FIIO R7 Audio Player DAC ES9068AS Headphone Amplifier 2x THX AAA-788+ 32bit 768kHz DSD256 MQA
The FiiO R7 is the brand's first ever digital audio player featuring a high-performance ES9068AS DAC chip, two high-power THX-788+ headphone amplifier chipsets and a beautiful display for intuitive navigation. Featuring an extensive connectivity, the R7 can be used both as a standalone player and in combination with other devices.
Reference : 17246
699,00 €tax incl.
582,50 € tax excl.
FiiO R7
FiiO R7 Lecteur Audio DAC ES9068AS Amplificateur Casque 2x THX AAA-788+ 32bit 768kHz DSD256 MQA
ES9068AS DAC
The digital/analog conversion stage is equipped with an ESS ES9068AS DAC. This one, in addition to ensuring a decoding of a great quality, allows the support of high resolution audio streams, up to PCM 32bit 768kHz and DSD256. It is also capable of reading MQA (Master Quality Authenticated) files for the most faithful sound reproduction possible.
THX amplifier circuit
The FiiO R7 features a powerful amplifier circuit, embedding two THX AAA-788+ chips. It is thus capable of delivering a high power of 3000mW. Furthermore, the R7 offers 7 gain levels, allowing it to adapt to the most demanding headphones as well as to very sensitive in-ear monitors.
A complete connectivity
The R7 is not left behind in terms of connectivity and offers many possibilities of association. On the input side, there are USB-C, USB-A (USB Host), coaxial, optical, an SD card slot, an RJ45 Ethernet network input, as well as Bluetooth. For the outputs, the FiiO R7 offers coaxial, optical, single-ended RCA, balanced XLR, as well as three headphone outputs in balanced 4.4mm jack and 4-pin XLR formats and unbalanced 6.35mm jack.
FiiO R7 Lecteur Audio DAC ES9068AS Amplificateur Casque 2x THD AAA-788+ 32bit 768kHz DSD256 MQA
A powerful architecture
The FiiO R7 ensures a fast use without slowing down thanks to the integration of a powerful Qualcomm Snapdragon 660 processor, associated with 4GB of RAM. It also uses Android 10 operating system, allowing the installation and use of numerous applications.
Product typeAudio player
InputsBluetooth 5.0
WiFi
1* USB-C
1* USB-A (USB Host)
1* Optical Toslink
1* Coaxial
1* Ethernet RJ45
1* Slot SD (up to 2TB)
OutputsBluetooth 5.0
WiFi
1* Optical Toslink
1* Coaxial
2* Single-ended stereo RCA
1* Balanced stereo XLR
1* Single-ended Jack 6.35mm headphone output
1* Balanced Jack 4.4mm headphone output
1* Balanced XLR 4 pins headphone output
WiFi2.4GHz/5GHZ
DAC chipESS ES9068AS
Headphone amplification chip2* THX AAA-788+
SoCQualcomm Snapdragon 660
RAM4Go
Internal storage64Go
OSAndroid 10
Screen4.97"
720*1280px
Supported Bluetooth codecsTransmission: SBC, AAC, aptX, aptX LL, aptX Adaptive, aptX HD, LDAC, LHDC
Reception: SBC, AAC, LDAC
Bluetooth LED indicatorBlue: SBC
Cyan: AAC
Purple: aptX / aptX LL
Yellow: aptX HD
White: LDAC
Green: aptX Adaptive
Orange: LHDC
Supported sampling ratesDAC USB / Local decoder: PCM up to 32bit 384kHz, Native DSD up to DSD256
USB Audio: PCM up to 32bit 768kHz, Native DSD up to DSD512
Coaxial input: PCM up to 24bit 192kHz
Optical input: PCM up to 24bit 96kHz
Coaxial output: PCM up to 24bit 384kHz, DSD DoP up to DSD128
Optical output: PCM up to 24bit 192kHz
MQA Support8x decoding
Sampling rates LED indicatorBlue: lossy
Cyan: low resolution
Yellow: high resolution
Vert : DSD
Magenta : MQA
Headphone output power3000mW
Recommanded headphone impedanceSingle-ended: 16 ~ 150Ω
Balanced: 16 ~ 300Ω
Channel balanceL20~R20 (0.5dB per level)
Gain settingsUltra high
Super high
High
Medium
Low
EQDynamic 10 bands (±12dB)
8 presets
Custom EQ
Single-ended headphone output performances (input: DAC USB/optical/coaxial, ultra high gain)
Output power≥ 2*1850mW @ 16Ω, THD+N < 1%
≥ 2*1250mW @ 32Ω, THD+N < 1%
≥ 2*160mW @ 300Ω, THD+N < 1%
SNR≥ 124dB (dBA)
Frequency response5Hz~50kHz @ attenuation < 1dB
20Hz~20kHz @ attenuation < 0.3dB
Output impedance< 0.5Ω
Crosstalk≥ 77dB
Peak voltage18Vp-p
THD+N< 0.0005% @ 1kHz, -8dB, 32Ω
Noise floor< 4µV (dBA)
Single-ended headphone output performances (input: DAC USB/optical/coaxial, super high gain)
Output power≥ 2*1450mW @ 16Ω, THD+N < 1%
≥ 2*750mW @ 32Ω, THD+N < 1%
≥ 2*80mW @ 300Ω, THD+N < 1%
SNR≥ 124dB (dBA)
Frequency response20Hz~80kHz @ attenuation < 1dB
Output impedance< 0.4Ω
Crosstalk≥ 73dB
Peak voltage14Vp-p
THD+N< 0.0005% @ 1kHz, -6dB, 32Ω
Balanced headphone output performances (input: DAC USB/optical/coaxial, ultra high gain)
Output power≥ 2*1000mW @ 16Ω, THD+N < 1%
≥ 2*3200mW @ 32Ω, THD+N < 1%
≥ 2*630mW @ 300Ω, THD+N < 1%
SNR≥ 122dB (dBA)
Frequency response20Hz~50kHz @ attenuation < 2dB
Crosstalk≥ 116dB
Peak voltage39Vp-p
Noise floor< 7.5µV (dBA)
Balanced headphone output performances (input: DAC USB/Optical/coaxial, super high gain)
Output power≥ 2*800mW @ 16Ω, THD+N < 1%
≥ 2*3000mW @ 32Ω, THD+N < 1%
≥ 2*320mW @ 300Ω, THD+N < 1%
SNR≥ 122dB (dBA)
Frequency response20Hz~80kHz @ attenuation < 2dB
20Hz~20kHz @ attenuation < 0.1dB
Crosstalk≥ 116dB
Peak voltage27.7Vp-p
THD+N< 0.00048% @ 1kHz, -6dB, 32Ω
Single-ended line output performances (USB DAC/optical/Coaxial)
THD+N< 0.0005% @ 1kHz, -0dB, 10kΩ
SNR≥ 118.5dB (dBA)
Frequency response5Hz~80kHz @ attenuation < 2dB
Crosstalk≥ 112dB
Noise floor< 2.7µV (dBA)
Niveau de sortie2.2Vrms
Balanced line output performances (USB DAC/optical/Coaxial)
THD+N< 0.0005% @ 1kHz, 0dB, 10kΩ
SNR≥ 125dB (dBA)
Frequency response5Hz~50kHz @ attenuation < 2dB
Crosstalk≥ 121dB
Noise floor< 2.5µV (dBA)
Niveau de sortie4.5Vrms
Supply voltage12VDC 3A OR100-240VAC 50/60Hz
Dimensions (L*P*H)110*134*160mm
Weight1282g
Package1* FiiO R7
1* Power cable
1* Flat support
1* Angled support
1* Jack 6.35mm adapter
1* USB cable
1* SD adapter
InputJack 6.35mm
OutputJack 4.4mm
OutputOptical Toslink
OutputJack 6.35mm
OutputCoaxial SPDIF
DAC / ADC ChipES9068AS
Max sampling rateDSD256
Max sampling rateMQA
Max sampling rate768kHz
NetworkingYes
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsTidal
Streaming services & Network protocolsWeb radios
Fantastique !
Le FIIO R7 et un superbe élément hi-fi extrêmement bien construit. Ce petit boîtier regroupe 3 fonctions : DAC, streamer et amplificateur pour casque. J’ai été très impressionné par sa qualité de restitution et sa musicalité, utilisé avec un Meze Audio Classic 99 avec Qobuz en HI-RES c’est tout simplement une dinguerie!!!! Ont plus envie de ce décoller le casque des oreilles ! Je n’irai pas dans l’argumentaire audiophile car chacun d’entre nous doit se faire son propre opinion, mais j’estime que cet appareil peut parfaitement trouver sa place dans une installation hi-fi de bonne facture ! Bref cette petite boîte m’a franchement épaté
This review has been posted for FIIO R7 Audio Player DAC ES9068AS Headphone Amplifier 2x THX AAA-788+ 32bit 768kHz DSD256 MQA
The FiiO R7 is the brand's first ever digital audio player featuring a high-performance ES9068AS DAC chip, two high-power THX-788+ headphone...
