FX-AUDIO DAC-X3 DAC / Headphone amplifier CS4344 24bit / 192kHz Black
The FX AUDIO DAC -X3 offers a wide range of digital input connections that can be adapted to any configuration.
It will be ideal in DAC input to improve the output of a PC, a TV thanks to its optical input and having a 3.5mm jack headphone output.
Strong point:
Optical input, Coaxial and USB
Headphone output
Compact size
4.9 / 5
Reference : 12576
39,90 €tax incl.
33,25 € tax excl.
This model is replaced by the new version: FX-AUDIO DAC-X3 PRO.
FX-Audio DAC-X3
DAC / Headphone Amplifier CS4344 24bit 192kHz Black
FX-Audio DAC-X3 DAC / Amplificateur Casque CS4344 24bit 192kHz Noir
The FX-Audio DAC-X3 is a brand new and versatile DAC that is distinguished by its design and electronic architecture as well as by the connectivity provided. It is equipped with a CM108 USB interface that can support PCM audio files up to 16bit 48kHz as well as a CS4344 digital interface that can support PCM audio files up to 24bit 192kHz.
It is equipped with a Cirrus Logic CS4344 DAC converter, resulting in a gold-plated RCA stereo output, as well as a 3.5mm Jack headphone output capable of delivering up to 120mW of power. This small DAC and headphone amplifier DAC-X3 is ideal for office use or to complete an audio system with its full connectivity.
FX-Audio DAC-X3 review by Qobuz
" This small, low-cost DAC FX-Audio DAC-X3 DAC-Audio offers two sound renditions depending on the output used. A certain wisdom if you use it from its stereo line output with a Hi-Fi system and a restitution that seems more true since its headphone output. "
Test du FX-Audio DAC-X3 par Qobuz
Product typeDAC and Amplifier
DAC chipCS4344
Inputs1x USB-B
1x Coaxial
1x Optical
Outputs1x Stereo RCA (Line Out)
1x Jack 3.5mm
Sampling rateUSB : up to 16bit 48kHz
Coaxial / Optical : up to 24bit 192kHz
USB InterfaceCM108
S/PDIF InterfaceCS8416
Headphone output power120mW
Headphone output SNR81.5dB
Headphone output THD0.14%
Housing materialBrushed Aluminium
Dimensions10.5 x 7.5 x 3.2cm
Weight500g
Package1x FX-Audio DAC-X3
1x 12V 1A Power supply
OutputJack 3.5mm
DAC / ADC ChipCS4344
Max sampling rate192kHz
7 reviews
EXCELLENT POUR LE PRIX ET LA QUALITE !!!
J'avais envie d'avoir sur mon bureau d'ordi une prise casque 3,5 de bonne qualité à porté de main pour pouvoir brancher un casque Sennheiser en plus de la sortie RCA vers l'ampli et j'étais pas trop sur de la qualité de la sortie casque (surtout en 3.5 ?) sur ce DAC... Donc pour moi le Canal casque est impeccable et le canal RCA Ampli est aussi impeccable et quand je dit impeccable c'est plus que largement au dessus des cartes sons d'ordinateur. Voilà à ce prix et au niveau qualité n'attendez pas (en plus il lit le 24bit / 192kHz)... Sinon vous regretterez de pas l'avoir commandé avant !!! Encore un beaux petit couteaux suisse que je me réserve pour mes soirées de découverte musicale. Et surtout merci à l'équipe d'AUDIOPHONICS pour leur sérieux et savoir faire.
This review has been posted for FX-AUDIO DAC-X3 DAC / Headphone amplifier CS4344 24bit / 192kHz Black
AWESOME Product!!!
An awesome product with a very good (in this price level) DAC.
Price performance ratio - absolutely great
Franchement pour un prix dérisoire ce petit dac est vraiment bluffant au niveau de l'écoute. Je m'en sers sur une chaîne bis (lecteur Aune, ampli naim nait 2) et j'avoue que je m'attendais pas à ce résultat. Il était prévu au départ pour un usage bien plus modeste. Attention il peut être sensible au protocole d'allumage des appareils (ampli-convertisseur-lecteur).
Vous avez dit un avis !
Étant forumeur assidu d'un forum de hardware informatique j'entendais souvent parler de DAC et dans l'ensemnle tres positivement, ma vieille chaine Hifi d'un côté reliée a mon Pc par la simple entrée jack verte...au bout de'quelques annees j'ai'approfondis mes recherches sur le DAC U-Sabre et de lien en lien mks mon devolu sur le FX-X3, une fois connecté (aucunes manips software a faire) ah si baisser le,volume de l'ampli qui etait éternellement sur 5, la j'ai du descendre à 2 et mes amis quels sons, je ne çonnaissait pas mon systeme hifi'ainsi, du bon, du trés bon son, perso j'ai'ete berçé sous la zic rock des 70s / 80s quand j'ai mis echoes ,,wish you'we here...je me suis pris pour un spectareur intime de l'amphi de'Pompéï j'etait tout petit sur les pierre tout là-haut des gradins.
Parfait (utilisé pour connecter TV/Ampli)
Aucun son parasite, les connecteurs sont de bonne qualité. De plus il est beaucoup plus efficace que l'ancien DAC que j'avais, j'ai gagné en terme de niveau sonore. Un bon petit DAC à prix raisonnable !
The FX AUDIO DAC -X3 offers a wide range of digital input connections that can be adapted to any configuration. It will be ideal in DAC input to...
