CYP DCT-37 HDMI DAC / Preamplifier / Headphone Amplifier HDMI SPDIF USB RCA 32bit / 384khz
The CYP DCT-37 is a true Swiss Army Knife dedicated to audio and video. It can control many digital and analog sources and then output to a wide variety of digital and analog devices.
By buying this product you get 79 loyalty points
Reference : 13191
799,00 €tax incl.
665,83 € tax excl.
CYP DCT-37
DAC-ADC / Preamplifier / Headphone amplifier 4x HDMI SPDIF USB RCA 32bit / 384khz
CYP DCT-37 DAC-ADC / Préamplificateur / Amplificateur Casque 4x HDMI SPDIF USB RCA 32bit / 384khz
The CYP DCT-37 is a true Swiss Army Knife dedicated to audio and video. It can control many digital and analog sources and then output to a wide variety of digital and analog devices. With support for video up to 6G in UHD (Ultra High Definition) and audio with sampling rates up to 32bit 384kHz, this versatile tool also delivers performance.
The DCT-37 also supports 2-channel LPCM audio, namely uncompressed PCM, HDMI, USB audio 2.0 as well as coaxial and optical inputs and outputs. CYP also integrates a DAC and an ADC, for a Digital to Analog and Analog to Digital conversion. The USB of the DCT-37 decodes the DoP (DSD via PCM frames), offering much higher sample rates and lower distortion.
There is also a headphone amplifier with unbalanced 6.35 jack and balanced XLR output for high audio quality. The 3.5mm analog input and stereo RCA output benefit from PLL mounting and a precision clock for very low jitter and pure sound reproduction.
Finally, there is a beautiful OLED screen with controls directly on the device or on the supplied IR remote control, allowing simple and intuitive control of the DCT-37.
Connection diagram
Diagram : Front panel
CYP DCT-37 Schéma façade avant
1Jack 3.35mm Headphone Output
2Jack 3.5mm Line input
3Status LED (Red when powered, green when powerd on)
4IR Receiver
5OLED Display
6Menu button / Volume control
Diagram : Rear panel
CYP DCT-37 Schéma façade arrière
15V DC Power supply
24x HDMI inputs
3HDMI output
4Coaxial input
5Optical input
6USB input
7Coaxial output
8Optical output
9RCA Output
10XLR Balanced output
Diagram : Top panel
1Power ON/OFF
2Mute
Diagram : Remote control
1Power ON/OFF
2Menu
3Return
4Volume +/-
5Mute
6HDMI input
7Coaxial input
8Optical input
9USB input
10Line input
Video bandwidth600MHz 18Gbps
Inputs4x HDMI
1x Coaxial
1x Optical
1x USB-B
1x Jack 3.5mm
Outputs1x HDMI
1x Coaxial
1x Optical
2x RCA
1x XLR Balanced
1x Jack 6.35mm
HDMI resolutionsVGA-WUXGA (RB), 408i-1080p @ 24/50/60Hz, 4K @ 24/25/30Hz, 4K @ 50/60Hz (YUV420)
Digital Audio I/O FormatLPCM 2Ch
XLR Balanced Audio I/O Level4V RMS +/-0.2
Headphone impedance16 - 600 Ohm
Power supply5V 3A DC (included)
Measurments
Input Level / FreqOutputOutput levelTHD+NFrequency responseSNR > 90dBCrosstalk < -90dB
HDMI 2Vrms / 1kHzHDMI (Ext Audio)-0.0000.00001%+/-1dBFS> 141dB< -110dB
Optical 2Vrms / 1kHzOptical-0.0000.00001%+/-1dBFS> 141dB< -164dB
Coaxial 2Vrms / 1kHzCoaxial-0.0000.00001%+/-1dBFS> 141dB< -163dB
Analog line 2Vrms / 1kHzAnalogique (L/R)1.8640.001%+/-1dBFS> 110dB< -164dB
USB 2Vrms / 1kHzAnalog (XL/XR)3.9220.001%+/-1dBFS> 111dB< -118dB
Housing materialAluminium
Dimensions223 x 145 x 48mm
Weight886g
ColorNoir
Consumption14.5W
InputHDMI
InputJack 3.5mm
OutputHDMI
OutputCoaxial SPDIF
OutputOptical Toslink
DAC / ADC ChipNC
Max sampling rate384kHz
Remote ControlYes
Very satisfying DAC with unique features
I am very happy with this exellently sounding DAC and its rather exclusive HDMI features. If you are happy with stereo sound, but fed up with downsampling optical outputs of regular TV's and Videoplayers, this is the right choice.
This review has been posted for CYP DCT-37 HDMI DAC / Preamplifier / Headphone Amplifier HDMI SPDIF USB RCA 32bit / 384khz
The CYP DCT-37 is a true Swiss Army Knife dedicated to audio and video. It can control many digital and analog sources and then output to a wide...
