | N/A |
Networking | No |
Remote Control | Yes |
