Headphone Amplifier and DAC ES9038Q2M 32bit 768kHz DSD512 Rede
The Loxjie D10 is both a USB DAC and a sedentary headphone amplifier. Using an ESS ES9038Q2M chip, it provides transparent reproduction with a high signal-to-noise ratio and a very low level of distortion. In addition, the DAC, in combination with the USB XMOS interface, supports sampling rates up to 32bit 768kHz in PCM and the DSD up to DSD512. The clocks integrated into the circuit allow the jitter to be lowered.
"The Loxjie D10 has an innovative form factor and industrial design. It has equal pluses and minuses in practice so I let you judge that aspect. On performance front, its DAC nearly aces all of my tests, going well past its budget pricing. Unfortunately the ESS IMD Hump is there, knocking it back a step or two. Still, I think it provides a very good option for a DAC at such a reasonable price."
For the headphone amplifier stage, the D10 includes a specially developed MTCAC (Multi-Chip Current Amplifying Circuit) circuit using discrete components on a Class AB architecture. This ensures low distortion and a high output level, allowing the D10 to be combined with many headphones, including demanding models requiring a significant power input.
A | Power ON/OFF LED |
B | USB / Hi-Res LED |
C | Optical / DSD LED |
D | Coaxial / Headphone amplifier LED |
E | ON/OFF Button |
F | Volume + |
G | Volume - |
H | Output selection |
I | Jack 3.5mm output |
J | Stereo RCA output |
K | Coaxial input |
L | Optical input |
M | Micro USB / Power supply input |
N | Aux power supply Micro USB |
The D10 comes with a Micro USB cable for power supply.
Spécifications | ||
Product type | DAC and headphone amplifier | |
Inputs | 2x Micro USB 1x Optical Toslink 1x Coaxial SPDIF | |
Outputs | 1x Stereo RCA 1x Jack 6.35mm | |
USB Transmission | Asynchronous | |
Power | 100mW @ 32Ω | |
Dynamic range | 122dB | |
SNR | RCA Output : 115dB Jack 6.35mm Output : 105dB | |
THD+N | RCA Output : 0.0003% Jack 6.35mm Output : 0.003% | |
Supported sampling rates | USB : PCM up to 32bit 768kHz / DSD up to DSD512 Coaxial : PCM up to 24bit 192kHz / DSD up to DSD64 (DoP) Optical : PCM up to 24bit 96kHz |
Général | |
Case material | CNC Machined Aluminium |
Color | Red |
Consumption | 1.5W |
Standby consumption | <0.5W |
Dimensions | 200 x 89 x 60mm |
Weight | 450g |
