GUSTARD A26 DAC 2x AK4499EX XMOS XU216 LAN UPnP Roon 32bit 768kHz DSD512 MQA Silver
Gustard unveils with the A26 a high-end DAC, as powerful as versatile. It is based on a high quality architecture, using in particular a dual AK4499EX DAC associated with a AK4191 modulator and a USB XMOS XU216 interface allowing a faithful and rich sound reproduction. It also supports high-resolution audio streams up to PCM 32bit 768kHz, DSD512 and MQA from its USB, I2S and LAN inputs.
4.4 / 5
By buying this product you get 149 loyalty points
Reference : 17145
1 499,00 €tax incl.
1 249,17 € tax excl.
Shipping date: 16-04-2025.
Gustard A26
Gustard A26 DAC 2x AK4499EX XMOS XU216 LAN UPnP Roon 32bit 768kHz DSD512 MQA Argent
AK4499EX dual DAC
With its two AKM AK4499EX DAC chips and AK4191 digital modulator, the Gustard A26 provides high performance decoding for rich, detailed and accurate sound reproduction. In addition, each channel has its own power supply, which considerably reduces interference that could alter the audio signal.
Streamer / Renderer
The Gustard A26 integrates a network layer with its RJ45 Ethernet input and support for UPnP, Roon Bridge and HQPlayer NAA protocols. It can therefore be used as a streamer and allows you to access your files stored on your network, on a computer or a NAS for example.
K2 Clock
In order to provide an accurate clock signal, the A26 features the ultra-low noise K2 module. This ensures that the DAC is able to achieve a very low jitter level for the most transparent sound possible.
The A26 also provides a 10M BNC input allowing it to be used in conjunction with an external clock generator.
XMOS XU216
The USB input of the Gustard A26 is associated with an XMOS XU216 interface. This allows it to support high resolution audio streams, up to PCM 32bit 768kHz and DSD512. It also supports MQA files.
I/V conversion
The Gustard A26 features an I/V conversion stage using multiple OPAs and transistors. This provides a precise and powerful output.
LPF
An LPF using discrete components was specifically designed to accompany the AK4499EX DACs. This was then carefully optimized to provide the best possible sonic performance.
A customized power supply stage
The A26's power supply stage includes two toroidal transformers to provide independent power supply to the analog and digital circuits. It also uses voltage regulators and filter capacitors, ensuring a clean and stable signal.
MQA
The Gustard A26 can decode and play MQA (Master Quality Authenticated) files. These ensure a sound quality as close as possible to the original studio recording.
Product typeDAC
Inputs1* Optical Toslink
1* AES/EBU
1* Coaxial
1* I2S (HDMI)
1* USB-B
1* RJ45 Ethernet
1* BNC clock input (50Ω)
Outputs1* Single-ended stereo RCA
1* Balanced stereo XLR
DAC chips2* AKM AK4499EX
Digital modulatorAK4191
USB interfaceXMOS XU216
Supported sampling ratesUSB / I2S / LAN: PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256, MQA
AES / Optique / Coaxial: PCM up to 24bit 192kHz, DSD DoP up to DSD64
Network protocolsUPnP
Roon Bridge
HQPlayer NAA
Frequency response20Hz - 20kHz ±0.2dB
Dynamic range> 127dB
SNR> 126dB
Crosstalk-139dB @ 1kHz
THD+N≤ 0.0001% @ 1kHz
IMD≈ 0.001% @ -1dBFS
Output levelRCA : 2.5Vrms (fixed volume) 100Ω
XLR : 5Vrms (fixed volume) 100Ω
Supply voltage (switchable)115V/230V AC 50Hz/60Hz
Consumption< 30W
Dimensions (L*P*H)330*260*65mm
Housing materialAluminum
ColorSilver
Pinout I2S
InputClock (BNC)
InputRJ45
InputAES/EBU
InputI2S via HDMI
DAC / ADC ChipAK4499EX
Max sampling rateMQA
Max sampling rate768kHz
Max sampling rateDSD512
ColorSilver
NetworkingYes
Remote ControlYes
7 reviews
Du très beau matériel
Équipé d'un dac teac ud 503 branché en rca esprit alpha à roksan k3 sur monitor audio silver 500 6G. Source tidal depuis pc. Je remplace le teac + pc par ce a26.
Gain léger en utilisant le gustard avec source pc en usb. Puis je passe en l'an avec le streamer interne avec source tidal sur bubble upnp. Et là le gain est incontestable. J'avais déjà un très bon son, bien optimisé, peaufiné pendant des années. Mais là je gagne sur tout. Scène un peu plus large, et clairement plus profonde. Silence un niveau au dessus et surtout micro informations et attaques un gros cran au dessus. Le son a bas volume conserve sa qualité et son dynamisme, avant je sentais qu'il fallait pousser un peu pour profiter du potentiel de mes HP de 20cm.
De nouveaux micro détails se révèlent de manière évidente. Le plus flagrant s'entend sur les percussions/batteries. Un solo de batterie complexe est maîtrisé sans aucune bavure et avec une finesse qui permet d'apprécier l'intention de chaque frappe même quand le batteur est surexcité. J'ai l'impression que ce a26 est capable de gérer tout ce qu'on lui envoie. Au point où j'ai l'impression qu'à présent c'est peut-être le reste du matériel qui mériterait de monter en gamme.
Esthétiquement rien d'incroyable mais c'est minimaliste et très bien construit, donc RAS. En terme de signature sonore, c'est dans la continuité de ce que j'avais avant (double akm) mais tous les curseurs sont clairement poussés en termes de performances. Un son neutre, défini, naturel sans excès, pas de chaleur superflue qui nuirait à la définition, pas de froideur particulière mais une maîtrise virtuose qui prend aux tripes si le reste de l'installation est cohérente.
Ps : je suis habitué à des écoutes sur de nombreux systèmes HDG (atoll, Mac, hegel...).
J'ai changé le câble secteur avec un furutech tcs31 avec viborg rhodium, gain évident sur les basses qui sont plus musclées et longueur de note sur les micro informations.
J'espère qu'il vous plaira.
This review has been posted for GUSTARD A26 DAC 2x AK4499EX XMOS XU216 LAN UPnP Roon 32bit 768kHz DSD512 MQA Silver
Excellent DAC - Horrible Streamer !
The DAC is excellent however the streaming module is an afterthought that is very buggy ! There are regular drop outs when streaming from Roon and the device will register itself with a new MAC-adress on your network at EVERY startup. This has been confirmed by multiple users on head-fi.org forums. Also note that this is not a Roon Ready device, it's a Roon bridge which is NOT officially supported by Roon. In fact, Gustard does not have a license to claim Roon compatibility and it does not appear in the list of Roon compatible devices (https://roon.app/en/partners). The manual is an auto-translate from the Chinese version. I now stream to a Raspberry Pi running RoPieee, which is then connected via USB to the Gustard, this combo works very well. But the Gustard as a solo streaming solution ? Absolute crap.
Perfect sound & DSD direct via UPnP works!
Continuing from my previous appraisal below: please do not do anything wrong as directed by some extremist forums: just downgrade to Gustarender 1.41 (when you have received 1.43) - BalenaEtcher or USBImager would do. Install USB drivers fist (for C port above ETH). Suddenly TIDAL HiRes & MQA works without any outages and you can stream DSD from your own UPnP resources instantly! I am not a user of Roon, and I will never be - no reason for it. Thank you Audiophonics for the support!
Perfect sound but beware of DSD direct!
Sound for its price its unbeatable. But beware of DSD direct - no way to get DSD native in LAN mode - it is converted to hires PCM. Fmv 1.43. Awaiting DAC patch from Shenzenaudio.
I echanged A22 to A26 and this was good step
I have Gustard A22 for over 2 years, it goes to second system and A26 exchanged it in main system. I short - the same good, natural, full and balanced sound, with little improvement of low frequency, new model is more accurate, more detailed. And has improvements like input for external clock (I will add in future) and with LAN input! Only screen is smaller than in A22, but looks more stylish. Important - new model heat-up less than A22
Gustard unveils with the A26 a high-end DAC, as powerful as versatile. It is based on a high quality architecture, using in particular a dual...
