Top, Super Dac, the finest technology, very fine resolution,
I've already had a few dacs, but it's the best, thanks to Gustard for this miracle of sound
Highly Recommended
By buying this product you get 119 loyalty points
DAC 2x AK4499EQ PCM784kHz, DSD512 - USB version / Bluetooth 5.0 / MQA
Gustard Audio DAC A22 makes use of two AL4499EQ DAC chip. This reference component is among today's best digital to analog conversion solution.
The audio stream is divided into two channels (right and left) which are both fed independantly to each DAC chip.
The device has its own discrete Intensity / Voltage converter. This converter has been specially developed for this specific application and comes with its own adder circuit. This ensures that the DAC chips are working under optimum operating condition for superior audio precision.
The DAC-A22 is also capable of decoding and reading MQA (Master Quality Authenticated) files. These allow you to enjoy sound reproduction that is as close as possible to the original studio recording.
Under its sleek CNC-machined aluminum housing, Gustard DAC A-22 makes uses of first class components with rigorous integration.
The digital circuit is controlled by CPLD (programmable logic chip). This type of electronic controller provides a very fine control of clock cycles, phase locked loop, demodulation of DOP (DSD over PCM) signals, digital switch suppression, and digital filters.
Even after the DAC stage, each channel from the stereo signal goes through its own dedicated circuit. Thus, L & R signals each have their own voltage stabilization and several filtering stages. This ensure a crystal-clear channels separation with no audible interference.
The DAC A22 embarks not less than two high stability toroidal transformers for its power supply. This configuration allows to power separately the digital and analog circuits, which significantly reduces unwanted noise in sensitive audio circuits.
In addition, each power supply units have been carefully divided and isolated from one another to avoid the spreading of I/V fluctuations while effectively preventing the captation of interferences.
USB connectivity works through a XMOS XU208 module, a reference particularly appreciated in the world of digital audio.
The latter supports PCM audio streams up to 768kHz and native DSD up to DSD512. This make the DAC-A22 a great choice for playing high-resolution files. In addition, this module supports as well I2S signals to take advantage of this excellent technology for digital audio stream.
This module incorporates two clocks Accusilicon AS318-B, a crystal oscillator model extremely low phase noise (- than 90dBc has 10Hz) typically found in professional recording equipment as well as electronic circuits very advanced audiophiles .
The analog circuit in Gustard A22 is mainly composed of independent sub-circuit made of discrete components. for example it has a fully discrete analog low pass filter working in Class A. This type of construction is particularly interesting in the for a CPLD-driven high quality DAC in that it allows to operate optimally (and without compromise regaring performance) several circuits that do not share the same specifications.
DAC A-22 has a USB & HDMI-IIS digital input (PCM768K DSD512 driven XMOS U208 module), a SPDIF Coaxial input (PCM384K / DOP128), a SPDIF Optical input (PCM192K / DOP64) and an AES / EBU input (PCM192K / DOP64).
For it analog output, the DAC offers a balanced (XLR) and unbalanced (RCA) stereo connectors.
The I2S configuration LVDS via HDMI is not natively compatible with PS_AUDIO standards (Audio-GD ... )
Product type | DAC |
Digital inputs | I2S (HDMI) USB Coaxial S/PDIF Optical S/PDIF AES/EBU Bluetooth 5.0 |
Analog outputs | Stereo XLR (balanced) Stereo RCA (single-ended) |
DAC Chip | 2x AK4499EQ |
Sampling rate | I2S, USB : PCM 44.1 - 768kHz 16-32bit /DSD64-512 Coaxial : PCM 44.1 - 384kHz 16-24bit /DoP64-512 Optical, AES/EBU : PCM 44.1 - 192kHz 16-24bit / DoP64 MQA Files support |
Clocks | AS318-B (Accusilicon) |
USB Interface | XMOS XU208 |
Frequency response | 20Hz - 20kHz ±0.08dB |
Line output | RCA : 3Vrms @ 0dBFS XLR : 6Vrms @ 0dBFS |
XLR Pinout | 1 : GND 2 : + 3 : - |
Volume control |
Dimensions | 328 x 260 x 76mm |
Weight | 5380g |
Color | Silver |
Package | 1x Gustard DAC-A22 1x Power cable 1x USB-A to USB-B cable 1.8m 1x Remote control (requires 2 x AAA 1.5V batteries sold separately for operation) 1x Antenna |
Input | Optical |
Input | AES/EBU |
Input | SPDIF |
Input | I2S via HDMI |
Input | USB |
Output | XLR |
Output | RCA |
DAC / ADC Chip | AK4499 |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Color | Silver |
Networking | No |
Remote Control | Yes |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Mathias L.
