MATRIX MINI-I 3 Balanced DAC ES9038Q2M Headphone Amplifier Streamer 768kHz DSD512
This fourth version of the Matrix Audio Mini-i series features network player capabilities as well as a balanced, powerful audio circuit while maintaining the superb compact design of its predecessors.
By buying this product you get 83 loyalty points
Reference : 14700
839,00 €tax incl.
699,17 € tax excl.
This product has been replaced by the new version, the MATRIX MINI-I 3 PRO MQA DAC ES9038Q2M.
Matrix Mini-i 3
Streamer / Headphone amplifier / DAC ES9038Q2M 768kHz DSD512 Balanced
The interface gains in readability thanks to the introduction of a 3.3-inch color screen offering a pleasant and intuitive use.
Network drive
The main evolution of the Matrix Mini-I-3 lies in its functionalities since it now includes a complete network drive.
The device can work with a wide range of digital audio sources. Thanks to its Roon Ready configuration and its support for UPnP protocols, the Mini-i 3 can easily receive bit-perfect audio streams via a LAN connection or from an Apple device with AirPlay.
The Mini-i-3 functions as a Roon terminal, allowing a simple, transparent remote connection that does not require any configuration to achieve bit-perfect audio stream.
Balanced headphone output
The Mini-I-3 incorporates a balanced low noise, low distortion headphone amplification circuit. The latter is accessible via a 6.35mm jack connector as well as a 4.4mm jack connector compatible with most of the most popular balanced headphones.
The power of the headphone amplifier has been significantly revised upwards from previous versions with an increase in power of 50% for an unbalanced connection and of 370% for a balanced connection.
Bluetooth HD
Unlike previous versions of the Matrix Mini-i series, the Mini-i 3 now uses an integrated antenna to ensure quality wireless transmission without compromising the ergonomics and aesthetics of the device.
Its bluetooth receiver supports the LDAC standard and can therefore work with compatible sources to receive digital streams with an impressive resolution reaching 96kHz / 24bit. Likewise, the bluetooth reception circuit is compatible with the apt-X HD standard and supports 48kHz / bit streams with your bluetooth audio sources sharing this standard.
Digital & Analog inputs / Analog outputs
Numerous digital connectors are available as input to allow all kinds of integration into almost all types of advanced audio installations.
The Mini-i 3 has its own SPDIF interface with coaxial and optical connector, ideal for connecting your CD players, SPDIF drives, televisions and game consoles.
The USB interface is now accessible via a USB-C connector for a reliable and easy connection. The latter allows operation as a USB DAC to add very high definition audio output to your computers and other USB devices.
Finally, there is an I2S receiver directly accessible on an HDMI connector. The latter respects the LVDS pinout and offers very high performance connectivity for your most advanced high fidelity devices.
In addition to its excellent digital connectivity, the Mini-I3 has a very useful analog input for turntables, radios,cassette players... This stereo analog input on an RCA connector is a very elegant and space-saving solution for easily connecting audio sources of different technologies within a single Hi-Fi installation.
Superb 3.3 "screen with GUI
Unlike previous versions of its series, the Mini-i 3 has a 3.3 "24-bit color LCD screen on the front. The display offers a superb color interface which provides a very intuitive solution to control all the functions of the DAC.  Active inputs, streaming protocols, device configuration and even filtering options as well as I2S interface definitions.
Comparaison of Matrix Devices
Spec DeviceElement XElement PElement MElement IMini-i 3Mini-i Pro 3
DAC chipES9038 PRO + ES9311ES9028 PROES9038Q2M
DAC ChipXMOS U216XMOS U208XMOS U216
PCM : 16-24Bit 768kHz
DSD : 11.2MHz (DoP)
DSD : 22.4MHz (Native)
PCM : 16-24Bit 384kHz
DSD : 5.6MHz (DoP)
DSD : 11.2MHz (Native)
DSD : 11.2MHz (DoP)
MQA : 24bit 384kHz
DSD : 11.2MHz (DoP)
ClocksCrystek CCHD-950
Ultra Low Phase Noise
Femtosecond
SiTime Low Phase NoiseCrystek CCHD-950
Femtosecond
Digital InputsOptiquex2x1
Coaxialx2x1
I2S (LVDS)x1
Bluetooth
Réseau
USBx1 USB-Bx1 USB-C
Line InRCAx2
Line OutRCAx1x1
XLRx1x1
Amplified output2×230W@4Ω
Headphone OutXLR4 & Dual XLR3x1
Single-Ended 6.35mmx1x1
Balanced 4.4mmx1
NetworkLAN10BASE-T/100BASE-TX
WLAN2.4GHz/5GHz
IEEE 802.11
a/b/g/n/ac
2.4GHz
IEEE 802.11
a/b/g/n
Non2.4GHz/5GHz
IEEE 802.11
a/b/g/n/ac
Volume controlHyper-Control
Relay + Digital Volume
MUSES 72320
Volume resistor network
Digital volume
Storage DeviceTF Card
USB HOST X2
USB HOST X2
NAS SupportSMB V1.0 & V2.0
ARMQuad-CoreDual-CoreSingle-Core
DriveLocal filesMP3 , WMA , WAV , AIF, AIFC, AIFF, AAC, FLAC, OGG, APE, ALAC, M4A, DSF, DFF
AirplayAirplay 1Airplay 2
DLNA
Roon Ready
MQADecoder + RendererDecoder + Renderer
IR remote
Power SupplyLinear Noratel
40W
Linear Noratel
25W
Linear
30W
External AC Adapter
20W
Linear Noratel
20W
Dimensions340×281×60mm275×281×60mm240×220×55mm223x205x48mm
Weight4.2Kg4.7Kg3.7Kg1.5Kg1.7Kg
FunctionsNetwork Drive
DAC
ADC
Headphone Amplifier
Volume control
Source selection
ArchitectureBalanced
Digital inputsCoaxial SPDIF
Optical SPDIF
USB-C
RJ45
WiFi
Bluetooth
I2S (HDMI)
Analog inputRCA Stereo
Digital outputsRCA Stereo single-ended
XLR Stereo balanced
DACES9038Q2M
SNR125dB
THD+N0.00028% THD+N
File typePCM up to 384kHz 32bit
DSD 256
DOP64 on SPDIF inputs
BluetoothLDAC
Apt-X HD
Power cableIncluded
IR remoteIncluded
InputI2S via HDMI
InputRJ45
OutputJack 4.4mm
OutputJack 6.35mm
DAC / ADC ChipES9038Q2M
Max sampling rateDSD256
Max sampling rate384kHz
ColorSilver
NetworkingYes
Remote ControlYes
This fourth version of the Matrix Audio Mini-i series features network player capabilities as well as a balanced, powerful audio circuit while...
