By buying this product you get 134 loyalty points
Discover the new AUDIO R2R DAC CYAN 2 here.
Symmetric DAC & Headphone Amplifier PCM 24 bit 384KHz
The Cyan at Holo Audio offers the capabilities of decoding a DAC owner discrete component based on the so-called DAC R2R ladder technology. A calibrated digital stage for supplying symmetrical high-quality analog output.
The DAC is itself natively capable of operating a DSD conversion> PCM DSD256 up and will thus not limited by audio format issues. Similarly, possibilities of digital decoding make a Swiss Army knife since the decoding is possible to switch between decoding without oversampling, or oversample up to 384kHz. As many convenient options to refine compliance Foncton signal characteristics of other elements of the chain. Cyan so effectively prevent much of the unwanted colorations.
In the version PCM, Cyan is built around two distinct symmetrical circuits that provide a net signal and high accuracy as well as to the headset to the amplifier. Far from being a secondary feature, the headphone output meets the same quality of exigeances that the link connecting the analog digital converter to the amplifier. It is an excellent option for those who sail regularly between listening to the speakers and headphones. Cyan is quite suitable for headphones and in-ear systems demanding and can easily feed helmets at the highest level and high impedance. .
From the device menu, you can choose between low and hi fashion that will take into account the specific characteristics of different helmets that will be submitted to nvoyer a suitable signal.
The DAC Cyan incorporates advanced components for an enhanced audio experience.
Its XMOS unit U8 USB 3.0 benefits of galvanic isolation and clocks with a very low drift with phase-locked loop adjusted to a reduced jitter, even with very demanding digital resolution.
Cyan's remote is able to control the device in its most common functions. You can enable and disable remote oversampling, mutate and Unmute the audio, change the screen display, increase / decrease the volume, input selection, select actrive output.
This remote, very robust, mainly benefits a formidable design that uses the warm gilding and copper Cyan.
Type | DAC / Headphone Amp |
Input | USB 3 / Coaxial / Optical / AES / EBU / I2S (HDMI) |
Output | XLR and RCA (symmetrical) / Headset (symmetrical 4 pin XLR) |
CYAN model | PCM |
volume control | Yes (digital) - all output |
Selection OS / NOS | Yes (OUR 48k) |
oversampling PCM | 352.8 or 384K (32 bit) |
Selection high impedance / low headphones | Yes |
THD + N @ 1k | 0.0001% |
SNR | -125dB |
THD + N @ 1K Headset | 0.0015% |
SNR | -120dB |
Low impedance load (asymmetric) | 400mW @ 32ohm |
Low impedance load (balanced) | 1600mW @ 32ohm |
high impedance load (asymmetric) | 300mW |
Low impedance load (balanced) | 3000mW |
Dimensions | 260x281x55 mm |
Weight | 4.75g |
Parts supplied | |
Power cable | x1 |
Infrared Remote Control | x1 |
USB-A male to USB-B male cable | x1 |
Input | Optical |
Input | I2S via HDMI |
Input | SPDIF |
Input | HDMI |
Input | XLR |
Output | XLR |
Output | RCA |
Max sampling rate | 384kHz |
Color | Black |
Color | Gold |
