By buying this product you get 74 loyalty points
The J.C Acoustics UDP-5 is a DAC and headphones amplifier based on audiophile components. It features two ES9039Q2M DAC chip and an XU216 interface for support of high-resolution sampling rates up to PCM 32bit 768kHz and DSD512. It also boasts a balanced Class AB headphone amplifier circuit with four TPA6120A2 chips for output power of up to 7500mW under 32 ohm on its balanced headphone output.
The device is completed by a high-performance power supply consisting of a 60VA transformer and no less than 6 filter capacitors. Each component is independently powered for low noise. The front panel features an attractive 3” color IPS display with a practical, modern interface. As for connectivity, the UDP-5 has plenty to offer, with numerous digital inputs, two headphone outputs (6.35mm jack/4.4mm jack) and two analog outputs (RCA/XLR).
The UDP-5 benefits exclusively from high-quality components and an audiophile architecture to get the best out of your audio sources.
The UDP-5's digital-to-analog conversion is based on two ESS ES9039Q2M DAC chip and an XMOS XU216 USB interface. This enables it to support high-resolution sampling rates up to PCM 32bit 768kHz and DSD512. In addition, an SC8422 chip supports optical / coaxial SPDIF signal processing up to 24bit 192kHz.
The headphones amplifier stage features a balanced architecture with four OPA1642 and four TPA6120A2 amplifier chips for detailed, powerful sound reproduction. This configuration offers excellent dynamics and resolution across all frequencies. As a result, the UDP-5's headphone outputs deliver substantial power, making it a headphone amplifier capable of driving high-end, high-impedance headphones.
Balanced 4.4mm jack headphones output power:
6.35mm jack headphones output power:
The front panel of the UDP-5 headphones amplifier DAC features a beautiful 3” color IPS display. This is accompanied by a modern, practical interface. In fact, it provides access to the various information concerning the current playback, as well as navigation between the device's different parameters.
The UDP-5's power supply circuit is based on an optimised 60VA custom-made OFC copper transformer, six filter capacitors totalling almost 30,000µF and a regulated five-line power supply, allowing a stable and clean current to be delivered independently to each component of the unit. This enables the UDP-5 to achieve exceptional audio performance.
1 | Color IPS display |
2 | Balanced 4.4mm headphones output |
3 | Single-ended 6.35mm headphones output |
4 | Multifunction button |
5 | Balanced XLR output |
6 | Single-ended RCA output |
7 | Coaxial input |
8 | Optical Toslink input |
9 | I2S LVDS input via HDMI |
10 | USB-B input |
11 | Power supply |
Product type | DAC / Headphones amplifier |
DAC chips | 2x ES9039Q2M |
Amplification chips | 4x TPA6120A2 |
OPA | OPA1642 |
Inputs | 1x USB-B 1x Coaxial 1x Optical Toslink 1x I2S LVDS via HDMI |
Outputs | 1x Single-ended RCA output 1x Balanced XLR output 1x Balanced 4.4mm jack headphones output 1x Single-ended 6.35mm jack headphones output |
Supported sample rates | USB: PCM 32bit 768kHz, DSD512 (DoP & Native) SPDIF coaxial and optical toslink: 24bit 192kHz I2S LVDS via HDMI: PCM 32bit 768kHz, DSD512 (DoP & Native) |
DAC specifications (balanced XLR output) | |
Frequency response | 20Hz-40kHz (+/-0.2dB) |
THD+N | 0.00021% (-6dB @ 1kHz, A-WT) |
SNR | 118dB |
Channel separation | -131dB @ 1kHz |
Line output power | RCA: 2.3Vrms XLR: 4.6Vrms |
Headphones amplifier specifications (balanced 4.4mm jack output) | |
THD+N | 0.00030% (7Vrms @ 1kHz, A-WT) |
Frequency response | 124dB |
Channel separation | -129dB |
Output power | 4.4mm balanced jack: 6800mW @ 32 ohm / 720mW @ 300 ohm / 360mW @ 600 ohm 6.35mm unbalanced jack: 1680mW @ 32 ohm / 180mW @ 300 ohm / 90mW @ 600 ohm |
Power supply | 230V AC (Fusible 1.6A) |
Power consumption | < 25W Standby : 3W |
Color | Silver |
Dimensions | 239 x 50 x 208mm |
Weight | 3kg |
Package | 1x J.C Acoustics UDP-5 1x USB-A to USB-B cable 1x Power cable |
Input | SPDIF |
Input | I2S via HDMI |
Input | USB |
Input | Optical |
Output | RCA |
Output | Jack 6.35mm |
Output | XLR |
Output | Jack 4.4mm |
DAC / ADC Chip | ES9039Q2M |
Max sampling rate | DSD512 |
Max sampling rate | 768kHz |
Color | Silver |
Class | Class A / AB |
Networking | No |
Remote Control | No |
