HOLO AUDIO SPRING 3 LEVEL 2 PREAMP R2R DAC Preamplifier
Holo Audio unveils with the Spring 3 a beautiful R2R DAC / preamplifier based on discrete components. Custom designed, it offers incredible performances thanks to its Trickle Down technology. Its particular architecture allows it to deliver a sound restitution of an unbelievable richness and purity. It embeds two totally separate circuits, one in charge of PCM streams and the other of DSD streams.
By buying this product you get 338 loyalty points
Reference : 18757
3 389,00 €tax incl.
2 824,17 € tax excl.
Holo Audio Spring 3 Level 2PEAMP Balanced R2R DAC 32bit 1536kHz DSD1024
HoloAudio Spring 3 Level 2 DAC R2R Symétrique 32bit 1536kHz DSD1024
Holo Audio unveils with the Spring 3 a beautiful R2R DAC / Preamplifier based on discrete components. Custom designed, it offers incredible performances thanks to its Trickle Down technology. Its particular architecture allows it to deliver a sound restitution of an unbelievable richness and purity. It embeds two totally separate circuits, one in charge of PCM streams and the other of DSD streams. An impressive design which allows to benefit fully from the capacities of this last format. In addition, this version benefits from balanced preamplification with fully discrete, relay-controlled volume control. The preamplifier technology comes directly from the Serene brand preamplifier, and incorporates 4 modules and over a hundred transistors.
  • New generation of linear compensation technology to correct component resistance and switching problems.
  • The new generation of de-glitch technology provides full bandwidth without increasing background noise.
  • The Spring 3 achieves a SINAD of over 112dB and a dynamic range of >128dB, the best performance an R2R DAC can offer.
  • PLL+FIFO technology for drastically reduced jitter. Use of a high-performance femtosecond VCXO as the source of the PLL clock signal.
  • Proprietary firmware for the USB interface, with ultra-low latency and exceptional reliability.
  • I2S input via HDMI with independent four-channel circuitry, eliminating jitter and interference problems. Configurable I2S input pinout for maximum compatibility.
Level 2 Model
The Level 2 model of this Holo Audio Spring 3 incorporates specially designed capacitors for optimal power filtering for more neutral and detailed sound reproduction. It is also equipped with a Red Label 5N transformer with copper wiring. This version also comes with a CNC-machined remote control.
R2R & DSD
The Spring 3 is one of the few balanced R2R DACs to natively support DSD streams, using directly the discrete components of the D/A conversion stage. It is also compatible with MAC (DoP), Linux (DoP) and Windows (Native and DoP) systems.
R2R Architecture
Today's delta-sigma DACs differ from R2R models, as the former technology goes through an oversampling and high-speed digital switching stage that can cause distortion and sound artifacts. The R2R structure, on the other hand, is much more direct and pure, using a high-precision resistor network that negates the problems associated with delta-sigma conversion. What's more, the HoloAudio Spring 3 is the first discrete DAC with linear compensation, providing extremely accurate sound reproduction.
The input stage of the Spring 3 uses an AOP and its output stage discrete components, the latter operating in Class A.
Incredible sound reproduction
One of the Spring 3's strengths is its ability to deliver a wide soundstage with great precision. High frequencies are particularly detailed, without being aggressive. Bass frequencies are deep and textured, but never mask the midrange.
Linear compensation
The Spring 3 incorporates an additional R2R ladder, allowing compensation of the main R2R ladder. This additional ladder works in a similar way to trimming, but without changing the value of the resistors. It is digitally controlled and effectively compensates the tolerance of the resistors. A method that allows to reach a very high level of accuracy, with an almost perfect linearity, an extremely low THD and a particularly high SNR.
Holo Audio Spring 3 review by AudioScienceReview (WolfX-700)
Test du HoloAudio Spring 3 par AudioScienceReview (WolfX-700)
This product works with both 220V AC and 110V AC supply voltage. By default, however, it is set for use with 220V AC. For use on 110V AC, it is necessary to set the device to this supply voltage via an internal switch before use and connection.
Product typeR2R DAC / Preamplifier
Inputs1x USB-B
1x I2S via HDMI
1x Optical Toslink
1x AES/EBU
1x Coaxial (RCA)
1x Coaxial (BNC)
1x Balanced stereo XLR
Supported samplinf ratesUSB : PCM up to 32bit 1536kHz, Native DSD up to DSD1024, DSD DoP up to DSD512
Optical, Coaxial, AES/EBU : PCM up to 24bit 192kHz, DSD DoP up to DSD64
THD+N0.00032% @ PCM 48K NOS, 1K (1-110dB)
0.00025% @ DSD128X, 1K (-112dB)
Dynamic range127dB @ PCM 48K NOS
115dB @ DSD128X
DAC Output voltageRCA : 2.9Vrms @ PCM 48K NOS, 1.45Vrms @ DSD128X
XLR : 5.8Vrms @ PCM 48K NOS, 2.9Vrms @ DSD128X
Supply voltage110-240VAC 50/60Hz
Power cableIncluded
Housing materialAluminum
Dimensions430 x 300 x 55mm
Weight8.5kg
Package1x Spring 3 Level 2
1x USB-A to USB-B Cable
1x Aluminum remote control
Input
  • AES/EBU
  • BNC
  • I2S via HDMI
  • Optical
  • SPDIF
  • USB
Output
  • RCA
  • XLR
DAC / ADC Chip
  • R2R LADDER DAC
Max sampling rate
  • 1536kHz
  • DSD1024
Color
  • Black
Class
  • N/A
Networking
  • No
Remote Control
  • Yes
HOLO AUDIO SPRING 3 LEVEL 2 PREAMP Balanced R2R DAC 32bit 1536kHz DSD1024
Holo Audio unveils with the Spring 3 a beautiful R2R DAC / preamplifier based on discrete components. Custom designed, it offers incredible...
