By buying this product you get 52 loyalty points
FiiO offers us the evolution of their K9 model. The K9 AKM is a versatile DAC model integrating analog and digital inputs, and can be used in USB DAC mode. This model features a latest-generation AKM DAC coupled with its Delta-Sigma modulator, enabling music playback at resolutions of up to 32 bits / 768kHz and DSD512 file decoding. These two THX amplifiers, meanwhile, can deliver up to 2000 mW at 32 ohms for efficient powering of any headphones or earphones, thanks to balanced and unbalanced outputs.
Highly versatile, the Fiio K9 AKM headphone amplifier / DAC adapts to any type of input, analog or digital, and can be easily connected to all your sources. USB-B and asynchronous USB-C ports are available for processing Windows and Mac sources. These are linked to a high-precision XMOS XUF208 controller, guaranteeing optimum playback of your files. Conversion, meanwhile, is entrusted to an AK4191 DAC associated with its AK4499EX Delta-Sigma modulator, allowing total separation of digital and analog sections. To ensure correct data addressing and optimal conversion of 32-bit / 768kHz music, a dual 49 and 45 MHz clock has also been integrated.
At the DAC's output, Fiio's K9 AKM integrates two THX AAA 788+ amplifier modules. These combine the best of both worlds, offering amplification power and sound close to the best Class A amplifiers, while consuming as much power as Class D amplifiers. THX AAA technology ensures perfectly accurate reproduction with zero noise. The incredibly low harmonic distortion (THD) of 0.00027% and a frequency response ranging from 20Hz to 50kHz make it indispensable for appreciating all the details of a High Definition recording. The Fiio K9 AKM amp / DAC is therefore naturally Hi-Res Audio certified.
On the output side, the Fiio K9 AKM offers an single-ended 6.35mm headphone output and two balanced outputs, one 4.4mm jack and one XLR. The unbalanced output is rated at 1500mW at 32 Ohm, while the balanced outputs are rated at 2000mW at 32 Ohm. Thanks to its design, Fiio's headphone amplifier can power any type of headphone or pair of headphones, even high-impedance ones. Furthermore, to guarantee perfect compatibility, you'll find three gain settings on the front of the K9 AKM.
In addition to its USB ports, the K9 AKM offers two digital inputs (one optical and one coaxial), and a 4.4mm jack input. This makes it possible to connect a wide range of sources, such as CD players, network players and TV sets. It can therefore be easily integrated into any Hifi system, where it will act as a USB DAC and Audio DAC. Furthermore, thanks to its Bluetooth 5.1 receiver, Fiio audio's K9 AKM can handle music from a smartphone, tablet or computer. On the codec front, support of SBC and AAC guarantees compatibility with all sources, while the aptX HD and LDAC codecs ensure high listening quality. Finally, the aptX Low Latency and aptX Adaptive codecs are also on board to avoid any sound/image mismatch if you want to broadcast audio from a video.
Finally, Fiio's K9 AKM is not only easy to control from its physical front panel interface, but can also be remotely controlled via the Fiio mobile app. While you can adjust the volume, gain level, source and front-panel output connectors, you can set many other parameters and create your own equalization curves to adjust sound reproduction to your preferences.
Product type | DAC Amplifier Preamplifier |
DAC Chip | AK4191 + AK4499EX |
Inputs | Bluetooth 1x USB-B 1x USB-C 1x RCA stéréo asymétrique 1x Jack 4.4mm symétrique 1x Fibre optique 1x Coaxial |
Outputs | 1x RCA stéréo asymétrique 1x Jack 6.35mm asymétrique 1x jack 4.44mm symétrique 1x XLR3 stéréo symétrique 1x XLR4 sysmétrique |
USB Interface | XMOS XUF208 |
Bluetooth chip | QCC5124 |
Low Pass Filter | 2x OPA1612 |
Volume controller | 2x NJU72315 |
Amplification chip | 2x THX AAA788+ |
Channels balance | L12~R12 (0.5dB par niveau) |
Gain | L (Low) M (Medium) H (High) |
FiiO Control | Supported |
Supported Bluetooth codecs | AAC, SBC, aptX, LDAC, aptX HD, aptX LL, aptX Adaptive |
Bluetooth codecs indicators | SBC : Blue AAC : Cyan aptX HD : Yellow aptX : Purple aptX LL : Purple LDAC : White aptX Adaptive : Green |
Supported sampling rates | 768k 32bit / DSD512 |
Recommended headphone impedance | 8~350Ω |
SINGLE-ENDED LINE OUTPUT PERFORMANCES | |
Total harmonic distortion (THD) | <0.00027% (1kHz/-0.7dB@10kΩ) |
Signal-to-noise ratio (SNR) | ≥119dB (dBA) |
Crosstalk | ≥112dB (1kHz@10kΩ) |
Bottom noise | <2.9μV (dBA) |
Frequency response | 20Hz~50kHz(-3.5dB) |
Line Output Level | 2.3Vrms (1kHz@10kΩ) |
BALANCED LINE OUTPUT PERFORMANCES | |
Total harmonic distortion (THD) | <0.00020% (1kHz/-1dB@10kΩ) |
Signal-to-noise ratio (SNR) | ≥128dB (dBA) |
Crosstalk | ≥122dB (1kHz@10kΩ) |
Bottom noise | <1.9μV (dBA) |
Line Output Level | 4.7Vrms (1kHz@10kΩ) |
SINGLE-ENDED HEADPHONE OUTPUT PERFORMANCES (JACK 6.35MM) | |
Output power | 1000mW 16Ω, THD+N<1% 1500mW 32Ω, THD+N<1% 200mW 300Ω, THD+N<1% |
Output impedance | <1Ω (32Ω) |
Crosstalk | ≥76dB (1kHz@32Ω) |
Total harmonic distortion (THD) | <0.00026% (1kHz/-1.3dB@32Ω) |
Bottom noise | <3.0μV (dBA) |
Signal-to-noise ratio (SNR) | ≥127dB (dBA) |
Max output voltage | >21Vp-p |
PERFORMANCES SORTIE CASQUE SYMÉTRIQUE (JACK 4.4MM, XLR4) | |
Output power | 1000mW 16Ω, THD+N<1% 2000mW 32Ω, THD+N<1% 780mW 300Ω, THD+N<1% |
Crosstalk | ≥116dB (1kHz@32Ω) |
Total harmonic distortion (THD) | <0.00029% (1kHz/-9.5dB@32Ω) |
Bottom noise | <5.2μV (dBA) |
Signal-to-noise ratio (SNR) | ≥124dB (dBA) |
Max output voltage | >42Vp-p |
Supply voltage | AC 100-120V / AC 220-240V |
Dimensions | 200x 224.5x 72mm |
Net weight | 2.65 kg |
Case material | Aluminum |
Color | Noir |
Input | Bluetooth |
Input | Jack 4.4mm |
Input | USB |
Input | SPDIF |
Input | Optical Fiber |
Input | RCA |
Output | XLR |
Output | Jack 4.4mm |
Output | RCA |
Output | Jack 6.35mm |
DAC / ADC Chip | AK4499EX |
Max sampling rate | 768kHz |
Color | Black |
Class | Class D / T |
Networking | No |
Remote Control | No |
