IFI AUDIO NANO iDSD BLACK LABEL Headphone Amplifier / DAC Burr Brown PCM1793 BitPerfect 32bit 384kHz DSD256 MQA
The iFi Audio iDSD Nano Black Label is presented as a DAC combo and mobile headphone amplifier. Featuring high quality components and intelligent technologies, it allows you to enjoy high quality listening on the go, thanks in particular to the support of high-resolution files.
Reference : 13395
199,00 €tax incl.
165,83 € tax excl.
iFi Audio Nano iDSD Black Label
Headphone Amplifier / DAC Burr Brown BitPerfect PCM1793 32bit 384kHz DSD256 MQA
iFi Audio Nano iDSD Black Label Amplificateur / DAC Casque Burr Brown Bit Perfect 32bit 384kHz DSD256 MQA
In addition, the iDSD Nano Black Label also integrates two other iFi Audio products under its hood. The iPurifier of the USB input provides effective signal isolation to limit interference and background noise for clear reproduction. One of the two headphone outputs is equipped with iEMatch technology, which automatically adapts to the impasse of the connected headphones;.
Hi-Res, MQA, DSD... it's all there!
Designed to accompany a smartphone or mobile device, the iDSD Nano Black Label is a powerful DAC with high-end performance. It includes a Burr Brown PCM1793 DAC capable of supporting high-resolution files. PCM up to 32bit 384kHz, native DSD512, DXD and even MQA, the DAC / iFi Audio Amplifier at everything to delight audiophiles wishing to enjoy their entire high-definition music library without limitation.
S-Balanced Technology
Whether you have a symmetrical or asymmetrical headset, the iDSD Nano Black Label will provide excellent sound reproduction. It incorporates S-Balanced technology to optimize conventional asymmetric headsets in order to approximate the quality of reproduction of symmetric headsets. The device can also deliver 2x285mW to accompany the vast majority of headsets.
Asynchronous USB & AMR Clock
The USB input of the iDSD Nano Black Label operates in asynchronous mode and a can be used with a smartphone/tablet, DAP or computer. The internal AMR clock of the device from the telecommunications sector and therefore subject to strict requirements, has AMR Zero Jitter Lite technology and allows to drastically limit jitter and digital noise.
Precise volume control
On the iDSD Nano BL the volume control is analog. It ensures extremely precise volume control and undiminished sound quality.
Filtering system
The iDSD Nano Black Label also features a filter system, rarely found on mobile devices. A switch allows to select the option Measure " which corresponds to the filter Linear Phase Transient Aligned Filter or the option Listen which corresponds to the filter Minimum Phase Bezier Filter.
Great autonomy
The device is equipped with a Lithium-Polymer battery giving it a 10-hour reading time. Enough to allow you to listen to your favorite songs throughout the day and wherever you are.
Product typeHeadphone Amplifier / DAC
InputUSB-A 2.0 OTG with iPurifier technology
Outputs1x Fixed Stereo Jack 3.5mm
1x Direct Jack 3.5mm
1x Jack 3.5mm with iEMatch technology
DAC Specifications
DACBurr Brown PCM1793 BitPerfect
Sampling rate / Supported formatsPCM up to 384kHz
DSD256
DXD up to  384kHz
MQA up to 192kHz
PCM filtersListen : Min. phase optimized transient
Measure : Optimized frequency response
DSD filtersListen : Extended frequency response, optimized transient
Measure : Noise reduction
DXD filterFixed BitPerfect process
MQA filterFixed MQA process
Amplifier & headphone output specifications
Power output2x285mW
Dynamic rangeDirect : > 109dB(A) @ 3V
iEMatch : > 107dB(A)
THD+N< 0.005% @ 125mW/30R
Max voltage output(< 10% THD)> 3.5V @ 600 Ohm (Direct, 20mW/600 Ohm)
> 2.9V @ 30 Ohm (Direct, 285mW/30 Ohm)
> 1.7V @ 15 Ohm (Direct, 200mW/15 Ohm)
Output impedanceDirect : < 1 Ohm
iEMatch : < 4 Ohm
Channel separation> 79dB @ 600 Ohm (Direct)
> 79dB @ 15 Ohm (Direct, 1kHz, balanced)
Line output specifications
Dynamic range> 109dB(A)
THD+N (0dBFS)< 0.004%
Output voltage2.15V (+/- 0.05V)
Output impedance< 240 Ohm
Channel separation> 99dB (@ 1kHz)
Power supplyRechargeable on USB port Lithium-Polymère batteries
Autonomy10h playback
Consumption< 3W
Housing materialAluminium
Dimensions96 x 25 x 64mm
Weight139g
OutputJack 3.5mm
ClassN/A
The iFi Audio iDSD Nano Black Label is presented as a DAC combo and mobile headphone amplifier. Featuring high quality components and intelligent...
