GUSTARD X12 XMOS Symmetrical Out ES90018 XMOS USB AES / EBU 32bit 384Khz
By buying this product you get 54 loyalty points
Reference : 11003
549,00 €tax incl.
457,50 € tax excl.
The DAC ConverterGustard X12 XMOS ES9018 SABERis designed according to the rules of the art. This 32 bit 384Khz DAC has a neat USB input inspired by the Gustard U12 USB / SPDIF interface of the same manufacturer. With an accuracy of 0.1PPM and a power of 500MIPS with processor CPLD Altera MAX II,the DAC X12 offers a high level of resolution at a democratic price, a very low jitter, a fully symmetrical discrete transistor output.
The quality of its components (clock ESS ES9018 TCXO 100MHZ), its processorAltera MAX IICPLDwith 8MB of built-in memory, its isolation bridge on I2S input predestines its use on high-end Hi-Fi systems. Of course, this DAC with its asynchronous USB inputs with three separate clocks decodes the DSD 64, 128, DXD 32 bit 384Khz being fully ASIO bit perfect under Windows (requires a driver supplied on mini CD).
His aliaslinear dual transformer (one for digital, one for analog) shielded very neat provides a very low noise level preventing jitter by electrical pollution. The regulation section proposes 4 ROVER capacitors of 10000μF / 35V, LM2941 regulators and discrete transistors based.
Compatibility HDMI / I2S :
The entry HDMI to I2S formatDAC Gustard X12 XMOS is compatible with Audio GD format. (To see theDiagram at the bottom of the description).
General technical characteristics:
  • TCXO full size clock 100Mhz (ES9018) (0.1PPM).
  • Altera MAX II CPLD Processor
Digital Inputs:
  • One USB Audio class 2.0 input.
  • An I2S input on HDMI (see wiring diagram) 32bit 384Khz.
  • A standard input IEC60958 AES EBU 110Ohm XLR pins Gold plated 24bit 192Khz.
  • A coaxial input to standard IEC60958 insulation PTFE 75Ohm Plated Gold 24bit 192Khz.
  • A Toslink optical input with standard IEC60958 24bit 96Khz.
Analog Outputs:
  • An analog balanced stereo output gold-plated pins.
  • An analog stereo output on Cinch RCA CMC plated Gold PTFE insulation.
The bundle contains:
  • An IEC power cord of 1m75.
  • A mini CD containing the XMOS drivers.
Dimensions and weight:
  • 385x280x150mm.
  • Weight with packaging 4Kg.
ITS / HDMI Schema of Gustard Audio Products.
[Img-17221-left-thickbox_default]
[Img-17233-left-thickbox_default]
+1 pour Gustard
Je possède ce DAC depuis 6 mois, très bon matériel, rien à redire, c’est une belle amélioration par rapport à mon précédent matériel. Probablement un des meilleurs rapport qualité prix dans les dac mono-ESS9018 en XLR. Pour moi il est au dessus du Aune S16 niveau son, même si le look est un peu austère :-)
Quelques remarques :
- S’associe bien avec un réglage du volume passif (level pilot dans mon cas)
- Il est allumé h24 depuis 6 mois sans broncher
- Très bon support sur Mac et Linux (DSD, DoP), je n’ai pas testé sur Windows
- De base l’entrée USB n’est pas forcément aussi bonne que l’AES ou l’I2S sur ce DAC (idéalement branché à U12 de la même marque)
Néanmoins, complété avec une bonne alim externe sur l’USB, on obtient des résultats vraiment spectaculaire.
Je recommande !
This review has been posted for GUSTARD X12 XMOS Symmetrical Out ES90018 XMOS USB AES / EBU 32bit 384Khz
