IFI AUDIO ZEN DAC SIGNATURE Balanced DAC Burr Brown USB XMOS 8 Core MQA 384kHz DSD256
iFi Audio offers with the Zen DAC Signature an improved version of its Zen DAC V2. This one gets rid of its headphone amplification stage to concentrate on its digital/analog conversion stage and to get the best performances thanks to a circuit and high-end components.
Reference : 15378
299,00 €tax incl.
249,17 € tax excl.
his product has been replaced by the new version, the IFI AUDIO ZEN DAC SIGNATURE V2 DAC XMOS 16 Core.
iFi Audio Zen DAC Signature
iFi Audio Zen DAC Signature Convertisseur Symétrique Burr Brown USB XMOS 16 Core MQA 384kHz DSD256
iFi Audio offers with the Zen DAC Signature an improved version of its Zen DAC V2. This one gets rid of its headphone amplification stage to concentrate on its digital/analog conversion stage and to get the best performances thanks to a circuit and high-end components. We find there for example Panasonic OS-CON, Murata and ELNA Silmic II capacitors, a GMT clock or a TOCOS multi-track potentiometer. The circuit has been redesigned to be as short as possible, in order to ensure a direct transmission of the signal. This design favors an expressive sound reproduction of great precision.
True Native architecture
The digital stage of the Zen DAC Signature keeps the True Native architecture thanks to the use of a Burr Brown chip, a brand often solicited by iFi Audio for the musicality of its components. The True Native architecture allows to support high sampling rates, up to 32bit 384kHz PCM, DSD256 (Native) but also to support DXD and MQA decoding. The sample rate of the file being played is also indicated by the color of the LED behind the volume knob.
iFi Audio's programmed 8-core XMOS USB interface provides fast and efficient processing of data received from the USB input, and audiophile-grade oscillators ensure minimal jitter for perfect digital audio signal handling.
Connections
The Zen DAC Signature offers a simple but very effective connectivity. The USB-B input supports SuperSpeed 3.0 technology. The transmission is asynchronous, the data rate being regulated by the clock circuit to ensure high precision and extremely low jitter.
The output can be either an unbalanced stereo RCA or a balanced 4.4mm jack. The latter allows you to enjoy a high quality balanced audio transmission.
Fixed or variable level
The outputs of the Zen DAC Signature can be used with either a fixed or variable output level, with a switch on the back of the unit to select the desired option.
Thus, selecting a variable level will allow volume control to be applied to the audio signal, with the Zen DAC Signature then functioning as a preamplifier, which can be connected directly to a power amplifier.
On the other hand, the fixed level allows you to bypass the volume control, setting the output level to 4.2V balanced and 2.1V unbalanced. This parameter is therefore mainly used for use with an external preamplifier, an integrated amplifier or active speakers with their own volume controls.
Product typeDAC
DAC ChipBurr Brown DSD1793
Input1x USB-B 3.0
1x Balanced Jack 4.4mm
Native DSD up to DSD256
DXD up to 384kHz
MQA
Output impedanceBalanced : ≤ 200Ω
Single-ended : ≤ 100Ω
SNR< -117dB(A) @ 0dBFS
Dynamic range> 117dB(A) @ -60dBFS
THD+N< 0.0011% @ 0dBFS
Output level (balanced)Variable : 2V-6.2V
Fixed : 4.2V
Output level (single-ended)Variable : 1V-3.3V
Fixed : 2.1V
Supply voltage5V DC (iFi Audio iPower MK2 power supply included)
Dimensions160 x 117 x 35mm
Weight750g
OutputJack 4.4mm
DAC / ADC ChipDSD1793
Max sampling rateDSD256
Max sampling rate384kHz
iFi Audio offers with the Zen DAC Signature an improved version of its Zen DAC V2. This one gets rid of its headphone amplification stage to...
