FERRUM WANDLA HP DAC Headphone Amplifier
The Ferrum WANDLA HP combines the famous WANDLA DAC with a high-performance headphone amplifier. The latter incorporates the advantages of the WANDLA DAC, such as an ES9038PRO DAC chip and balanced architecture, enabling it to support high-resolution streams up to PCM 32bit 768kHz, DSD256 and MQA. On the headphone amplifier side, we find an IC amplifier with the brand's proprietary balanced architecture, offering a good reserve of output power and a dynamic range extended to 122dB.
By buying this product you get 329 loyalty points
Reference : 20084
3 295,00 €tax incl.
2 745,83 € tax excl.
Ferrum Wandla HP Headphone Amplifier DAC ES9038PRO Balanced I2S HDMI ARC 32bit 768kHz DSD256 MQA
Photo of FERRUM WANDLA HP
The Ferrum Wandla HP combines the famous Wandla DAC with a high-performance headphone amplifier. The latter incorporates the advantages of the Wandla DAC, such as an ESS ES9038PRO DAC chip and balanced architecture, enabling it to support high-resolution streams up to PCM 32bit 768kHz, DSD256 and MQA. On the headphone amplifier side, we find an IC amplifier with the brand's proprietary balanced architecture, offering a good reserve of output power and a dynamic range extended to 122dB. Overall, the Wandla HP's connectivity interface is quite rich, incorporating numerous digital inputs such as USB-C, HDMI ARC, I2S HDMI, SPDIF coaxial, Toslink optical, AES and an analog RCA input. It also has a single-ended RCA and balanced XLR analog outputs, plus a balanced Jack 4.4mm headphone output. To top it all off, a beautiful color touchscreen displays information on current playback, as well as navigating the device's parameters.
Wandla Ferrum key points
  • All-balanced headphone amplifier
  • 122dB dynamic range
  • Output power of 3500mW @ 50 ohms (headphone output)
  • ES9038PRO DAC chip
  • Support for high-resolution sampling rates up to PCM 32bit 768kHz, DSD256 and MQA
  • SERCE: ARM chip optimizes signal flow, includes MQA decoder and digital filters
Ferrum Wandla HP: the ultimate sound experience
This DAC headphone amplifier will delight even the most demanding audiophile thanks to its high-quality components. The ES9038PRO DAC chip, ARM processor, headphone amplifier and IC preamplifier optimize signal processing for a powerful, natural sound.
FERRUM WANDLA HP DAC chip picture
Ferrum power link
Ferrum Wandla HP : Ferrum Power Link (FPL)
Unique FPL power socket design: two wires providing power and two wires providing feedback to ensure a flat voltage at all times. This eliminates the adverse effects of cable resistance by effectively improving transient response. The speed of current delivery to the input of the powered device is considerably improved.
Ferrum Wandla HP: Designed for Hypsos
The Wandla HP is supplied with a carefully selected DC power adapter. However, to get the most out of the Wandla HP, you can connect it to HYPSOS using the proprietary Ferrum Power Link DC power cable (not included).
FERRUM WANDLA HP with HYPSOS power supply
Ferrum Wandla HP overview
FERRUM WANDLA HP overview
The Ferrum Wandla HP has a balanced Jack 4.4mm headphone output. However, an adapter (supplied) allows you to use a Jack 6.35mm.
1Color touchscreen
2IR receiver (remote control)
3Balanced Jack 4.4mm headphone output
4Volume control knob
5Balanced XLR output
6Single-ended RCA output
7RCA input
8AES input
9Coaxial input
10Toslink optical input
11HDMI ARC input
12I2S via HDMI input
13USB-C input
14Trigger
15Ferrum FPL power connector
16DC 5.5/2.5 (24V) jack power connector
Schéma de pin I2S
Product typeDAC / headphone amplifier
DAC chipES9038PRO
ArchitectureBalanced
Inputs1x Stereo single-ended RCA
1x USB-C
1x Coaxial
1x Optical Toslink
1x AES/EBU input
1x HDMI ARC
1x I2S HDMI
Outputs1x Balanced XLR output
1x Single-ended RCA stereo output
1x Balaced 4.4mm jack headphone output
Supported sample ratesUSB-C: PCM 32bit 768kHz, DSD DoP256, DSD512
HDMI ARC: PCM 24bit 192kHz
I2S HDMI: PCM 32bit 768kHz, DSD DoP256, DSD512 (+ PS Audio®)
Coaxial: 24bit 192kHz, DSD DoP64
Optical Toslink: 24bit 96kHz
AES/EBU: 24bit 192kHz, DSD DoP64
MQADecoder and renderer (on all digital inputs)
Vmax RCA input9.5V RMS (2 – 3.5V RMS recommanded)
RCA input impedance47kΩ
Volume controlAnalog with bypass option / digital for DAC operation only
Line output level@ 0dBFS, 1kHz sine 10V RMS balanced, 5V RMS unbalanced
Line output level (RED)@ 0dBFS, 1kHz sine 4V RMS balanced, 2V RMS unbalanced
Frequency responseAnalog input: 10Hz–200kHz +/- 0.1dB
THD (DAC)121dB (0.00009%) THD+N: -115dB (unweighted)
THD (analog input)-123dB @ 2V RMS output
Dynamic rangeAnalog input: 127dB (A-weighted)
Digital inputs: 127dB (A-weighted)
DAC output Crosstalk-120dB pour 1kHz, > -100dB for 20Hz-20kHz
Line output impedanceBalanced: 44Ω
Single-ended: 22Ω
Headphone amplifier Measurements
THD balanced output0.00016% / -116dB, 10mW into 50Ω
0.00020% / -114dB, 100mW into 50Ω
THD unbalanced output0.00022% / -113dB, 10mW into 50Ω
0.00022% / -113dB, 100mW into 50Ω
Output powerBalanced: 3500mW @ 50Ω
Single-ended: 1000mW @ 50Ω
Output impedanceBalanced  : 1Ω
Single-ende: 0.5Ω
Power supply24V DC via DC 5.5/2.5 jack
22-30V DC via proprietary FPL connector
Power consumption13W iddle (with amp powered off)
18W à vide  (with amp powered on)
35W max
Dimensions21.7 x 20.6 x 5cm / 8.6 x 8.1 x 2.0 inch (WxDxH)
Weight1.90 kg / 4.19 lbs
Package1x Ferrum Wandla HP
1x 6.35mm jack to 4.4mm jack adapter
1x Remote control
1x 24V DC power adapter
InputI2S via HDMI
InputHDMI ARC
InputAES/EBU
OutputJack 4.4mm
DAC / ADC ChipES9038PRO
Max sampling rateDSD512
Max sampling rateMQA
Max sampling rate768kHz
ClassN/A
Remote ControlYes
FERRUM WANDLA HP DAC ES9038PRO Headphone Amplifier Balanced I2S HDMI ARC 32bit 768kHz DSD256 MQA
The Ferrum WANDLA HP combines the famous WANDLA DAC with a high-performance headphone amplifier. The latter incorporates the advantages of the...
