FIIO K19 DAC 2x ES9039MSPRO Headphone Amplifier 2x THX AAA-788+ Black
FiiO unveils one of its most sophisticated devices with its K19. The K19 is an ultra-complete, high-performance DAC/headphone amplifier. It features two ES9039MSPRO DAC chips for balanced signal processing and support for high-resolution PCM 32bit 768kHz and DSD512 streams. Two THX AAA-788+ modules handle signal amplification, for maximum output power of up to 8000mW per channel at 32 ohms.
By buying this product you get 139 loyalty points
Reference : 19069
1 390,00 €tax incl.
1 158,33 € tax excl.
FIIO K19 DAC 2x ES9039SPRO Headphone amplifier 2x THX AAA-788+ 32bit 768kHz DSD512 8000mW 32 Ohm Black
FIIO K19 picture
FiiO unveils one of its most sophisticated devices with its K19. The K19 is an ultra-complete, high-performance DAC / headphone amplifier. It features two ES9039SPRO DAC chips for balanced signal processing and support for high-resolution PCM 32bit 768kHz and DSD512 streams. Two THX AAA-788+ modules handle signal amplification, for maximum output power of up to 8000mW per channel at 32 ohms. A further advantage of the FiiO K19 is its comprehensive connectivity, with numerous digital inputs: USB-C, Toslink optical, SPDIF coaxial, but above all an HDMI port and an HDMI e-ARC port. Outputs include 2 digital outputs, Toslink optical and coaxial SPDIF, as well as various analog outputs: stereo balanced XLR line output, 2x stereo RCA line output, 6.35mm headphone output, 4.4mm balanced headphone output and balanced XLR headphone output. Two 3.5mm Trigger IN/Trigger OUT 12V jack ports complete the package, as does an RS232 interface on a USB-C port (for DSP setting). Fiio has opted for an original, aesthetically pleasing case that can be positioned vertically or horizontally, and incorporates a small screen as a control interface.
FIIO K19: two ES9039SPRO DAC chips
The K19 incorporates two DAC chips for balanced audio channel processing. The ES9039SPRO DAC chips are 32bit, 8-channel DAC chips specially designed for professional applications. They enable the FiiO K19 to support high-resolution PCM 32bit 768kHz and native DSD streams up to DSD512. In addition, these DAC chips are combined with two ACCUSILLON AS318-B crystal oscillators to guarantee a perfect clock signal.
ES9039MSPRO DAC chip photo
THX logo
FIIO K19: two THX AAA-788+ amplifier modules
Headphone amplification is provided by two THX AAA-788+ modules, for exceptional output power of up to 8000mW per channel. As a result, the K19 can drive any type of audiophile headphone on the market, whether with 32 or 600 ohms impedance.
FIIO K19: next-generation Bluetooth
The K19 features a Bluetooth chip (receiver/transmitter), enabling it to support the following wireless transmission codecs: SBC, AAC, aptX, aptX HD and LDAC.
Bluetooth logo
FIIO K19: integrated DSP with 31-band EQ
The K19 incorporates an ADI SHARC+ ADSP-21565 DSP from Analog Devices Inc., giving users the benefit of a 31-band parametric equalizer. As a result, the K19's tuning control is extremely precise over a wide range of frequencies. This feature enables the user to adapt the sound to his preferences and the type of music he is listening to.
FiiO K19 : EQ
FIIO K19: dual power supply
A switch allows you to select the power supply mode, either 220V AC mains or 15V DC, to suit various configurations. A grounding switch, also located on the rear of the unit, resolves potential ground loop problems and effectively eliminates noise.
Photo of FIIO K19 power supply connectors
FiiO K19 overview
Diagram of FIIO K19 connectors
1HDMI /HDMI e-ARC input
2Bluetooth antenna
3Ground switch
412V Trigger IN/OUT jack 3.5mm
5RS-232 input via USB-C
6USB-C input
7SPDIF coaxial / optical TOSLINK inputs
8SPDIF coaxial / optical TOSLINK outputs
92x stereo RCA line output
10XLR balanced stereo line output
11220V AC / 15V DC power supply
Technichal characteristics
Product typeDAC / Headphone amplifier
DAC chips2x ES9039SPRO
Amplifier modules2x THX AAA-788+
Inputs1x USB-C
1x Optical Toslink
1x Coaxial SPDIF
1x HDMI
1x HDMI e-ARC
1x RS-232 via USB-C (for DSP setting)
Bluetooth
Outputs1x 6.35mm jack headphone output
1x 4.4mm jack balanced headphone output
1x XLR balanced headphone output
2x RCA stereo output
1x XLR stereo balanced output
1x Toslink optical output
1x Coaxial SPDIF output
Other connectors12V Trigger IN jack 3.5mm
12V Trigger OUT Jack 3.5mm
Bluetooth5.0 Bi-directional
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
Supported sample ratesPCM 32Bit 768kHz, native DSD up to DSD512
Headphone output power2x 8000mW @ 32 ohm
Power supply220V AC or 15V DC
Package1x FiiO K19
1x Power adapter
InputHDMI
InputHDMI ARC
InputRS-232
OutputOptical Toslink
OutputJack 6.35mm
OutputCoaxial SPDIF
OutputJack 4.4mm
DAC / ADC ChipES9039MPro / ES9039MSPro
Max sampling rateDSD512
Max sampling rate768kHz
ClassN/A
FIIO K19 DAC 2x ES9039SPRO Headphone Amplifier 2x THX AAA-788+ 32bit 768kHz DSD512 8000mW 32 Ohm Black
FiiO unveils one of its most sophisticated devices with its K19. The K19 is an ultra-complete, high-performance DAC/headphone amplifier. It...
