FOSI AUDIO DAC-Q4 DAC PCM5100 Headphone Amplifier MAX97220 24bit 192kHz
Compact, versatile and particularly affordable, the Fosi Audio DAC-Q4 brilliantly combines the functions of DAC and headphone amplifier. Ideal for a desktop installation, it will fit equally well into a more conventional audio system. Its digital/analog conversion stage is based on a Texas Instruments PCM5100 DAC chip, ensuring quality decoding for precise sound reproduction.
Reference : 17959
55,90 €tax incl.
46,58 € tax excl.
Shipping date: 22-04-2025.
Fosi Audio DAC-Q4
Fosi Audio DAC-Q4 DAC PCM5100 Amplificateur Casque MAX97220 24bit 192kHz
Compact, versatile and particularly affordable, the Fosi Audio DAC-Q4 brilliantly combines the functions of DAC and headphone amplifier. Ideal for a desktop installation, it will fit equally well into a more conventional audio system. Its digital/analog conversion stage is based on a Texas Instruments PCM5100 DAC chip, ensuring quality decoding for precise sound reproduction. It is accompanied by an MS8416 SPDIF receiver supporting PCM streams up to 24bit 192kHz, and a CT7601 USB interface accepting PCM signals up to 24bit 96kHz. The headphone amplification stage of the Fosi Audio DAC-Q4 is entrusted to a MAX97220 chip capable of developing a power of 100mW at 32Ω. On the connectivity side, inputs include USB-B, optical and coaxial. Output is either RCA, or on the amplified headphone output with Jack 3.5mm connector. Finally, in addition to volume control, the front panel features a tone control for adjusting bass and treble levels.
1Input selector
2Jack 3.5mm headphone output
3Bass gain control
4Treble gain control
5Power LED
6ON-OFF Switch / Volume knob
75VDC power input
8RCA output
9Coaxial input
10Optical input
11USB-B input
Product typeDAC
Inputs1* USB-B
1* Optical Toslink
1* Coaxial
Outputs1* Stereo RCA
1* Jack 3.5mm headphone output
Supported sampling ratesUSB : PCM up to 24bit 96kHz
Optical / Coaxial : PCM up to 24bit 192kHz
Frequency response20Hz-20kHz
USB CompatibilityWindows XP / 7 / 8 / 10
Mac
Linux
Distortion0.01%
SNR≥ 105dB
Max headphone output power100mW @ 32Ω
Recommended headphone impedance16-200Ω
RCA output level2.3V
Supply voltage5VDC
Dimensions73.5*98*33mm
Housing materialAluminum alloy
Package1* Fosi Audio DAC-Q4
1* USB power cable
1* USB cable
1* Optical cable
OutputJack 3.5mm
DAC / ADC ChipPCM5100
Max sampling rate192kHz
ClassN/A
Compact, versatile and particularly affordable, the Fosi Audio DAC-Q4 brilliantly combines the functions of DAC and headphone amplifier. Ideal for...
