DAC Headphone Amplifier DAC01 MAX97220 STM32 24bit 96kHz
FX-Audio offers with the DAC-X4 a digital/analog converter with headphone amplifier, at a very affordable price. This one embeds a DAC01 conversion chip, allowing it to support PCM sampling rates up to 24bit 192kHz. This one is associated with a MAX97220 headphone amplifier chip, offering a power of 2x150mW under 32Ω.
As for the connections, the DAC-X4 remains classic and efficient, with USB-B, Optical Toslink and Coaxial as inputs. For the outputs, we simply find stereo RCA and 3.5mm jack for the headphone output.
Product type | DAC Headphone amplifier |
Inputs | 1x USB-B 1x Optical Toslink 1x Coaxial |
Outputs | 1x Stereo RCA 1x Jack 3.5mm headphone output |
DAC Chip | DAC01 |
Headphone amplifier chip | MAX97220 |
MCU | STM32 |
Supported sampling rates | USB : PCM up to 24bit 96kHz Optical / Coaxial : PCM up to 24bit 192kHz |
Line output level | 0.7Vrms @ 0dBFS |
THD | Line output: 0.007% @ 1kHz, A-Weighting Headphone output: 0.01% |
SNR | Line output: 100dB @ 1kHz, A-Weighting Headphone output: 93dB |
Dynamic range | Line output: 98dB Headphone output: 90dB |
Frequency response | 20Hz-20kHz |
Headphone output power | 2x150mW @ 32Ω |
Headphone output impedance | 16-250Ω |
Supply voltage | 5VDC 1A (Power supply included) |
Housing material | Aluminum alloy |
Dimensions | 98 x 114 x 36mm |
Weight | 250g |
Color | Black |
Input | Optical |
Input | SPDIF |
Input | USB |
Output | Jack 3.5mm |
Output | RCA |
DAC / ADC Chip | DAC01 |
Max sampling rate | 96kHz |
Color | Black |
Networking | No |
Remote Control | No |
