EVERSOLO DAC-Z6 DAC 2x ES9068 XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA
The EverSolo DAC-Z6 is a powerful DAC based on a neat technical structure. It embeds high-end components with notably two ESS ES9068AS digital/analog conversion chips and a XMOS XU316 USB interface allowing it to support high resolution audio streams and to provide a clear and detailed sound reproduction. The DAC-Z8 also offers a wide range of features making it a versatile and efficient device.
Reference : 17133
469,00 €tax incl.
390,83 € tax excl.
EverSolo DAC-Z6
DAC 2x ES9068AS XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA
EverSolo DAC-Z6 DAC ES9068 XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA
EverSolo DAC-Z6 DAC ES9068AS XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA
ES9068AS Dual DAC
The heart of the DAC-Z6, its digital-to-analog conversion stage, is equipped with a pair of ESS ES9068AS chips. These ensure low distortion and noise for a seamless high-fidelity music experience. This balanced structure also greatly reduces interference that could alter the integrity of the audio signal. In addition, the DAC-Z6's audio circuitry is specifically calibrated to deliver its full potential.
The USB input of the DAC-Z6 is combined with an XMOS XU316 interface, which is able to process audio data quickly and efficiently for optimal signal transmission. This chip also supports high-resolution streams up to PCM 32bit 768kHz and DSD512 Native, as well as MQA files.
MQA
The EverSolo DAC-Z6 supports the decoding of MQA (Master Quality Authenticated) files from its USB, Toslink optical and coaxial inputs. This format allows to enjoy a sound quality as close as possible to the original studio recording.
High precision clocks
The DAC-Z6 is equipped with two very high precision clocks on the frequencies 45.1584MHz and 49.152MHz. These allow you to enjoy a high quality decoding, ensuring a very low jitter for a detailed and accurate sound.
Amplifier circuit & Balanced preamp output
The DAC-Z6's analog audio circuitry is fully balanced and uses multiple OPAs. The XLR, RCA and headphone outputs are all processed by a balanced differential amplifier circuit ensuring low noise and improved channel separation. The high-fidelity preamplifier circuitry provides precise and efficient volume control.
Bluetooth 5.0
In addition to full connectivity, the DAC-Z6 features a Qualcomm QCC5125 Bluetooth 5.0 receiver, making it possible to stream music remotely from a smartphone or tablet, for example, while supporting the high-resolution aptX HD and LDAC transmission codecs for high-quality wireless playback.
Digital filters
The EverSolo DAC-Z6 provides 3 sets of digital filters, each with different sound characteristics. These allow you to adapt the sound reproduction of the device according to your listening preferences and your audio system.
Low ripple power supply stage
A low-noise power supply stage and capacitor filter have been specially optimized for the DAC-Z6. They provide a clean, interference-free electrical signal to all of the unit's audio circuits for rich, accurate sound reproduction.
A powerful headphone amplifier
The DAC-Z6's headphone amplifier also performs very well and is capable of providing comfortable power to accompany headphones with impedance from 16 to 300Ω without difficulty. This one also has a two-step gain control to accommodate both demanding headphones and more sensitive earphones.
Control app
The DAC-Z6 can be controlled via the free EverSolo Control App available on Android and iOS. The latter allows access to the vast majority of the settings available on the device.
Color Screen & Intuitive Interface
The front panel of the DAC-Z6 features a beautiful 3" color LCD screen. This one displays an ergonomic and intuitive interface allowing you to access all the functions and parameters of the DAC.
Multi-function button
The DAC's multi-function knob can be used to control the volume level, navigate menus, select a source or output, change filters, change the display, etc. It allows full control of the device in a convenient way.
Aluminum frame
The EverSolo DAC-Z6 is dressed in a beautiful, sturdy aluminum chassis that has been precision-machined by CNC (numerical control). It offers a modern and sober design, allowing it to be easily integrated into any audio system.
Product typeDAC
InputsBluetooth 5.0
1* USB-B
1* USB-C
1* Optical Toslink
1* Coaxial
Outputs1* Balanced stereo XLR
1* Single-ended RCA
1* Jack 6.35mm headphone output
DAC chipES9068AS
USB interfaceXMOS XU316
OPA8* OPA1612
Bluetooth receiverQualcomm QCC5125
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, MQA
Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64, MQA
Supported Bluetooth codecsSBC
AAC
aptX
aptX LL
aptX HD
LDAC
ScreenLCD 3"
Control app
Recommended headphone impedance16-300Ω
XLR output performances
Output level4.1Vrms @ 0dBFS
THD+N (A-Weighted)0.000094% @ 1kHz (-120dB @ 1kHz)
THD+N (No-Weighted)0.000117% @ 1kHz (-118dB @ 1kHz)
Noise (No-Weighted)< 3µVrms
SNR (No-Weighted)125dB @ 1kHz
Frequency response20Hz-20kHz (±0.15dB)
Crosstalk-123dB @ 1kHz
Dynamic range (No-Weighted)125dB @ 1kHz
RCA output performances
Output level2.1Vrms @ 0dBFS
THD+N (A-Weighted)0.000116% @ 1kHz (-118dB @ 1kHz)
THD+N (No-Weighted)0.000135% @ 1kHz (-117dB @ 1kHz)
Noise (No-Weighted)< 2.5µVrms
SNR (No-Weighted)121dB @ 1kHz
Crosstalk-118dB @ 1kHz
Dyanmic range (No-Weighted)121dB @ 1kHz
Headphone output performances (Low gain mode)
Output level1.2Vrms @ 0dBFS
Output power45mW @ 32Ω
THD+N (A-Weighted)0.00028% @ 1kHz (-111dB @ 1kHz)
THD+N (No-Weighted)0.00031% @ 1kHz (-110dB @ 1kHz)
Noise (No-Weighted)< 3.5µVrms
SNR (No-Weighted)114dB @ 1kHz
Dynamic range (No-Weighted)114dB @ 1kHz
Headphone output performances (High gain mode)
Output level2.8Vrms @ 0dBFS
Output power26mW @ 300Ω
THD+N (A-Weighted)0.00014% @ 1kHz (-117dB @ 1kHz)
THD+N (No-Weighted)0.00016% @ 1kHz (-116dB @ 1kHz)
Dynamic range (No-Weighted)121dB @ 1kHz
Supply voltage110~240VAC 50/60Hz
Consumption9W
Dimensions (L*P*H)270*187*50mm
ColorSilver
Package1* EverSolo DAC-Z6
1* Remote control
1* Power cable
OutputJack 6.35mm
DAC / ADC ChipES9038PRO
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
Remote ControlYes
5 reviews
Popularité méritée
Dac Z6 reçu rapidement(comme toujours
This review has been posted for EVERSOLO DAC-Z6 DAC 2x ES9068 XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA
15h. D' écoute..
Tout simplement excellent dac pour le tarif.
Scène plus large et définie, hauteur, profondeur, tridimension, diaphonie, superbe timbre, respecte la musique et la restitué avec beaucoup de charme. Je recommande l' eversolo z6 sans réserve !
Premières impressions
Je l'écoute pour la première fois et, pas mal du tout..
Outre l'aspect physique, bien conçu et qualitatif, ce dac est adjoint a un ampli a Tube kt88, fezz audio titania via RCA.
Premier test avec qobuz en hires. Très neutre, droit mais nuancé, détaillé mais pas analytique. Pas de souffle apparent, fond assez sombre.
Diaphonie respectable mais pas spectaculaire. Il n'en fait pas trop mais fait ce qu'il faut.
En bluetooth, il est tres très bon !!!
Simple d'utilisation avec ou sans l' appli.
Le rapport performance/prix est excellent. Reste plus qu'à a essayer en xlr.....
Très bien
Packaging exceptionnel tant au niveau esthétique que fonctionnel. Appareil de très bonne facture livré avec un bon câble secteur ainsi qu’un câble USB de qualité. La télécommande en plastique dénote un peu mais comme on bénéficie d’une application smartphone bien pratique, on ne l’utilise pas. Le panel de connections est particulièrement complet. La qualité sonore me paraît au rendez-vous avec une scène sonore assez étendue.
PRELIMINAIRES
On va faire monter la température en douceur!
Le premier contact avec le produit est très positif et surprenant.
La présentation du conditionnement est vraiment premium.
Ok, rien à voir avec les qualités musicales du produit mais un constructeur qui pousse la présentation et l'emballage de son produit à ce niveau ne peut pas prendre le risque de livrer une "bouse" au final.
De toute façon l'impression positive initiale concernant l'emballage se poursuit avec la prise en main du produit.
Assemblage, matériaux utilisés, la qualité perçue est vraiment d'un très bon niveau.
Et le son dans tout çà? J'avais bien dit que c'était des préliminaires. Juste 3 heures d'écoute qui se finissent l'air un peu bête avec un large sourire sur les lèvres, la tête encore dans un nuage musical dont l'espace sonore a augmenté de volume en re définissant la localisation spatiale des différents interprètes. De la matière, de l'épaisseur mais avec beaucoup d'air entre les notes pas cet effet maigrelet et éthéré qu'on entend malheureusement trop souvent. Combien d'entre nous ,pourtant satisfaits de notre système, reconnaissent devoir pousser le volume pour avoir cette sensation de corps, de matière, d'épaisseur. Avec le Z6 c'est bien la première fois que toute ces qualités se retrouvent dès les premiers db. Et si l'envie vous prend de pousser le volume pas de crainte de tassement ni d'agressivité ou de fatigue.
Très belle excursion du registre grave à la fois tendu et nuancé et montée des aigus sans crispation et semblant monter très haut. Le médium sonne vrai et place les interprètes quasi dans votre pièces sans faire trop d'effort. Au final une belle exploration de la bande passante assez linéaire et neutre mais pas sans émotion ni musicalité.
Pour le moment ce qui m'embête le plus avec le Z6 c'est que j'avais l'intention de changer l'ampli mais il m'a enlevé cette envie en me donnant ce que j'attendais de mon système.
Adieu nouvel ampli mais bienvenue à la musique.
Merci Z6 et à Audiophonics qui comme d'habitude par leurs conseils et disponibilité ont fait mouche.
Je conclurai en rappelant que Le Z6 coute moins de 500€ et que tout jugement comporte une part de subjectivité.
Si vous avez compris ça alors oui produit hautement recommandé.
Salutations à toutes et tous.
 (5)
The EverSolo DAC-Z6 is a powerful DAC based on a neat technical structure. It embeds high-end components with notably two ESS ES9068AS...
