FOSI AUDIO ZD3 DAC
Fosi Audio's ZD3 is a balanced DAC with excellent connectivity thanks to its multiple inputs and Bluetooth 5.0 chip. The digital/analogue conversion is based on an ES9039Q2M chip, which supports PCM up to 32bit 768kHz and DSD up to DSD512. Three DIP8-mounted OPAs can also be replaced if you wish to have a different tone.
Reference : 19836
179,00 €tax incl.
149,17 € tax excl.
Shipping date: 16-04-2025.
Fosi Audio ZD3 DAC ES9039Q2M Bluetooth 5.0 32bit 768kHz DSD512
Fosi Audio ZD3 : Front view
FOSI Audio ZD3 Highlights
Fosi Audio ZD3: Balanced architecture
In order to deliver the cleanest possible sound, Fosi Audio opted for a symmetrical architecture during the design of the ZD3, drastically reducing the distortion that one channel could create on the other.
Fosi Audio ZD3 : Symmetrical architecture diagram
Fosi Audio ZD3: ESS ES9039Q2M Sabre DAC chip
Thanks to its ES9039Q2M DAC chip using Hyperstream IV technology and taking advantage of the advanced Sabre HiFi architecture, the ZD3 is capable of handling a PCM signal up to 32bit 768kHz and DSD up to DSD512.
Fosi Audio ZD3 : DAC Chip
Fosi Audio ZD3 : XMOS and Qualcomm chips
Fosi Audio ZD3: Excellent connectivity
The ZD3 has 5 different inputs, allowing it to adapt to any configuration. Moreover, you can use the HDMI ARC, Optical and Coaxial inputs, each of which accepts a signal up to PCM 24bit 192kHz. You can also use the USB-B input, which accepts PCM 32bit 768kHz and DSD512 thanks to the XMOS XU316 interface used.
Fosi Audio ZD3: Bluetooth 5.0
The ZD3's Bluetooth QCC3031 chip enables it to support high-resolution codecs for stable, reliable wireless transmission: SBC, AAC, aptX and aptX HD. The ZD3 therefore supports up to PCM 24bit 48kHz, i.e. CD quality in wireless transmission.
Bluetooth functionality of the Fosi Audio ZD3
Fosi Audio ZD3: Interchangeable OPA
The ZD3's amplification stage is based on LME49720 OPAs with an output level of 5Vrms on XLR and 2.5Vrms on RCA. However, as these are DIP8 mounted, you can easily replace them with other OPAs with a different sound profile to adapt the pre-amplification to your tastes.
Fosi Audio ZD3 : Macro view of the PCB
Fosi Audio ZD3: Low noise low-dropout regulator
To ensure the cleanest possible power supply, the ZD3 features a number of very low-noise voltage regulators, ensuring that the power needed to operate the device does not pollute your audio signal.
Fosi Audio ZD3 : LDO positioning diagram
The little extras of the Fosi Audio ZD3
Fosi Audio ZD3 trigger
Trigger in/out
For automatic power-up of your Hi-Fi system.
Fosi Audio ZD3 bypass
Bypass
For a pure, unaltered signal.
A perfect match with the ZA3 amplifier
The ZD3 DAC has been specially designed to match one or two of the brand's ZA3 amplifiers. Whether in terms of form factor or electronic components, to get the best out of it aesthetically speaking or for the performance of your Hi-Fi system.
Un match parfait avec le ZA3
Fosi Audio ZD3 overview
Fosi Audio ZD3 highlights
1Balanced XLR output
2RCA output
3Trigger in/out
4Toslink optical input
5Antenne Bluetooth
6Coaxial input
7HDMI ARC input (CEC compatible)
8USB-B input
9DC 12V power port
The ZD3 nails the look and importantly, feature set of what one wants in a low cost DAC. It provides full transparency with excellent noise and distortion. […] It is my pleasure to recommend the Fosi ZD3 balanced stereo DAC.
Logo Audio Science Review
Product typeDAC
DAC chipES9039Q2M
OPALME49720
Inputs1x USB-B
1x HDMI ARC (CEC compatible)
1x Coaxial
1x Optical Toslink
Bluetooth
Outputs1x Stereo XLR
1x Stereo RCA
Supported sampling ratesUSB : PCM 32bit 768kHz / DSD512
Optical/Coaxial/HDMI : PCM 24bit 192kHz
Bluetooth : PCM 24bit 48kHz
Output levelXLR : 5Vrms
RCA : 2.5Vrms
Signal-to-noise ratio (SNR)126dB
SINAD≥ 120dB
Total harmonic distortion more noise (THD+N)< 0.00008%
Dynamic range≥ 123dB
Noise level≤ 2μV
Bluetooth version5.0
Bluetooth operating range≥ 13m
Supported codecsaptX HD, aptX, AAC, SBC
USB compatibilityWindows 7, 8, 8.1, 10, 11 (driver required)
Mac OS X
Linux
Power supplyDC 12V 1.5A
Package1x Fosi Audio ZD3
1x Remote control
1x 12V 1.5A power supply
1x USB-A to USB-B cable
1x Jack 3.5mm trigger cable
Fosi Audio ZD3 measurements
ZD3 measurements
InputHDMI ARC
ClassN/A
Remote ControlYes
3 reviews
Relié en optique au drive et en coaxial au steamer,
ce joli petit dac offre un son chaud et musical, sans aucune agressivité.
This review has been posted for FOSI AUDIO ZD3 DAC ES9039Q2M Bluetooth 5.0 32bit 768kHz DSD512
Excellent pour le prix et facile à « upgrader »
J’essaie depuis quelques jour ce dac recommandé par ASR.
(Audiophonics propose aussi des « packages » intéressants avec l’amplificateur za3 de la même marque.)
Je le trouve très bon. Ma configuration est un peu « perchée » vu que je lui ai collé une très bonne alim 12 volts et super câble secteur + câble dc. Donc au final je ne suis plus du tout sur un dac à 180 euros.
Sans aller aussi loin on peut quand même profiter de l’entrée dc pour virer le petit bloc à découpage livré avec l’appareil.
Je ne sais pas ce que vaut cette ifi mais ça peut être intéressant
https://www.audiophonics.fr/fr/adaptateu...14433.html
Fosi propose aussi une manip relativement simple pour changer les aop de ses appareils. Apres le tube rolling on a donc du « op amp rolling ». On peut essayer des alternatives à quelques euros ou aller jusqu’au Sparkos à 85 euros, ce qui augmente fortement le coût de revient, particulièrement si on utilise le dac en symétrique (2 aop à changer).
On peut aussi trouver en ligne des aop « discrets » autour de 15 euros qui ont la cote. J’essaierai peut-être.
J’utilise simplement la sortie rca et je n’ai aucune frustration. C’est moins raffiné et détaillé que mon dac principal mais pour le prix c’est excellent. Bien mieux que le dac de mon petit lecteur de cd Teac 301 utilisé avec la même alimentation.
Une reussite
Connecté par câbles XLR à un ampli ZA3, et relié en optique à mon Yamaha WXC-50, en coaxial à un lecteur de Blu-ray Sony et en hdml arc à un téléviseur Samsung, ce Dac ZD3 joue les chefs d’orchestre avec une redoutable efficacité. Mes enceintes JMR Folia jubilé (4ohm) restituent un son à la fois précis, légèrement chaud avec des aigus sans aucune agressivité. Hauts et bas Médiums sont superbes et très bien équilibrés. Les basses n’en font pas trop et sont bien contrôlées. Bref que du bon. Le Dac apporte de la précision à ce petit système tout en restant très musical. Cette nouvelle puce ESS 9039 est une réussite quelque soit l’entrée utilisée.
A ce prix c’est vraiment une affaire.
 (3)
Fosi Audio's ZD3 is a balanced DAC with excellent connectivity thanks to its multiple inputs and Bluetooth 5.0 chip. The digital/analogue...
