I am very happy with this exellently sounding DAC and its rather exclusive HDMI features. If you are happy with stereo sound, but fed up with downsampling optical outputs of regular TV's and Videoplayers, this is the right choice.
By buying this product you get 79 loyalty points
DAC-ADC / Preamplifier / Headphone amplifier 4x HDMI SPDIF USB RCA 32bit / 384khz
The CYP DCT-37 is a true Swiss Army Knife dedicated to audio and video. It can control many digital and analog sources and then output to a wide variety of digital and analog devices. With support for video up to 6G in UHD (Ultra High Definition) and audio with sampling rates up to 32bit 384kHz, this versatile tool also delivers performance.
The DCT-37 also supports 2-channel LPCM audio, namely uncompressed PCM, HDMI, USB audio 2.0 as well as coaxial and optical inputs and outputs. CYP also integrates a DAC and an ADC, for a Digital to Analog and Analog to Digital conversion. The USB of the DCT-37 decodes the DoP (DSD via PCM frames), offering much higher sample rates and lower distortion.
There is also a headphone amplifier with unbalanced 6.35 jack and balanced XLR output for high audio quality. The 3.5mm analog input and stereo RCA output benefit from PLL mounting and a precision clock for very low jitter and pure sound reproduction.
Finally, there is a beautiful OLED screen with controls directly on the device or on the supplied IR remote control, allowing simple and intuitive control of the DCT-37.
1 | Jack 3.35mm Headphone Output |
2 | Jack 3.5mm Line input |
3 | Status LED (Red when powered, green when powerd on) |
4 | IR Receiver |
5 | OLED Display |
6 | Menu button / Volume control |
1 | 5V DC Power supply |
2 | 4x HDMI inputs |
3 | HDMI output |
4 | Coaxial input |
5 | Optical input |
6 | USB input |
7 | Coaxial output |
8 | Optical output |
9 | RCA Output |
10 | XLR Balanced output |
1 | Power ON/OFF |
2 | Mute |
1 | Power ON/OFF |
2 | Menu |
3 | Return |
4 | Volume +/- |
5 | Mute |
6 | HDMI input |
7 | Coaxial input |
8 | Optical input |
9 | USB input |
10 | Line input |
Video bandwidth | 600MHz 18Gbps |
Inputs | 4x HDMI 1x Coaxial 1x Optical 1x USB-B 1x Jack 3.5mm |
Outputs | 1x HDMI 1x Coaxial 1x Optical 2x RCA 1x XLR Balanced 1x Jack 6.35mm |
HDMI resolutions | VGA-WUXGA (RB), 408i-1080p @ 24/50/60Hz, 4K @ 24/25/30Hz, 4K @ 50/60Hz (YUV420) |
Digital Audio I/O Format | LPCM 2Ch |
XLR Balanced Audio I/O Level | 4V RMS +/-0.2 |
Headphone impedance | 16 - 600 Ohm |
Power supply | 5V 3A DC (included) |
Measurments | ||||||
Input Level / Freq | Output | Output level | THD+N | Frequency response | SNR > 90dB | Crosstalk < -90dB |
HDMI 2Vrms / 1kHz | HDMI (Ext Audio) | -0.000 | 0.00001% | +/-1dBFS | > 141dB | < -110dB |
Optical 2Vrms / 1kHz | Optical | -0.000 | 0.00001% | +/-1dBFS | > 141dB | < -164dB |
Coaxial 2Vrms / 1kHz | Coaxial | -0.000 | 0.00001% | +/-1dBFS | > 141dB | < -163dB |
Analog line 2Vrms / 1kHz | Analogique (L/R) | 1.864 | 0.001% | +/-1dBFS | > 110dB | < -164dB |
USB 2Vrms / 1kHz | Analog (XL/XR) | 3.922 | 0.001% | +/-1dBFS | > 111dB | < -118dB |
Housing material | Aluminium |
Dimensions | 223 x 145 x 48mm |
Weight | 886g |
Color | Noir |
Consumption | 14.5W |
Input |
Output |
Color |
DAC / ADC Chip |
Max sampling rate |
Networking |
Remote Control |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Stefan S.
