By buying this product you get 53 loyalty points
With its D60 DAC / headphone amplifier, Loxjie offers a modern, high-performance device, carefully designed and equipped with audiophile components. It incorporates an ES9039MSPRO DAC chip with MQA decoder, as well as an XMOS XU-316 USB interface, enabling it to support sampling rates up to PCM 32bit 768kHz, DSD512 and MQA-CD. Versatile, it features numerous digital inputs, including an HDMI I2S input and Bluetooth 5.1 reception thanks to a latest-generation Qualcomm chip.
On the headphone amplification side, it benefits from a balanced architecture and offers three outputs: single-ended 6.35mm jack, balanced 4.4mm jack and balanced XLR 4 pins. It is capable of delivering power up to 2x350mW at 600Ω and 2x6000mW at 16Ω, enabling it to drive all types of headphones. The package is rounded off by a nice display and user-friendly interface, as well as the possibility of using numerous PCM and DSD filters. As for its RCA and XLR line outputs, they feature adjustable output levels of 2.5Vrms and 5.2Vrms maximum respectively.
Loxjie has equipped its D60 with an ES9039MSPRO DAC chip and XMOS XU-316 USB interface, enabling it to support sampling rates up to PCM 32bit 768kHz, native DSD up to DSD512 and MQA-CD. As a result, the D60 lets you enjoy audio files of the highest possible resolution for rich, precise sound reproduction.
The symmetrical architecture of the D60's headphone amplifier circuit limits noise and interference levels, while greatly enhancing the dynamic range of the unbalanced 6.35mm jack, balanced 4.4mm jack and balanced 4-pin XLR headphone outputs. Headphone listening with the D60 is rich in detail. What's more, it boasts a power reserve capable of driving headphones with impedances ranging from 16 ohm to 600 ohm:
A latest-generation Qualcomm Bluetooth 5.1 receiver chip enables the D60 to support standard SBC and AAC codecs, as well as high-resolution aptX and aptX HD codecs. This provides reliable, stable wireless transmission quality for fast, convenient use with a smartphone, for example.
The Loxjie D60's various filters can be used to modify the signal's transient response to adapt to different types of source and optimize sound reproduction.
The D60's HDMI I2S input enables it to retrieve signals from a variety of sources, thanks to two available interface modes: normal or inverted.
The use of these eleven OPAs enables fast, instantaneous multichannel processing with reduced latency.
The balanced headphone amplifier circuit features three high-quality output interfaces.
The clock circuit is optimized for low jitter.
Discrete linear regulators and low-noise components for clean power supplies to analog circuits.
On the front of the D60 is a beautiful screen with an intuitive, modern and dynamic user interface. It also features a Bluetootth remote control for convenient remote control.
1 | Screen |
2 | Multifunction button |
3 | Single-ended 6.35mm jack headphone output |
4 | Balanced 4.4mm jack headphone output |
5 | Balanced XLR 4-pin headphone output |
6 | Single-ended RCA line output |
7 | Balanced XLR line output |
8 | AES/EBU input |
9 | Bluetooth antenna |
10 | HDMI I2S input |
11 | Toslink optical input |
12 | Coaxial input |
13 | USB-B input |
14 | Power input / Power switch |
Product type | DAC / Headphone amplifier |
DAC chip | ES9039MSPRO |
USB interface | XMOS XU-316 |
Inputs | 1x USB-B 1x Coaxial 1x Optical Toslink 1x HDMI I2S 1x AES/EBU Bluetooth |
Outputs | 1x Single-ended RCA line output 1x Balanced XLR line output 1x Single-ended 6.35mm jack headphone output 1x Balanced 4.4mm jack headphone output 1x XLR 4-pin balanced headphone output |
Supported sample rates | USB: PCM up to 32bit 768kHz, Native DSD up to DSD512, MQA-CD Coaxial, Optical, AES/EBU: PCM up to 24bit 192kHz, DSD DoP64 |
THD+N | 0.00005% (-125dB) |
Dynamic range | RCA: 127dB XLR: 132dB |
SNR | RCA: 127dB XLR: 132dB |
Line output impedance | 100Ω |
Line output level | RCA: 2.5Vrms XLR: 5.2Vrms |
USB transmission | Asynchronous |
USB compatibility | Windows 7 / 8 / 8.1 / 10 / 11 MAC OS Linux |
Unbalanced headphone output power | 2x3000mw @ 16Ω 2x1500mw @ 32Ω 2x350mW @ 300Ω 2x175mW @ 600Ω |
Balanced headphone output power | 2x6000mw @ 16Ω 2x3000mw @ 32Ω 2x700mW @ 300Ω 2x350mW @ 600Ω |
Power supply | 100-240V AC |
Energy consumption | < 40W Standby: < 0.5W |
Color | Silver |
Dimensions | 245 x 196 x 46mm |
Weight | 1.495kg |
Package | 1x DAC / Headphone amplifier Loxjie D60 1x Remote control 1x Bluetooth antenna 1x USB-B to USB-A cable 1x Mains cable |
Input | SPDIF |
Input | Bluetooth |
Input | AES/EBU |
Input | USB |
Input | Optical |
Input | I2S via HDMI |
Output | RCA |
Output | Jack 6.35mm |
Output | XLR |
Output | Jack 4.4mm |
DAC / ADC Chip | ES9039MPro / ES9039MSPro |
Max sampling rate | DSD512 |
Max sampling rate | MQA |
Max sampling rate | 768kHz |
Color | Silver |
Class | N/A |
Networking | No |
Remote Control | Yes |
