DAC ES9038Q2M XMOS 32bit 768kHz DSD512 Blue
FX-Audio's DAC-M1 is a compact, affordable and powerful digital-to-analog converter. It is based on the use of an ESS ES9038Q2M DAC chip, associated with an XMOS XU208 USB interface, allowing for the support of high-resolution audio streams, up to PCM 32bit 768kHz and DSD512, while offering great sound transparency. The DAC-M1 is also equipped with a headphone amplifier stage, based on a Texas Instruments TPA6120A2 chip. In terms of connectivity, the DAC-M1 is versatile, with USB-C, Coaxial, Optical and Bluetooth 5.0 inputs, using a Qualcomm CSR8675 receiver chip and supporting the aptX, aptX HD and aptX LL transmission codecs. For its outputs, the DAC-M1 offers a stereo RCA output, as well as a headphone output on the front panel on 6.35mm jack.
"It is easy to see that the company has aimed high with this combination DAC and headphone high. The transparency is provided almost across the board with plenty of power to drive a range of headphones. It is nice to have different options in this class of product. "
Product type | DAC |
DAC Chip | ES9038Q2M |
USB Interface | XMOS XU208 |
Headphone amplifier chip | TPA6120A2 |
Bluetooth reception chip | CSR8675 |
Inputs | 1x USB-C 1x Optical Toslink 1x Coaxial Bluetooth 5.0 |
Outputs | 1x Stereo RCA 1x Jack 6.35mm headphone output |
THD+N | 0.00025% |
SNR | 118dB |
USB Transmission mode | Asynchronous |
USB Compatibility | Windows 7 / 8 / 8.1 / 10 Mac OSX 10.6 Linux |
Supported sampling rates | USB : PCM up to 32bit 768kHz, Native DSD up to DSD512 Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64 Bluetooth : PCM up to 24bit 96kHz |
Headphone output power | 500mW @ 32Ω 340mW @ 64Ω 180mW @ 150Ω 96mW @ 300Ω |
Consumption | 3.5W |
Standby consumption | 0.25W |
Dimensions | 130 x 10 x 55mm |
Weight | 350g |
Color | Blue |
Package | 1x FX-Audio DAC-M1 1x Power adapter 12V 1A 1x Bluetooth antenna 1x Remote control |
Input | SPDIF |
Input | Bluetooth |
Input | USB |
Input | Optical |
Output | Jack 6.35mm |
Output | RCA |
DAC / ADC Chip | ES9038Q2M |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Color | Blue |
Networking | No |
Remote Control | Yes |
