LOXJIE D30 AK4493EQ DAC Headphone Amplifier XMOS 32bit 768kHz DSD512
Loxjie offers with the D30 a small DAC and headphone amplifier combo with high performance and affordability. It features excellent components for great sound reproduction, while offering full connectivity for easy integration into the vast majority of audio systems.
4.8 / 5
Reference : 14816
179,00 €tax incl.
149,17 € tax excl.
The Loxjie D30 is now replaced by the Loxjie D30 V2 ES9068AS.
Loxjie D30
DAC Headphone Amplifier AK4493EQ XMOS 32bit 768kHz DSD512
Loxjie D30 DAC Amplificateur Casque AK4493EQ XMOS 32bit 768kHz DSD512
AK4493 DAC
At the heart of the digital-to-analog conversion stage is an AKM AK4493EQ DAC, ensuring excellent audio performance. The AKM AK4493EQ DAC has a very low distortion of only 0.00017% (-115dB) and a wide dynamic range of 121dB, for rich, accurate and lively sound.
The chip also supports high sample rates up to 32bit 768kHz PCM and DSD512 for a high-definition listening experience.
Bluetooth
Practical, the Loxjie D30 allows you to transmit your audio files remotely, in Bluetooth, directly from your smartphone. The Bluetooth 5.0 standard combined with the aptX protocol allows for a stable and high quality transmission.
Filters
The AKM AK4493EQ DAC chip AK4493EQ offers six digital PCM filters to adapt the sound reproduction to your audio system or type of listening.
Loxjie D30 DAC Amplificateur Casque AK4493EQ XMOS 32bit 768kHz DSD512 Loxjie D30 DAC Amplificateur Casque AK4493EQ XMOS 32bit 768kHz DSD512
Preamplifier mode
The D30 has a stereo RCA preamplifier output. This "Pre-Mode" has 3 different parameters: The fixed mode locks the output level at 3Vrms, the variable mode allows it to take advantage of the volume control of the device and the DDSD mode, which allows DSD files not to be impacted by the volume level processing.
Components
The entire Loxjie D30 benefits from a careful design, based on components known for their audio quality. It includes the very good AKM AK4493EQ DAC, but also an AK4118A digital receiver of the same brand, allowing efficient processing of digital streams, while ensuring a very low jitter of only 49ps for the Coaxial input and 79ps for the Optical input. The USB input is associated with an XMOS U308 interface supporting audio streams up to 32bit 768kHz PCM and DSD512. The circuitry also includes a low-distortion, low-noise AOP LM4562 and low phase noise oscillators.
Robust and elegant
The D30's components are housed in an elegant and robust Aluminum case, offering excellent rigidity that also eliminates case vibration, while limiting the impact of electromagnetic interference on circuits.
Schema
1Screen
2Jack 6.35mm headphone output
3Volume / power button
4RCA stereo output
5Bluetooth antenna
6Optical input
7Coaxial input
8USB input
9Power supply input
10Power button
Product typeDAC
Headphone amplifier
Inputs1x USB-B
1x Coaxial
1x Optical
Bluetooth 5.0
Outputs1x Stereo RCA
1x Jack 6.35mm headphone output
DAC ChipAK4493EQ
Digital receiver chipAK4118A
USB interfaceXMOS U308
THD+N0.00017% (-115dB)
Output levelVariable : 3Vrms
Fixe : 2.2Vrms
DDSD : 2Vrms
Dynamic range121dB
SNR121dB
Supported bluetooth codecsSBC
aptX
USB transmissionAsynchronous
USB CompatibilityWindows 7/8/8.1/10
Mac OS X 10.6 ou antérieur
Linux
Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD up to DSD512
Optical / Coaxial : PCM up to 24bit 192kHz
Headphone amplifier power2x 110mW @ 32Ω
Housing materialAluminum
Consumption3W
Dimensions151 x 170 x 38mm
Weight535g
Package1x Loxjie D30
1x Remote control
1x Bluetooth antenna
1x USB Cable
1x Power cable
THD+N
Frequency response
RCA output dynamic range
RCA output SNR
OutputJack 6.35mm
DAC / ADC ChipAK4493EQ
Max sampling rate768kHz
Max sampling rateDSD512
ClassN/A
Remote ControlYes
8 reviews
Bien, mais...
Présentation au top, fonctions intéressantes, écran parfait.
Hélas, si les performances sont réelles sur le papier, à l'écoute, le son est très "électronique" : précis mais agressif, impropre à traduire les timbres des instruments de l'orchestre.
Bref, à réserver à des écoutes de musiques "modernes" : amateurs de classique, allez voir ailleurs... et plus cher !
This review has been posted for LOXJIE D30 AK4493EQ DAC Headphone Amplifier XMOS 32bit 768kHz DSD512
Excellent DAC
Appareil sans fioritures et bien conçu. Restitution musicale précise et fluide (tests sur musique classique et jazz). A noter une alim intégrée probablement de meilleure qualité que les blocs secteur habituels (avec accessoirement un gain de place notable). L'ampli casque fonctionne bien sur mon AKG k271 Studio facile à driver (55 Ohms d'impédance) et m'a permis de me débarrasser sans hésitation de mon imposant ampli casque SAMSON C-que-8 en conservant la même qualité globale de restitution (plus de détails avec le loxjie assurément, peut-être un chouia moins de pêche mais c'est même pas sûr...). La télécommande est très légère mais pas assez directionnelle.
Pas du tout testé le bluetooth.
Dans l'ensemble, vraiment un super appareil !
Excellent DAC
I use it via a USB connection to a Sony TA-F3000ES amplifier that powers the Wharfedale Diamond 230 speakers. I am very happy with the purchase.
Excellent appareil à prix raisonnable
Ce petit appareil a un excellent rapport qualité/prix. Le design est sobre et efficace. La finition est très bonne même s'il faut être évidemment précautionneux, notamment avec le connecteur USB-B. La restitution sonore est de qualité.
Configurations testées :
- connecté à mon lecteur CD et enceintes sans ampli, belle restitution sonore quel que soit le filtre utilisé.
- connecté à mon PC en USB, bonne restitution avec de grosses différences selon la qualité de la source (fichiers audio, vidéo, jeux, internet et streaming ...) et le filtre utilisé (avec purifieur audio en entrée de DAC).
- connecté à mon PC via Bluetooth, excellente restitution sonore à 3m, scène large et aérée, bluffant ... et plutôt cool pour supprimer les câblages !
Conclusion : je recommande vivement ce matériel au regard de son rendu et de son prix.
PS : merci à Audiphonics pour l'envoi très rapide, l'emballage de qualité et la traçabilité du produit.
Excellent appareil
Une découverte que ce petit appareil. Le DAC est très performant sur le papier, et à l'écoute aussi (Entrée USB - Flac 44.1 et 96: tout est nickel). L'ampli casque est précis et pas du tout agressif, largement suffisant en puissance pour mon AKG 702.
La sortie ligne (un ampli PP à tubes derrière) est sans défaut. On entend tout, et le son est très naturel.
Alim intégrée, ergonomie au top....
Le BT fonctionne bien (je n'utilise pas trop, juste testé.....). Ce n'est pas la philo de ce type d'appareil, je pense, mais c'est un plus.
Les 2 volumes (ligne et casque) sont indépendant et mémorisés: parfait.
L'écran n'est pas bien grand, mais l'appareil lui même est très petit. De toutes façons, une fois les réglages faits, on l'oublie, sauf éventuellement le réglage du volume.
Il me reste à explorer les filtres (il y en a 6) pour bien comprendre à quoi ça sert, et si ça s'entend.... Mais tout le reste est très bien conçu et facile à mettre en oeuvre, aucune faute de goût.
Et à ce prix là.... Rapport Qualité/Prix imbattable. Même pour le DAC seul!
Merci au support technique Audiophonics (Mr Aubert) pour les conseils avisés.
Loxjie offers with the D30 a small DAC and headphone amplifier combo with high performance and affordability. It features excellent components for...
