By buying this product you get 338 loyalty points
Holo Audio unveils with the Spring 3 a beautiful R2R DAC / Preamplifier based on discrete components. Custom designed, it offers incredible performances thanks to its Trickle Down technology. Its particular architecture allows it to deliver a sound restitution of an unbelievable richness and purity. It embeds two totally separate circuits, one in charge of PCM streams and the other of DSD streams. An impressive design which allows to benefit fully from the capacities of this last format. In addition, this version benefits from balanced preamplification with fully discrete, relay-controlled volume control. The preamplifier technology comes directly from the Serene brand preamplifier, and incorporates 4 modules and over a hundred transistors.
The Level 2 model of this Holo Audio Spring 3 incorporates specially designed capacitors for optimal power filtering for more neutral and detailed sound reproduction. It is also equipped with a Red Label 5N transformer with copper wiring. This version also comes with a CNC-machined remote control.
The Spring 3 is one of the few balanced R2R DACs to natively support DSD streams, using directly the discrete components of the D/A conversion stage. It is also compatible with MAC (DoP), Linux (DoP) and Windows (Native and DoP) systems.
Today's delta-sigma DACs differ from R2R models, as the former technology goes through an oversampling and high-speed digital switching stage that can cause distortion and sound artifacts. The R2R structure, on the other hand, is much more direct and pure, using a high-precision resistor network that negates the problems associated with delta-sigma conversion. What's more, the HoloAudio Spring 3 is the first discrete DAC with linear compensation, providing extremely accurate sound reproduction.
The input stage of the Spring 3 uses an AOP and its output stage discrete components, the latter operating in Class A.
One of the Spring 3's strengths is its ability to deliver a wide soundstage with great precision. High frequencies are particularly detailed, without being aggressive. Bass frequencies are deep and textured, but never mask the midrange.
The Spring 3 incorporates an additional R2R ladder, allowing compensation of the main R2R ladder. This additional ladder works in a similar way to trimming, but without changing the value of the resistors. It is digitally controlled and effectively compensates the tolerance of the resistors. A method that allows to reach a very high level of accuracy, with an almost perfect linearity, an extremely low THD and a particularly high SNR.
This product works with both 220V AC and 110V AC supply voltage. By default, however, it is set for use with 220V AC. For use on 110V AC, it is necessary to set the device to this supply voltage via an internal switch before use and connection.
Product type | R2R DAC / Preamplifier |
Inputs | 1x USB-B 1x I2S via HDMI 1x Optical Toslink 1x AES/EBU 1x Coaxial (RCA) 1x Coaxial (BNC) |
Outputs | 1x Single-ended stereo RCA 1x Balanced stereo XLR |
Supported samplinf rates | USB : PCM up to 32bit 1536kHz, Native DSD up to DSD1024, DSD DoP up to DSD512 USB : PCM up to 32bit 1536kHz, Native DSD up to DSD1024 Optical, Coaxial, AES/EBU : PCM up to 24bit 192kHz, DSD DoP up to DSD64 |
THD+N | 0.00032% @ PCM 48K NOS, 1K (1-110dB) 0.00025% @ DSD128X, 1K (-112dB) |
Dynamic range | 127dB @ PCM 48K NOS 115dB @ DSD128X |
DAC Output voltage | RCA : 2.9Vrms @ PCM 48K NOS, 1.45Vrms @ DSD128X XLR : 5.8Vrms @ PCM 48K NOS, 2.9Vrms @ DSD128X |
Supply voltage | 110-240VAC 50/60Hz |
Power cable | Included |
Housing material | Aluminum |
Dimensions | 430 x 300 x 55mm |
Weight | 8.5kg |
Color | Black |
Package | 1x Spring 3 Level 2 1x USB-A to USB-B Cable 1x Aluminum remote control |
Input | BNC |
Input | SPDIF |
Input | I2S via HDMI |
Input | AES/EBU |
Input | USB |
Input | Optical |
Output | RCA |
Output | XLR |
Max sampling rate | DSD1024 |
Max sampling rate | 1536kHz |
Color | Black |
Class | N/A |
Networking | No |
Remote Control | Yes |
