FX-AUDIO DAC-A10 DAC Preamplifier
FX-Audio's DAC-A10 is a versatile, high-performance tube DAC/preamplifier with a relatively compact form factor. It is based on quality components such as an ESS ES9018K2M DAC chip and two 6N3 tubes for the preamplifier stage.
Reference : 18576
115,00 €tax incl.
95,83 € tax excl.
FX-AUDIO DAC-A10DAC ES9018K2M / Tube Preamplifier 6N3 Bluetooth 5.1 aptX HD LDAC 24Bit 192kHz
Photo of FX-AUDIO DAC-A10
FX-Audio's DAC-A10 is a versatile, high-performance DAC / tube preamplifier with a relatively compact form factor. It is based on quality components such as an ESS ES9018K2M DAC chip and two 6N3 tubes for the preamplifier stage. It also incorporates a TI TPA6120A2 headphone amplifier chip, OPA1612 OPAs, an STM8S microcontroller, a CM6642 USB/ADC interface and a QCC5125 Bluetooth 5.1 receiver chip.  It supports PCM streams up to 24bit 192kHz.  Moreover, a subwoofer output enables the A10 DAC to be used in a 2.1-channel Hi-Fi configuration.
FX-Audio DAC-A10: ESS ES9018K2M DAC and CM6642 interface
The DAC-A10 features an ESS Technology ES9018K2M DAC chip for audiophile applications. This chip features HyperStream architecture and a jitter elimination solution. It enables the DAC-A10 to support audio streams up to PCM 24bit 192kHz. A CM6642 chip completes the decoding stage. This chip acts as a high-speed USB 2.0 interface with 3-channel ADC, S/PDIF interface and PWM LED controller.
Photo of ES9018K2M DAC chip
Photo of 6N3 tubes
FX-AUDIO DAC-A10: Preamplification with 6N3 tubes
The preamplifier stage incorporates two 6N3 tubes, bringing warmth and roundness to the final sound reproduction. If you wish to adapt the DAC-10's output sound to your listening preferences, you can change the tubes supplied with the following compatible tubes: 6A8Q, 2C51, 5670, 5185, 6385, 6185, WE396, ECC42, 6H3N, 6H3II, ECF82 or 6CC42.
FX-Audio DAC-A10: Bluetooth 5.1 receiver chip
A Qualcomm QCC5125 Bluetooth 5.1 receiver chip enables the DAC-A10 to support high-resolution Bluetooth codecs: SBC, ACC, aptX, aptX LL, aptX HD and LDAC. So you can enjoy an audio source such as your smartphone or tablet with a high-resolution wireless connection.
Photo of Bluetooth logo
Photo of TI TPA6120A2 chip
FX-Audio DAC A-10: a high-performance headphone amplifier
The TI TPA6120A2 class A/B amplifier chip delivers wide bandwidth, low noise and high dynamics. It gives the DAC-A10 plenty of power on its 6.35mm jack headphone output, with 2x 300mW @ 32 Ohm.
Overview of FX-Audio DAC-A10 connectors
FX-Audio DAC-A10 connector diagram
1ON-OFF / Input selector
2Active input LED indicators
3Jack 6.35mm headphone output
4Volume control
5Bass adjustment
6Treble adjustment
7Bluetooth antenna
8USB-B input
9Toslink optical input
10RCA line input
11Subwoofer ouput
12RCA line output
1312V DC 5.5/2.1mm jack power connector
FX-Audio DAC-A10 dimensions
Product typeDAC
Preamplifier
Headphone amplifier
DAC ChipESS ES9018K2M
Tubes2x 6N3
Amplification typeClass A/B
Amplification chipTI TPA6120A2
USB / SPDIF interfaceCM6642
OPAOPA1612
Inputs1x USB-B input
1x Toslink optical input
1x RCA stereo line input
Bluetooth 5.1
Outputs1x RCA line output
1x 6.35mm headphone output
1x Subwoofer output
Supported sample ratesPCM 24bits 192kHz
Supported Bluetooth codecsSBC, ACC, aptX, aptX LL, aptX HDLDAC
Line output levels3Vrms
THD< 0.5%
SNR> 90dB
Headphone output power2x 300mW @ 32 Ohm
Frequency response20Hz-20kHz
Tone controlBass and Treble : -16dB / +6dB
Power supply12V DC via DC 5.5/2.1mm jack connector
Dimensions180 x 180 x 35mm
Weight776g
Package1x FX-Audio DAC-A10
2x 6N3 Tubes
1x Bluetooth antenna
1x USB-A to USB-B (2.0) cable
1x Mains adapter
OutputSubwoofer
OutputJack 6.35mm
DAC / ADC ChipES9018K2M
Max sampling rate192kHz
ClassClass A / AB
2 reviews
Rapport qualité prix imbattable
Rapport qualité prix imbattable, la qualité d'écoute sera au rendez vous à seule condition de changer les tubes chinoises fournies par des tubes russes série militaire, la différence tant vraiment notable. Fabriqués selon des cahiers de charges plus exigeantes au niveau endurance, les tubes russes série militaire 6N3P-E (6Н3П-Е) chauffent moins. La puce de réception Bluetooth 5.1 QCC5125 de chez Qualcomm qui permet au DAC-A10 de supporter les codecs Bluetooth haute résolution : SBC, ACC, aptX, aptX LL, aptX HD et LDAC est un plus. Ecoute sur casques Sennheiser HD 650
This review has been posted for FX-AUDIO DAC-A10 DAC ES9018K2M Tube Preamplifier 6N3 Bluetooth 5.1 aptX HD LDAC 24Bit 192kHz
Très bon et pratique
Préampli et récepteur bluetooth avec un son détaillée plutôt correct. Volume et contrôle tonalités font de ce petit appareil une tour de contrôle très pratique qui s'adapte très bien avec un ensemble hifi,même hétéroclite par exemple un lecteur cd, un ampli, un tuner et même un caisson de basse.
FX-Audio's DAC-A10 is a versatile, high-performance tube DAC/preamplifier with a relatively compact form factor. It is based on quality...
