FX-AUDIO DR07 DAC Headphone Amplifier
The FX-Audio DR07 is a quality DAC and headphone amplifier combo at an affordable price. Its meticulous design and comprehensive connectivity make it highly versatile, ensuring its integration into the vast majority of audio systems. What's more, its architecture and components ensure precise, musical sound reproduction.
Reference : 18675
169,00 €tax incl.
140,83 € tax excl.
FX-Audio DR07 DAC Headphone Amplifier 2x AK4493 XMOS XU316 Bluetooth 5.1 QCC5125 32bit 768kHz DSD512
FX-Audio DR07 : Vue de face
FX-Audio DR07 : Caractéristiques principales FX-Audio DR07 : Intégrations possibles et connectique
FX-Audio DR07: Quality components
At the heart of the DR07 are a pair of AK4493 DAC chips and an XU316 XMOS USB receiver. This selection of components ensures that the DR07 delivers high-quality decoding and the ability to support high-resolution audio streams up to PCM 32bit 768kHz and DSD51.2.
A Qualcomm QCC5125 Bluetooth 5.1 receiver completes the design, giving the device a Bluetooth reception function. This makes it possible to stream music remotely, from a smartphone for example.
FX-Audio DR07 : Puces DAC, USB et Bluetooth
Product typeDAC
Headphone amplifier
InputsBluetooth 5.1
1x USB-B
1x Coaxial
1x Optical
Outputs =1x Jack 3.5mm headphone output
1x Jack 6.35mm headphone output
1x Optical
1x Stereo RCA line out
DAC chips2x AKM AK4493
Bluetooth receiverQualcomm QCC5125
USB receiverXMOS XU316
Distortion≤ 0.0005%
Frequency response10Hz - 40kHz (±0.3dB)
SNR120dB
Headphone output power2x 1100mW @ 32Ω
Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD up to DSD512, MQA
Optical / Coaxial : PCM up to 24bit 192kHz, MQA
Supported Bluetooth codecsSBC, AAC, aptX, aptX LL, aptX HD, LDAC
RCA output level2.5Vrms
Dimensions132 x 185 x 32mm
Weight552g
Package1x FX-Audio DR07
1x Remote control
1x Antenna
1x USB-A to USB-B cable
1x Power supply
OutputJack 6.35mm
OutputOptical Toslink
OutputJack 3.5mm
DAC / ADC ChipAK4493EQ
Max sampling rate768kHz
Max sampling rateDSD512
ClassN/A
Remote ControlYes
Sympathique petite machine !
Voici un appareil au prix très abordable qui fait très bien son travail, et fournit un signal de grande qualité, dont on peut choisir la courbe de réponse (6 “couleurs sonores”). C’est mon quatrième DAC FX-Audio et le plus abouti des quatre. L’écran est lilliputien mais lisible (de près) et affiche les infos du paramétrage (sélection des entrées, des sorties - à noter qu’on peut isoler la sortie casque ou la coupler avec la sortie ligne - des filtres, et niveau de volume). Comme je disposais d’une alimentation linéaire 12 V Audiophonics inoccupée, je l’ai branchée sur le DR07, avec pour résultat un son qui me semble encore plus fouillé (issu de Qobuz/Audivarna via la prise USB). Bon, il faut passer un peu de temps à déchiffrer et à traduire le “manuel” fourni, et - conseil ! - utiliser la télécommande pour le paramétrage, ça facilite la vie. Ah ! Aussi : on distingue de légers clics (de relais ?) - dans l’appareil, pas dans le son - au début et à la fin des pistes de lecture. C’est inaudible à l’écoute sur enceintes, mais perceptible à l’écoute avec casques ouverts si on est à côté de l’appareil. Cela dit, au final, un rapport qualité-prix excellent.
This review has been posted for FX-AUDIO DR07 DAC 2x AK4493 Headphone Amplifier XMOS XU316 Bluetooth 5.1 QCC5125 32bit 768kHz DSD512
The FX-Audio DR07 is a quality DAC and headphone amplifier combo at an affordable price. Its meticulous design and comprehensive connectivity make...
