KECES S3 DAC Preamplifier Headphone Amplifier ES9026Pro 32bit 384kHz DSD256
-9%
With the Keces S3 you get an all-in-one device, covering the functions of DAC, preamplifier and headphone amplifier. Carefully designed with high-end components, it provides a high quality sound reproduction that is as rich and precise as it is dynamic.
Reduced price!
Reference : 17033
Limited special offer
1 750,00 €tax incl.
-9%
1 600,00 €tax incl.
1 333,33 € tax excl.
Shipping date: 22-04-2025.
Keces S3
Keces S3 DAC Préamplificateur Amplificateur Casque ES9026Pro 32bit 384kHz DSD256
Its digital-to-analog conversion section is equipped with a 32bit ESS ES9026Pro DAC chip that uses HyperStream® II arcitecture and Time Domain Jitter Eliminator technology to ensure excellent sonic performance. It also enables the S3 to support high-resolution audio streams, up to 32bit 384kHz PCM and DSD256.
On its side, the headphone amplification circuit of the S3 allows him to develop an important power which can go until 2*2000mW under 32Ω. It can thus accompany without difficulty as well very sensitive in-ear monitor as high impedance headphones.
With its extensive connectivity, the Keces S3 is also able to respond to the vast majority of usage scenarios, both balanced and single-ended. On the input side, there are USB-B, coaxial, optical, single-ended RCA and balanced XLR. For the outputs, we can also count on single-ended RCA and balanced XLR, as well as on balanced XLR 4 pins and unbalanced Jack 6.35mm headphone outputs.
The front of the device has a screen displaying information about the playback and a volume control. The latter is associated with a very precise relay attenuation circuit.
Product typeDAC
Headphone amplifier
Preamplifier
Inputs1* Coaxial
1* Optical Toslink
1* USB-B
1* Single-ended stereo RCA
1* Balanced stereo XLR
Outputs1* Single-ended stereo RCA
1* Balanced XLR 4 pins headphone output
1* Single-ended Jack 6.35mm headphone output
DAC chips1* ESS ES9026Pro
Supported sampling ratesUSB: PCM up to 32bit 384kHz, Native DSD up to DSD256, DSD DoP up to DSD128
Optical / Coaxial: PCM up to 24bit 192kHz, DSD DoP up to DSD64
Analog inputs
Input impedance47kΩ
Max input levelXLR: 10Vrms
RCA: 5Vrms
Input/Output gain0dB
Analog outputs
SNRXLR: > -122dB @ 20Hz-20kHz, A-Weighting
RCA: > -119dB @ 20Hz-20kHz, A-Weighting
THD+NXLR: < 0.0004% @ 1kHz, A-Weighting
RCA: < 0.0007% @ 1kHz, A-Weighting
Frequency responseXLR: 20Hz-20kHz (+0dB/-0.09dB)
RCA: 20Hz-20kHz (+0dB/-0.03dB)
CrosstalkXLR: > -124dB @ 1kHz
RCA: > -122dB @ 1kHz
Output levelXLR: 0-4Vrms adjustable @ 0dBFS
RCA: 0-2Vrms adjustable @ 0dBFS
Headphone outputs
SNRXLR 4 Pins: > -120dB @ 20Hz-20kHz, A-Weighting
Jack 6.35mm: > -108dB @ 20Hz-20kHz, A-Weighting
THD+NXLR 4 Pins: < 0.00115% @ 1kHz, A-Weighting, 300Ω, 100mW
Jack 6.35mm: < 0.0015% @ 1kHz, A-Weighting, 300Ω, 100mW
Frequency responseXLR 4 Pins: 20Hz-20kHz (+0dB/-0.09dB)
Jack 6.35mm: 20Hz-20kHz (+0dB/-0.09dB)
Output impedanceXLR 4 Pins: 0.6Ω
Jack 6.35mm: 0.6Ω
Output powerXLR 4 Pins: 2000mW @ 32Ω THD+N 0.1% / 1200mW @ 300Ω, THD+N 0.1% / 650mW @ 600Ω THD+N 0.1%
Jack 6.35mm: 1200mW @ 32Ω, THD+N 0.1% / 350mW à 300Ωn THD+N 0.1% / 175mW @ 600Ω, THD+N 0.1%
Supply voltage110-120VAC 60Hz
220-240VAC 50Hz
Consumption30W
Dimensions (W*D*H)300*220*66mm
Weight4kg
Housing materialAluminum 4mm
InputXLR
OutputJack 6.35mm
DAC / ADC ChipES9026PRO
Max sampling rateDSD256
Max sampling rate384kHz
ClassN/A
Remote ControlYes
With the Keces S3 you get an all-in-one device, covering the functions of DAC, preamplifier and headphone amplifier. Carefully designed with...
