FX-AUDIO DAC-SQ6 DAC Headphone Amplifier
The FX-Audio SQ6 is an affordable DAC and headphone amplifier combo. It benefits from a meticulous design and versatile connectivity for assured integration into the vast majority of audio systems. What's more, its architecture and components ensure clear sound reproduction.
3.0 / 5
Reference : 18679
59,90 €tax incl.
49,92 € tax excl.
FX-Audio DAC-SQ6 DAC Headphone Amplifier ES9038Q2M SA9227 32bit 768kHz DSD256
FX-Audio SQ6 : Front view
FX-Audio SQ6 : Main features FX-Audio SQ6 : Connectivity
FX-Audio SQ6: Quality components
At the heart of the SQ6 are an ES9038Q2M DAC and an SA9227 audio controller. This selection of components ensures that the SQ6 delivers high-quality decoding and the ability to support high-resolution audio streams up to PCM 32bit 768kHz and DSD256.
FX-Audio SQ6 : DAC and USB chips
FX Audio SQ6 : Diagram
1Power / Input switch
2Volume -
3Volume +
4USB LED indicator
5USB 1.0 LED indicator
6DSD LED indicator
7Optical LED indicator
8Coaxial LED indicator
9PCM LED indicator
10USB-C input
11Optical input
12Coaxial input
13Optical output
14RCA line out
15Jack 3.5mm headphone output
Product typeDAC
Headphone amplifier
Inputs1x USB-C
1x Coaxial
1x Optical
Outputs1x Jack 3.5mm headphone output
1x Optical
1x RCA line out
DAC chipESS ES9038Q2M
Audio controllerSA9227
Supported sampling ratesUSB: PCM up to 32bit 768kHz, DSD up to DSD256
Optical / Coaxial: PCM up to 24bit 192kHz
Headphone output power260mW @ 32Ω
RCA output level2.5Vrms
THD≤ 0.0008%
SNR112dB
Frequency response10Hz - 20kHz (±0.5dB)
Dimensions108 x 20.5 x 72mm
Weight-
Package1x FX-Audio SQ6
1x Power supply
OutputJack 3.5mm
OutputOptical Toslink
DAC / ADC ChipES9038Q2M
Max sampling rateDSD256
Max sampling rate768kHz
ClassN/A
Remote ControlN/A
Très beau son mais ... très capricieux
Le son est excellent, d'une finesse inconstestable, mais,
- sur pc (prise USB), la déconnexion est fréquente, le son est alors coupé.
- sur TV, la reconnaisssance/reconnexion (Fiche Opt) utilisée n'est pas systématique. Ce qui contraint à relancer le décodeur pour avoir le son sur l'ampli (alors que la TV est bien réglée en PCM). La bascule en "Opt" via le commutateur du DAC ne suffit pas toujours. Dommage.
Il est vraiment très très petit et fourni sans alimentation (juste un cable usb)
Alors que sur mon Dacmagic100 de Cambridge, la reconnaissance se fait toujours sans problème sur l'un comme sur l'autre.
This review has been posted for FX-AUDIO DAC-SQ6 DAC Headphone Amplifier ES9038Q2M SA9227 32bit 768kHz DSD256
The FX-Audio SQ6 is an affordable DAC and headphone amplifier combo. It benefits from a meticulous design and versatile connectivity for assured...
