MATRIX X-SABRE PRO MQA FULL DECODER DAC USB I2S ES9038PRO 32Bit/768kHz DSD1024 Black
With this updated version of the X-Sabre Pro, Matrix offers us a 32bit DAC based on an ES9038Pro chip. This new version adds support for Master Quality Authenticated (MQA) technology to the already impressive technical capabilities of the X-Sabre Pro.
By buying this product you get 224 loyalty points
Reference : 14205
2 249,00 €tax incl.
1 874,17 € tax excl.
Matrix X-Sabre Pro MQA
DAC USB I2S ES9038Pro 32bit 768kHz DSD1024 Noir
Matrix X-Sabre Pro MQA DAC USB I2S ES9038Pro 32bit 768kHz DSD1024 Noir
This 32bit DAC is thus able to manage DSD and PCM digital streams (including MQA), making it an extremely complete high-fidelity converter.
Testing and measurements by Audio Science Review
That beauty runs deep when it comes to performance as Matrix Audio X-Sabre Pro MQA unseats its own brother to take the crown of the best DAC I have ever measured. Considering that the list now includes nearly 160 DACs, this is an incredible achievement. "
Test et mesures du Matrix X-Sabre Pro MQA par Audio Science Review
MQA DAC (Full Decoder)
The X-Sabre Pro MQA is equipped with an MQA decoder (integral decoder / full decoder). This is the most advanced class of MQA decoders, capable of natively managing Stream Authentication, Origami Unfold to Core and integrating file platform-specific compensation at the decoding level.
This approach, similar to FLAC, allows to obtain files rich in details while strongly limiting the size of the files. It is therefore a very advantageous tool for fans of high-definition streaming music who will be able to enjoy a listening quality comparable to FLAC while saving up to 50% bandwidth (at equivalent resolution and frequency). This offers a multitude of advantages in terms of loading times, the quality of the network required and the fluidity of the runway sequence.
ES9038Pro
The X-Sabre Pro is equipped with the ES9038Pro chip. This 8-channel chip has powerful internal DSP units and offers a complete panel of reconstruction filters. It is mainly able to natively decode the DSD while maintaining compatibility with DoP or dCS streams in the case of multiple sources.
In addition to these important capabilities, the DAC ES9038Pro is best known for its exceptional performance, with a THD below 0.0002% or a signal-to-noise ratio of 134dB
Ultra-complete connectivity
The DAC X-Sabre Pro MQA has an impressive array of connectors including USB, Coaxial, Optical, AES/EBU and I2S LVDS via HDMI.
The I2S port offers excellent transmission performance and allows short distance and very high speed interconnections.
Finally, this I2S input allows the X-Sabre Pro MQA to process DSD files up to DSD1024 (45,158Mhz).
High precision electronic circuitry
In order to integrate as well as possible with all audiophile installations, the X-Sabre Pro MQA from Matrix Audio has a clock configuration function, capable of activating the ES9038Pro's own asynchronous clock, but also its own ultra-low noise internal clock. Dedicated software controls this setting to significantly improve the decoding of audio streams.
Both clocks are operated by Crystek high-frequency audio oscillators. The latter benefit from an extremely low phase noise of -169dB and provide clock signals of dreadful accuracy. Two oscillators are in charge of 44.1kHz and 48kHz sampling rates and their multiples, while the third is the reference clock of the ES9038Pro chip.
No less than 10 power supply units ensure the proper functioning of each unit in the circuit. A dedicated ultra-low noise LDO ES9311 controller with two own power supply units (1µVrms of noise) provides power to the left and right channels of the analog circuit.
XMOS XU2016 & AK4118 Interfaces
To get the most out of the ES9038Pro's excellent capabilities, the X-Sabre Pro MQA features an XMOS XU2016 USB interface (asynchronous) and an AK4118 S/PDIF interface.
These high-performance components allow the DAC to work under the best conditions in order to benefit from excellent computing power and multi-channel processing capacity.
High Gain +18dB Setting
The line output of the DAC can be configured with a digital gain of +18dB. Therefore, it is not necessary to add an additional preamplifier for active speakers with low gain. The X-Sabre Pro MQA can also be used with a power amplifier for greater flexibility.
Mlink trigger only works with other Matrix devices which have a Mlink input.
Product typeDAC
DAC chipSabre ES9038Pro 32bit
Channel numberx8 Delta Sigma
140dB dynamic
HyperStream DAC
Digital inputs1x AES/EBU
1x Coaxial
1x Optical
1x I2S LVDS via HDMI
1x USB-B
Analog output1x Balanced XLR
1x Single-ended RCA
Supported frequencyAES/EBU : PCM 16-24Bit 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz / DSD64 (DoP/dCS)
Coaxial : PCM 16-24Bit 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz / DSD64 (DoP/dCS)
Optical : PCM 16-24Bit 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz / DSD64 (DoP/dCS)
I2S (PS Audio) : PCM 16-32Bit 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, 384kHz, 705.6kHz, 768kHz / DSD64/128/256 (DoP/dCS) DSD64/128/256/512/1024 (Native DSD)
USB : PCM 16-32Bit 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, 384kHz, 705.6kHz, 768kHz / DSD64/128/256 (DoP/dCS) DSD64/128/256/512 (ASIO Native)
SNRXLR : -134dB 20Hz-20kHz
RCA : -129dB 20Hz-20kHz
THD+NXLR : <0.00012% @ 1kHz
RCA : <0.00018% @ 1kHz
Frequency responseXLR : 20Hz-20kHz
RCA : 20Hz-20kHz
CrosstalkXLR : -151dB @ 1kHz
RCA : -143dB @ 1kHz
Output levelXLR : 4.5Vrms fixed @ 0dBFS DAC Mode / 0-4.5Vrms adjustable @ 0dBFS PRE Mode
RCA : 2.25Vrms fixed @ 0dBFS DAC Mode / 0-2.25Vrms adjustable @ 0dBFS PRE Mode
CompatibilityWindows 7/8/8.1/10 (driver needed)
Mac OS X 10.6 (native)
Android (OTG needed)
iOS (Camera Kit Apple needed)
Supply voltageAC 220V-240V 50/60Hz (230V position)
AC 100V-120V 50/60Hz (115V position)
Consumption< 10W
Dimensions300 x 218 x 45mm
Weight3.7kg
Housing materialAluminium
Package1x Matrix X-Sabre Pro MQA
1x RM2 Remote Control
1x USB Cable
1x Power cable
InputAES/EBU
InputI2S via HDMI
DAC / ADC ChipES9038PRO
Max sampling rateDSD1024
Max sampling rate768kHz
Remote ControlYes
5 reviews
DAC preamp haut de gamme
Après quelques heures de chauffe et de rodage, il commence à révéler son énorme potentiel. Certains détails des enregistrements m’avaient jusqu’alors complètement échappés, les voix et les instruments sont réalistes en termes de timbre, texture et détails. La dynamique est simplement bluffante sans dureté sur le haut du spectre, et la scène sonore prend naturellement place.
Merci pour vos conseils éclairés, c’est exactement le produit que je cherchais.
This review has been posted for MATRIX X-SABRE PRO MQA FULL DECODER DAC USB I2S ES9038PRO 32Bit/768kHz DSD1024 Black
outstanding
the performans is outstanding .
can only prais !
Top of the lot
This year I got the munchies for digital music... got myself a cocktail audio x50d and the hunt for a dac started, beginning with an excellent Topping D70 from audiophonics but it had its shortcomings. Next up was the even sharper aune s8 reference dac that I still love ,but it didn't either go the full mile..
Matrix audio X-Sabre Pro MQA really gives you it's every penny worth...
I'm not hunting anymore
superbe qualité de fabrication et superbe écoute .
Bonjour , livraison rapide , très content et satisfait de ma commande . Produit sérieux , de qualité , construction haut de gamme . Qualité son sublime . Merci AUDIOPHONICS .
A. D.
Exceptionnel
J'ai reçu mon nouveau Dac un "MATRIX X-SABRE Pro MQA" et je voulais vous faire part de mes premières impressions. En premier la qualité de fabrication est irréprochable digne de modèles coutant 3 à 5 fois plus cher. Côté rendu musical, le gap est très important par rapport à l'Audiophonics , tout deux équipés pourtant, de la même puce "SABRE ES9038 Pro". Heureusement qu'il y a une différence car côté tarif on joue pas dans la même division, 469€ pour l'Audiophonics contre près de 1900€ pour le Matrix.
Côté son, je dirais que ce Matrix est fait pour les fichiers en haute résolution ( HI RES, DSD et MQA ) et là il est loin devant. Une scène plus profonde ou chaque instrument est bien à sa place. Dans un enregistrement en LIVE au moment des applaudissement, on devine la profondeur de la salle et si un applaudissement se détache des autres on pourrait le situer.
Cet AM j'ai écouté un album que je connais bien "Getz At The Gate (live) en qualité MQA, c'était magique. Dans le morceau "52nd Steet Theme" à un moment il y a un solo de batterie, quel pieds ! j'avais l’impression que la batterie était physiquement dans ma pièce d'écoute là devant moi à droite.
Après une cinquantaine d'heures d'écoute je dirais que ce MATRIX est vraiment un Dac audiophile de référence. J'avais jamais eu l'occasion d'écouter des Dac valant plusieurs milliers d'euros, mais je pense que celui-ci est vraiment capable de convaincre des audiophiles très exigeants.
Un grand merci à Audiophonics pour la qualité de leurs services.
 (3)
With this updated version of the X-Sabre Pro, Matrix offers us a 32bit DAC based on an ES9038Pro chip. This new version adds support for Master...
