By buying this product you get 599 loyalty points
The DSDAC 1.0 DELUXE is a DAC based on DSD technology. It is different from most DACs on the market. Indeed, the DSDAC 1.0 DELUXE can increase the frequency of any digital input signal, including PCM and DSD64, up to DSD1024. If the signal is equivalent or higher at DSD128 you can also choose not to increase the frequency of the signal.
The DSDAC 1.0 DELUXE does not integrate a conventional DAC chip but an optimized FPGA for an efficient reclocking system and discrete components for digital processing.
It has 3 advanced audio technologies:
The DELUX model compared to the standard model has an optimized clock system and major modifications have been made to the circuit.
The Deluxe model can also be used as a preamp. It can provide a maximum gain of 5dB for the input signal. In preamp mode, the DAC function is inactive.
DAC 1.0 DELUXE
DAC 1.0 STANDARD
Clock system
Improved femtosecond clock system,
RMS jitter is as low as 100fs
Femtosecond clock system
Circuitry
Advanced digital and analog circuitry
Standard circuits without advanced components
Power system
Optimized system:
independent transformers
for the digital and analog parts
Single transformer
The DSDAC 1.0 DELUXE is equipped with an integrated femtosecond clock. Its signal is sent directly, without intermediate conversion and without going through the frequency divider, to the shift register. This allows the performance of the femtosecond clock to reflect directly on the analog outputs of the DAC.
An FPGA takes care of the synchronization of the audio signals. In short, it makes it possible to offer a more precise and transparent sound reproduction, while drastically reducing noise.
The DSDAC 1.0 DELUXE is able to block the clock signal of devices transmitting a sound signal upstream, your CD player for example, so the DAC only uses its internal clock. This technology solves the clock problem often seen in digital audio.
The USB interface is capable of receiving native DSD signal. The SPDIF inputs can receive DSD64 in DoP mode.
Product type | DAC |
Digital inputs | 1* SPDIF AES 1* SPDIF Optical Toslink 1x SPDIF Coaxial 1x SPDIF BNC 1x USB-B |
Analog inputs | 1* Single-ended stereo RCA (pre-amp) 1* Balanced stereo XLR (pre-amp) |
Outputs | 1* Single-ended stereo RCA 1x Balanced stereo XLR |
Supported sample rates | SPDIF: PCM up to 24bit 192kHz, DoP64 (AES, optical, coaxial, BNC) USB-B: PCM up to 32bit 384KHz, Native DSD up to DSD512 |
Output levels | XLR: 6.2 V RMS RCA: 3.51 V RMS |
Volume control range | -65dB ~ 4dB |
Dimensions | 430*360*100mm |
Net weight | 11.5kg |
Gross weight | 13.8Kg |
Color | Silver |
Package | 1* DSDAC 1.0 DELUXE 1* USB Cable USB-A to USB-B 1m 1* Remote control 1* Power cable |
Input | USB |
Input | XLR |
Input | Optical |
Input | AES/EBU |
Input | RCA |
Input | SPDIF |
Input | BNC |
Output | RCA |
Output | XLR |
DAC / ADC Chip | NC |
Max sampling rate | 384kHz |
Max sampling rate | DSD1024 |
Color | Silver |
Networking | No |
Remote Control | Yes |
