GUSTARD A20H DAC Full balanced 2xAK4497 / Headphone amplifier XMOS PCM384 DSD264
The AH20 is a fully balanced DACl & preamplifier / headphone amplifier with relay volume control circuit (hardware). Equipped with the best conversion technologies, it uses two excellent AK4497EQ chips in conjunction with a high-performance XMOS USB interface and has an I2S input on an HDMI connector.
By buying this product you get 85 loyalty points
Reference : 14581
859,00 €tax incl.
715,83 € tax excl.
Gustard A20H
DAC 2x AK4497 / Class A discrete headphone amplifier / Full symmetrical / USB XMOS
This DAC / headphone amplifier will delight audiophiles looking for a very high level compact system for transparent and clear decoding of high definition digital files. It will ideally match HiFi systems of any degree of complexity and offers interesting integration possibilities, notably thanks to its balanced and single-eded outputs which are activated simultaneously.
Full symmetrical DAC AKM AK4497EQ
The digital to analog conversion stage uses a 32-bit AKM AK4497EQ chip combo.
It takes advantage of the famous Velvet Sound architecture of the brand, making it possible to develop sound details of incredible richness while largely limiting the distortion of the signal.
Each channel of the stereophonic signal uses its own DAC chip. This makes it possible to develop an astonishing richness in the resolution of the signal, each of the two chips dedicating 100% of its computing power to a specific channel. This full symmetrical integration feature offers an incomparable level of crosstalk with impressive precision in channel separation. This plays a considerable role in the construction of a detailed sound scene with a clear stereophonic image & spatialization.
The Velvet Sound technology developed by AKM benefits the sound rendering and develops immersive dynamics and integrates 6 selectable reconstruction filters to adapt the behavior of the DAC to the specifics of your audio system and your listening preferences.
The digital signal is processed by CPLD (FGPA Altera) to fulfill the functions of logic, clock management, PLL, DOP demodulation and PCM / DSD antipop.
XMOS U8 USB interface with Accusilicon clocks
The Gustard A20H has a very high quality XMOS U8 USB interface with 8-core controller completely up to date with the latest USB Audio standards.
The latter supports DSD64-256 & PCM384 kHz digital streams and is supported in most current operating systems: Windows XP, Vista, W7, W8, W8.1, W10, MacOS, Linux Kernel and can even partially work with Android and OSX devices if they have an OTG function.
Gustard A20H's integrated USB interface uses two very low phase noise and extremely precise Accusilicon clocks. The model used is one of the best clock references available for digital audio and considerably limits the need to correct errors in digital cycles that can cause unwanted noise and distortion.
Clean dual power supply
The A20H benefits from an extremely efficient power stage based on two regulated linear power supplies with 2x isolated 50W toroidal transformers. This makes it possible to supply the digital and analog stages very cleanly while carefully avoiding the pickup of noise from one circuit to another.
The supply stage is then divided into several sub-units of powerr with individual filtering and voltage regulation for each interdependent block of the circuit. This ensures excellent power stability while limiting local stresses on the components.
Discrete balanced headphone amplifier
The Gustard A20H has a fully discrete and balanced amplification circuit operating in pure class A.
Its balanced and single-ended outputs are active simultaneously.
The headphone amplifier stage is capable of providing comfortable power up to 2400mW at 32Ω and 132mW at 600Ω. Or a reserve of sufficient power to power difficult helmets.
TypeDAC
Headphone amplifier
Volume controlYes (hardware)
ArchitectureFull balanced
DAC Chip2x AK4497EQ
USB interfaceXMOS U8
Headphone amplifiierFull class A
Balanced
Discrete
InputsUSB-B
I2S (HDMI LVDS)
AES/EBU
Coaxial
Optical
OutputsRCA (single-ended) stereo
XLR (balanced) stereo
Mini-XLR (headphone)
Jack 3.5mm (headphone)
Sampling rateUSB : PCM384 / DSD256
SPDIF : PCM192 / DOP64
I2S : PCM384 / DSD256
Dimensions330 x 260 x 65
Weight6kg
InputI2S via HDMI
InputAES/EBU
OutputJack 3.5mm
Réception de la commande
Je viens de recevoir le Gustard A20H. Très bien emballé. Expédition rapide.
Superbe appareil et merci beaucoup.
This review has been posted for GUSTARD A20H DAC Full balanced 2xAK4497 / Headphone amplifier XMOS PCM384 DSD264
The AH20 is a fully balanced DACl & preamplifier / headphone amplifier with relay volume control circuit (hardware). Equipped with the best...
