CEN.GRAND DSDAC 1.0 DAC FPGA XMOS XU208 Femtosecond Clock 32bit 384KHz DSD512
Created by CEN.GRAND, the DSDAC 1.0 is a DAC based on DSD technology. It is different from most DACs on the market, in fact the DSDAC 1.0 can increase the frequency of any digital input signal, including PCM and DSD64, up to DSD 1024. If the signal is equal to or greater than the DSD128 you can also choose not to increase the frequency of the signal.
The DSDAC 1.0 does not integrate a conventional dac chip but an optimized FPGA for an efficient reclocking system and discrete components for digital processing.
By buying this product you get 249 loyalty points
Reference : 17661
2 490,00 €tax incl.
2 075,00 € tax excl.
Shipping date: 03-04-2025.
CEN.GRAND DSDAC 1.0
CEN.GRAND DSDAC 1.0 DAC PCM 384KHz DSD512 Argent
It has 3 advanced audio technologies:
  • High precision DSD frequency algorithm
  • Direct synchronous clock.
  • Clock blocking technology.
Synchronous direct clock technology
The DSDAC 1.0 is equipped with an integrated femtosecond clock. Its signal is sent directly, without intermediate conversion and without going through the frequency divider, to the shift register. This allows the performance of the femtosecond clock to reflect directly on the analog outputs of the DAC.
An FPGA takes care of the synchronization of the audio signals. In short, it makes it possible to offer a more precise and transparent sound reproduction, while drastically reducing noise.
The DSDAC 1.0 is able to block the clock signal of devices transmitting an audio signal upstream, your CD player for example, so the DAC only uses its internal clock. This technology solves the clock problem often seen in digital audio.
XMOS XU208 custom USB interface
The USB interface is capable of receiving native DSD source code. The SPDIF inputs can receive DSD64 in DoP mode.
Product typeDAC
Inputs1* SPDIF AES
1* SPDIF Optical Toslink
1* SPDIF Coaxial
1* SPDIF BNC
1* USB-B
Outputs1* Single-ended stereo RCA
1* Balanced stereo XLR
Supported samples ratesSPDIF: PCM 24bit 192kHz, DoP64 (AES, optical fiber, coaxial, BNC)
USB-B: PCM 32bit 384KHz, Native DSD up to DSD512
Output levelsXLR: 5.0V RMS
RCA: 2.5V RMS
Volume control range-70dB ~ 0dB
Dimensions430*360*100mm
Net weight10.6kg
Gross weight13.3Kg
ColorSilver
Package1* DSDAC 1.0
InputBNC
InputAES/EBU
DAC / ADC ChipNC
Max sampling rateDSD1024
Max sampling rate384kHz
ColorSilver
Remote ControlN/A
Created by CEN.GRAND, the DSDAC 1.0 is a DAC based on DSD technology. It is different from most DACs on the market, in fact the DSDAC 1.0 can...
